Old 07-23-2012, 04:28 PM   #101
BGoins12
BGoins12's Avatar
Anyone know how much I need to torque the bolts down for the rear main seal carrier plate?
-William
'98 S90 - 201k - Whiteblock POWAH
'97 Mazda B2300 (Ford Ranger) - 186k - 2.3/5-Speed - No POWAH
BGoins12 is offline   Reply With Quote
Old 07-23-2012, 05:07 PM   #102
vvpete
IIRC they are 7 lb/ft torque.
vvpete is offline   Reply With Quote
Old 07-23-2012, 10:57 PM   #103
BGoins12
BGoins12's Avatar
I figured it was something low, mainly because of the size of the bolts. I just tightened them and snugged them a bit, so probably around 10-12 ft/lbs. Plus I used threadlocker so they should be good for another 160k or so.
Old 08-04-2012, 07:17 PM   #104
smokeyfan1000
Guest
1978-1991 240 steering column SHAFT where steering wheel retaining nut threads on is M18-1.5 thread/count.
I'm told 140s - 1977 240s have same threads/count also
Old 08-11-2012, 07:34 PM   #105
Mueller
Mueller's Avatar
Originally Posted by BLS View Post
Didn't see the starter bolts in this FAQ. I had to cut off the heads and then lost the rest during my slow rebuild job on a 1990 240DL.
bump for starter mounting hardware....even a pic could help right now
Old 10-26-2012, 01:44 PM   #106
HonestJhon
HonestJhon's Avatar
Originally Posted by HonestJhon View Post
Flexplate hardware
Flexplate to crank and flex plate to torque converter...?
anyone? in the final stages of this build and wanted to replace the old hardware (if i even have it anymore...) involved in bolting these things on.
HonestJhon is offline   Reply With Quote
Old 10-27-2012, 02:46 PM   #107
HonestJhon
HonestJhon's Avatar
checked, dont have any spare crank bolts (none in the new motor)
if anyone has a motor laying around they could check , that would be greatly appreciated. crank bolts and torque converter bolts.
Old 11-05-2012, 09:15 PM   #108
HonestJhon
HonestJhon's Avatar
nothing? i havent been over to the motor to work on it for a week....but still need the info!
i'd like to be able to order something from jegs or summit....
maybe RSI stocks something?
anyone?
Old 11-16-2012, 03:03 PM   #109
HonestJhon
HonestJhon's Avatar
bolt that fits for the crank is m10x1.5 length, im guessing is something in the 40-50mm range.
my last resort is to order them from the dealer. i just have a feeling these are going to be in the 5-6 dollars each range.
Old 12-03-2012, 02:49 PM   #110
542
A link to anything you need to know re AN fittings
http://www.precisionenginetech.com/t...rdware-part-1/
5 pages worth of reading, bottom right of article takes you to next page (not totally obvious). Lots of photos and explanations. I find Summit, Jegs etc.. frustrating when looking for fittings as its all not in one spot and always going back and forth to compare
542 is offline   Reply With Quote
Old 12-05-2012, 04:12 AM   #111
740tankDriver
Post-Hypnotic Sigma
740tankDriver's Avatar
what is the thread size on the main fuel pump check valve? not the compression-seal side the thread for the check valve to the main pump.
Happy Passover!
Great Victory!
740tankDriver is offline   Reply With Quote
Old 12-11-2012, 06:04 AM   #112
cleanflametrap
cleanflametrap's Avatar
(For Mueller)
-Art
Old 02-11-2013, 02:01 AM   #113
MistrThou
Darth Mog
MistrThou's Avatar
From impvolvo:
Lower chassis brace for 7/900
10mm x 1.5 pitch x 25mm need 3 bolts and one 10mmx1.5 pitch nut
91 944T - Gone, 93 244+t and CR-V
Photobucket sucks...
MistrThou is offline   Reply With Quote
Old 03-04-2013, 11:58 AM   #114
J.B.
Does anyone know off hand the size & pitch of the studs/nuts on the exhaust manifold flange-to-header pipe on an NA B230? I saw the manifold studs are listed here but not the next juncture on the exhaust. Possibly even the part #'s for said three studs and copper lock washers.
1979 242GT, a work in progress.
DD: 1991 245 SE.
J.B. is offline   Reply With Quote
Old 06-17-2013, 08:58 AM   #115
cleanflametrap
Surprised this wasn't in the thread already, and it was asked before at #81 but not yet answered.
M10 (1.5) -- nothing exotic. Don't know length, but can look up p/n: 977581
Old 06-17-2013, 01:55 PM   #116
smokeyfan1000
Guest
This might help a little for part numbers.
Buying them from ww.tascaparts.com is what I did.
http://forums.turbobricks.com/showth...s+part+numbers
Old 06-30-2013, 10:19 AM   #117
Harry Tuttle
From the thread referenced above:
Originally Posted by smokyfan1000
I think we need a "Volvo Part Number List" stickied on TB somewhere
+1 on that
Originally Posted by sbabbs
who cares, push start it if you have a man tranny.
Old 08-28-2013, 10:33 PM   #118
$EEKING 945 TURBO WAGON
Default Favorite quality thread pitch gauge sources? LARGE PRINT
Who sells a thread pitch gauge that has old man eyes sized readable stamped print; and useable sizes without wasting space with impractical sizes- and maybe NOT CHEESY QUALITY?
Metric/ SAE/ both?
$EEKING 945 TURBO WAGON is offline   Reply With Quote
Old 10-22-2013, 03:17 PM   #119
122power
dude
122power's Avatar
M47 drail and fill plug 18mm x 1.5.
Old 11-12-2013, 09:15 PM   #120
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
What's the length of the M8x1.25 exhaust studs?
Isaac
1995 940 Turbo:
531 head, Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Synapse Synchronic BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18
Sir Psycho is offline   Reply With Quote
Old 03-26-2014, 10:04 AM   #121
cleanflametrap
Default 240: some fuel sender pipe diameters
Old 04-04-2014, 07:30 AM   #122
cleanflametrap
The M8 studs I have (240 Ti p/n 953048) are 50mm long.
Old 04-04-2014, 07:33 AM   #123
cleanflametrap
Now, why do I have this picture?
These are the cam cover studs and the thermostat housing studs in the head (B21/23/230 best I know).
Old 05-12-2014, 01:00 PM   #124
benski
Post
Metric/ SAE/ both?
Matco tools, Part #432.
Old 05-17-2014, 03:37 PM   #125
Coupe' de Grace
Slowest in the West™
Coupe' de Grace's Avatar
per request:
k-jet and idle computer sensor ports on the block (near the dipstick)
12mm x 1.5mm 11mm x 1.5mm per honestjhon
3/8NPT
V A F
(1976 265dl/b27/m46 killed in battle, 1991)
(1976 265dl/b27/bw55 bring out ye dead, 2000)
(1980 262c/b28/m46 trebuchet fatality 2014)
1982 244t/b21ft/aw71 'Vicious Chicken of Bristol'
1989 780/b230ft/aw71 'Brave Sir Robin'
Coupe' de Grace is offline   Reply With Quote
