Old 01-06-2018, 04:32 PM   #1
Steerfromdarear
Default 940 immobilizer
Do the 940 2.0 red box have immobilizers
Steerfromdarear is offline   Reply With Quote
Old 01-06-2018, 06:53 PM   #2
sbabbs
sbabbs's Avatar
984 ECU does. 1997 or 1998 year wise I think. Put say 967 chip in 984 ecu to get around it or swap in earlier ecu like 967 or 954 for turbo lh2.4.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 542K MILES
sbabbs is online now   Reply With Quote
Old 01-09-2018, 02:14 PM   #3
Steerfromdarear
Are all the 940 separate fuel and ignition ECUs. is the ignition one with the immobilizer
Old 01-09-2018, 05:00 PM   #4
sbabbs
sbabbs's Avatar
No the fuel ECU has the immobilizer in it, should be ECU number 984. Swap that out to earlier non immobilizer ECU to get around the immobilizer so it will run.
Do you not have the correct key for the car? What is your problem? You can't use a 984 ECU in any car unless you have the key for it. You can put any 9xx, not 984 chip, in you 984 ECU and then it will work. I put a 967 chip in my 984 ecu to make it work around the immobilizer problem.
Is your car LH 2.4 fuel injection? Bosch? What country you in? What are you trying to do??
Old 01-09-2018, 05:25 PM   #5
Steerfromdarear
Engines in a 940 putting it in a 87 740.i have the key it's a UK spec car it has a jetronic ECU can find the number s on it
