Old 06-10-2010, 09:01 PM   #76
smokeyfan1000
Guest
B21, B23,B230 block drain petcock's OEM Volvo adapter bushing is: 3/8-18 NPT. So if wanting to use another adapter for a Aftermarket 52mm WT gauge, you can mount the sender in the block drain location.
I have done this trick 3 times, but was never absolutely sure that the hole in the block was for a NPT bushing. Now I know it is a NPT, 3/8 -18 OEM adapter bushing and you do too.. Finally.
Old 06-10-2010, 10:02 PM   #77
smokeyfan1000
Guest
The OEM Volvo adapter bushing for the Block drain petcock (and with the hex provision for a wrench), is a 3/8-18 NPT fitting/bushing. YUP!
Old 06-20-2010, 09:44 AM   #78
kahluaTDI
kahluaTDI's Avatar
Double checked this and it is in fact correct, 3/8th NPT
SEO Baby!
Home Inspections in SW Washington
kahluaTDI is offline   Reply With Quote
Old 06-26-2010, 08:41 PM   #79
hindesite
hindesite's Avatar
Default Clay's white 1993 940 -> help getting stock radio out
sorry - no comment on this post.
D. Hindes
a.k.a. -> hindesite
hindesite is offline   Reply With Quote
Old 06-26-2010, 10:31 PM   #80
Texas240
Prius Owner
Texas240's Avatar
knock sensor on the B230 is a 12mm head
93 245 LS Engine Swap Project
Old 12-17-2010, 03:44 PM   #81
brYan
What is the bolt size/thread pitch for the 3 bolts for the dp flange to a t3?
brYan is offline   Reply With Quote
Old 03-21-2011, 10:40 AM   #82
omanaran
omanaran's Avatar
Could anyone tell me how to set back the flywheel timing position on a B230FT engine please
omanaran is offline   Reply With Quote
Old 03-23-2011, 12:04 AM   #83
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
If you're talking about an LH2.4 engine (1990+?), you need the blank to be in the starter hole with number one piston at TDC.
cheers
James
'05 V70 D5
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'69 164
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 03-23-2011, 12:04 AM   #84
foggyjames
foggyjames's Avatar
cheers
James
Old 06-13-2011, 12:22 PM   #85
swedishiron.com
I sell Volvo parts!
Diesel motor mount part number:
from Beachee in this thread: http://forums.turbobricks.com/showthread.php?t=238319
Hello
The volvo diesel rubber engine mounts are: 1229805 & 1272346
Here in Norway they are rather expensive, about $100 each. You'll probably find them cheaper in the states.
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 06-30-2011, 11:15 PM   #86
cleanflametrap
cleanflametrap's Avatar
FI temp sensor threads LH2.0/2.2/2.4 (ECT)
-Art
Old 09-04-2011, 10:37 AM   #87
smokeyfan1000
Guest
240 steering wheel nut- 27mm deep socket (hope not a repost)
True , Also, just so happens that a standard 1 1/16 deep socket will also fit steering wheel nut, in case metric socket is unavailable
Old 10-29-2011, 03:44 PM   #88
242Bleek
k-jet groupie
242Bleek's Avatar
Just thought id throw this out there. I need to know the thread size on the one coolant pipe plug that comes on the 16v head by the temp sensors. Id like to assume it's 1/4" npt but I could be wrong, just need to be sure
Originally Posted by TestPoint View Post
The D24 did not accelerate, it accumulated speed.
82' 242t 16v-Every mod known to man kind
72' 162E-B30 (no the 2 isn't a typo)
83’ kjet with 245 attached
98’ s70x2
95' s10 awd LS 1000+club
VFBG
242Bleek is offline   Reply With Quote
Old 10-29-2011, 10:53 PM   #89
John2x240
John2x240's Avatar
Get a guage like this: http://www.amazon.com/Rockler-Bolt-S...e_hi_ai_ps_t_1, but there are some that have both and thread sizes, which are more useful.
'88 Volvo 240 auto (now a parts car), '89 Volvo 240 5 spd. (now a daily driver), '92 245 5 spd. (new my car), '80 Holiday Rambler/Ford E350 (tow vehicle and track crash pad), '95 GMC K2500 (local hauler/back-up tow vehicle), '83 Mazda RX7 (race car when I have the funds), '99 Miska 20' car hauler.
The man's prayer: "I'm a man, but I can change, ... if I have to, ... I guess."
John2x240 is offline   Reply With Quote
Old 12-14-2011, 04:40 PM   #90
940Orlando
940Orlando's Avatar
B230FT (8v) cam cap nuts: M8x1.25
940Orlando is offline   Reply With Quote
Old 01-16-2012, 12:36 PM   #91
Dakar09
The Blue Baastard
Dakar09's Avatar
Found this kit for adapting NPT sensors to the metric fittings on the heads and/or block. No more custom drilling/tapping if you choose to go this route...
http://www.dakotadigital.com/index.c...110/prd110.htm
Tony
1958 Volvo PV444
1983 245 Turbo - The Project - Targa Newfoundland entry - Sold
http://forums.turbobricks.com/showthread.php?t=225396
2002 BMW M5 - Sold
2011 F150 FX4 Screw with Ecoboost V6
Past bricks - '95 855 manual, '98 V70 T5 Manual, '04 V70R 6-speed, '10 XC60 T6
Dakar09 is offline   Reply With Quote
Old 02-03-2012, 11:59 AM   #92
BLS
Question Starter bolts
Didn't see the starter bolts in this FAQ. I had to cut off the heads and then lost the rest during my slow rebuild job on a 1990 240DL.
BLS is offline   Reply With Quote
Old 02-08-2012, 11:46 AM   #93
Sol_Turbo_Love
Sol_Turbo_Love's Avatar
Does anyone know the size/pitch of an M46 hydraulic clutch slave cylinder bleed valve?
-94' 944ti, RC 550cc's, t3/t4, Ford WC T5, 3" MAF, TLAO chips, 3" super 40 sideout, IPD cam, SLC wideband, KYB coil overs, Eibach springs, dual sways, iPD chassis braces +more fun stuff.
-87' 780 Bertone 5.0HO V8, Bilstein HDs, g80 rear
7/9 T5 swap parts for sale!
Buyer/seller feedback
Sol_Turbo_Love is offline   Reply With Quote
Old 03-01-2012, 12:25 PM   #94
Josepilove
anyone know the drive shaft bolt sizes for a aw71 240?
Josepilove is offline   Reply With Quote
Old 03-26-2012, 03:10 PM   #95
Fuse
Fuse's Avatar
What's the thread size for an EGR thermostat valve in redblocks. It's the one below intake manifold and has two vacuum ports. It goes in to the head next to the temp sensors.
Thread is tapered so I would suspect NPT but if someone knows for sure..
Volvo R-Sport - Equipment for the car enthusiast.
http://www.volvo300mania.com
Fuse is offline   Reply With Quote
Old 03-27-2012, 11:05 PM   #96
ellist
240 exhaust heat shield bolts: M8 x 1.25 x 12mm length
ellist is offline   Reply With Quote
Old 04-28-2012, 10:07 AM   #97
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Anyone know the size of the drain hole in the block for the turbo drain back?
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 05-08-2012, 12:51 PM   #98
Ursan
Ursan's Avatar
Ah, 29mm deep if you can find it, 1 1/8" if you can't.
Old 05-20-2012, 04:59 PM   #99
Milos
water temp sender for dashboard gauge from b230FT = 5/8 -18 UNF
Milos is offline   Reply With Quote
Old 06-08-2012, 06:55 AM   #100
HonestJhon
HonestJhon's Avatar
Flexplate hardware
Flexplate to crank and flex plate to torque converter...?
HonestJhon is offline   Reply With Quote
