Old 01-09-2018, 08:57 PM   #1
speedn_j
speedn_j's Avatar
Default I hate you 240 wiper system
Pouring rain the cables on the wiper decided to fall of the cam again. Is there a better way to have a wiper system?
i'm too sexy for RWD
2000 ducati 748 45k miles
2004 jeep grand Cherokee overland
1994 Mercedes e320
speedn_j is offline   Reply With Quote
Old 01-09-2018, 09:03 PM   #2
Yes 140's had solid actuation arms till 73 when they went to that cable crap.
Old 01-09-2018, 09:15 PM   #3
speedn_j
speedn_j's Avatar
Transferable to the 240s?
Old 01-09-2018, 09:21 PM   #4
No everything's in a different place, you'd have to swap the cowl.
Old 01-09-2018, 10:08 PM   #5
Can play the blues
Be sure the cables are well lubed and the tension on the wrap isn't too tight but not too loose. It is a crappy way to have the wipers work. But if you keep it lubed you'll probably never have a problem.
Old 01-09-2018, 10:15 PM   #6
Lando
Arthur Digby Sellers
Lando's Avatar
Are they really that bad? I've never had a problem with 240 wiper linkage.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is online now   Reply With Quote
Old 01-09-2018, 10:24 PM   #7
Eleven
Eleven's Avatar
^...yet
'76 245DL 240k miles
‘77 242DL 89k miles
'90 240DL 360k miles
Eleven is online now   Reply With Quote
Old 01-09-2018, 10:36 PM   #8
Can play the blues
To me they are more of a pain than the heater fan if you need to service it. Wrapping those cables around the cam can get very frustrating.
For service tools a small 8mm ratcheting box wrench and a small slotted screwdriver will help you tighten the nut on the end of the cable without twisting the cable and making it come off the moving slotted thing. You have to also remove enough dash stuff to get both hands in there.
It is also good to take off the wiper arms once in awhile and shoot some lube down the shaft. Something like Wurth HHS K will seep in there and leave grease where it is needed. Just be sure to use paper towels or rags so you don't get that stuff anywhere else.
Old 01-09-2018, 10:58 PM   #9
Lando
Lando's Avatar
You just scared me into giving them a squirt.
Old 01-09-2018, 11:10 PM   #10
speedn_j
speedn_j's Avatar
I bought the car with one of the cams broke off. Huge pain in the ass to put it together and working properly. I thought I had it solved now I have to do it all over
Old 01-10-2018, 12:04 AM   #11
Rebuilt mine per cleanflametrap's tutorial with some JY dust /hat seals since they're NLA and the goose grease caused the cam to fall off of the post ... twice ... second time I had to accurately clean the splines and tap it back together with red loctite.
So far so good.
Old 01-10-2018, 09:55 PM   #12
1971Gold142
1971Gold142's Avatar
This is pretty much why I sold my 242 Ti many years ago after tearing into the dash multiple times trying to fix that same issue.
71' 142E
1971Gold142 is offline   Reply With Quote
Old 01-11-2018, 08:05 PM   #13
Can play the blues
On my wagon a few years ago. I figured the cable came off on the right wiper. When I went to check it out. the whole cam thing for the cable had come off the wiper shaft. I pressed it back on but there was no way I wanted to trust it. Found one in the parts stash and its been ok since then.
Hey they fixed it with the 760/740.
Old 01-12-2018, 03:34 AM   #14
quillc
yv1a.com
quillc's Avatar
Had the same experience. Put the cam back on with blue Loctite.
I snug up the cables when get in there for any reason. No issues since (fingers crossed).
Chris
www.yv1a.com
Old 01-12-2018, 12:11 PM   #15
Mr. V
Mr. V's Avatar
A cam fell off on the wiper shaft of my 244; I successfully repaired it by reattaching it with JB Weld.
Old 01-14-2018, 10:37 PM   #16
LC4CARL
Aero challenged
LC4CARL's Avatar
Swapped the M for an A and my wipers are faster.
Life begins at 10PSI.
