Old 12-31-2017, 04:10 PM   #1
Can play the blues
Default pcv mod
Some of you asked me about this recently. Here are some pictures of the pcv mod done on my 93 wagon. I did this because the drain back hose on the oil separator box is clogged and the crankcase ventilation was bad. The stock setup is still connected but this is probably the main venting going on now on my tired oil motor. Seems to work well.
Old 12-31-2017, 04:12 PM   #2
Can play the blues
I just threw this together when I was replacing the oil trap box and discovered the clogged drainback hose. This car is a road warrior taking all the crap of the bad weather.
Old 12-31-2017, 04:25 PM   #3
lummert
lummert's Avatar
Where does the lower hose in the first photo run to? Does it connect to the air inlet before the throttle body?
Old 12-31-2017, 06:35 PM   #4
Can play the blues
Correct. It's just the stock pcv hose from the flame trap to right near the throttle body cut along it's run. Then this hose from the oil cap T'd in.
Old 01-01-2018, 10:33 PM   #5
prometheus_aflame
I have a Yoshifab catch can kit for sale if you want to get that junk out of your intake for good. You'd need the hoses, but all the fittings are in the kit.
prometheus_aflame is offline   Reply With Quote
Old 01-01-2018, 10:49 PM   #6
Can play the blues
Thank you for the offer. I can't buy that now, though.
Old 01-05-2018, 02:35 PM   #7
emem1160
Did you leave the clogged block box as is or did you cap it /block it off somehow?
Where did you get the 3 way fitting? or is it the stock plastic thingy?
Hard to drill the oil cap and weld? epoxy?
Just so we can document this and others can benefit!
The more +Ts people do the more they can benefit from threads like this.
emem1160 is offline   Reply With Quote
Old 01-05-2018, 03:03 PM   #8
photoman327
photoman327's Avatar
Oil cap is from a older red block
Old 01-06-2018, 09:46 PM   #9
Can play the blues
0. I left the clogged drain hose in place. I tried to clear it with a metal wire but don't think it worked. I put a new oil trap box on there anyway.
1. the three way fitting is a local pep boys purchase. 1/2 metal 3 way hose coupler. Plus I used another straight 1/2" metal hose coupler.
2. the oil cap is for a B18B.
3. For sure!
4. This engine is n/a. A 93 B230F. Check out other threads here on catch cans and the pbase stealthfti pages for other pcv stuff.
Old 01-09-2018, 02:12 PM   #10
Ryan_R
You should be able to get a long springy brush for cleaning out aquarium hoses at a pet shop. That might clear out the drainback hose.
Just a thought.
-Ryan
Athens, OH
1987 245
1989 245 GL
1989 745 GLE
1991 745 --Regina powered B234F!
1995 945T -- Mildly modded
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 01-09-2018, 03:27 PM   #11
Can play the blues
Just a thought.
-Ryan
Thank you for the good suggestion.
If that stuff wasn't baked on and hard as a rock that might work. I pushed a hanger wire through it and it didn't really help. As suggested in another post if you want to take a chance on pouring solvent through it while the oil drain plug is out that may help. But I didn't want to take a chance on any solvent getting around the inside of the engine.
Old 01-09-2018, 03:32 PM   #12
carver
Redblock for life.
carver's Avatar
Anybody tried using a shop vac with a length of simi-rigid hose to clean the drain back? At least then you'd be removing the crap rather than pushing it in the oil pan.
carver is offline   Reply With Quote
Old 01-09-2018, 06:33 PM   #13
lummert
lummert's Avatar
Use spare oil breather, fill full of kerosene, let soak for several days, flush with hot soapy water until hot water runs clear.
Old 01-09-2018, 07:02 PM   #14
don alán
don alán's Avatar
Doesn't look like junk to me, especially if it works. Not everybody is in the market for $350 catch can kits...
ehhhhh
don alán is offline   Reply With Quote
Old 01-10-2018, 01:47 AM   #15
quillc
yv1a.com
quillc's Avatar
Did this on my wagon. Works fine and prevents the valve cover gasket from blowing by.
Get a new filler cap gasket for that thing!
The breather boxes are pretty reasonably priced from a variety of online retailers.
Chris
www.yv1a.com
Old 01-10-2018, 03:10 AM   #16
Can play the blues
LOL that oil on the valve cover is more from me spilling it when adding oil than it leaking out of the cap. It was a new gasket when I put on the cap.
