Old 01-08-2018, 03:40 PM   #1
turbopop23
Default 1992 740 turbo wagon speedo needed
Anybody have a good speedometer cluster for a 1992 740 turbo? Mine stays between 60-90 miles per hour once the car starts to roll. I have a 92 940 turbo cluster that looks the same, but once you compare the backs of them, not even close.
1996 850 turbo wagon.Totally stock.
turbopop23 is offline   Reply With Quote
Old 01-08-2018, 04:31 PM   #2
2manyturbos
The 1992 740 and 940 speedo are exactly the same. 91-92 clusters are the same/interchange. 93-94 clusters are the same/interchange. 1995 is a one year only cluster in the US. 91-92 clusters are easy to identify because they don't have a clock adjustment knob coming through the lens. Virtually 99% of the 91-92 clusters have already failed due to defective capacitors. Get a 1993-94 940 cluster and convert it to work in your 1992 following this write-up on the Brickboard.
https://www.brickboard.com/FAQ/700-9...ngeability.htm
Old 01-09-2018, 12:30 PM   #3
turbopop23
Thanks, I guess the replacement I have must be the 95, it has the clock adjustment knob. Thanks for the info.
