Old 01-09-2018, 09:11 PM   #1
R3LLI1
R3LLI1's Avatar
Question Volvo 122 Brake Rotor Alternatives?
Hello all,
So my 1967 122s coupe needs new rotors and pads. Iv'e seen IPD's brake disc assembly but it's a little expensive at $219.00 a pop. Also Iv'e looked on skandix and just the rotor cost $70.00 + $50.00 shipping from Poland. Is there any cheaper solution?
R3LLI1 is offline   Reply With Quote
Old 01-09-2018, 09:28 PM   #2
JohnMc
JohnMc's Avatar
Last time I messed with my PV's front brakes (122 discs) I found it very hard to find calipers, and although I didn't need rotors those were very spendy as well.
I recall someone on Brickboard making up some adapters to bolt ABS 240 front calipers to the 122 mounts and use them with some Rover discs, but I really don't recall the details or how much work it took (outside of the adapters themselves). But vented rotors would be a nice addition.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-09-2018, 09:35 PM   #3
R3LLI1
R3LLI1's Avatar
I remember I saw this and ended up remaking the part in solid works and 3d printing it, but I looking for something a bit easier to piece together.
Old 01-09-2018, 09:40 PM   #4
VP has an alternative that's under $100 and they ship from a warehouse in the US.
http://212.247.61.152/us/main.aspx?p...e&artno=666525
Old 01-09-2018, 10:02 PM   #5
Can play the blues
122 type rotors used to come with the wheel studs in them already. So they were already expensive back when I bought them.
Looking at that part listing above it includes the wheel studs and hub with the rotor like always for less than $100. That's the deal there.
Old 01-10-2018, 01:32 AM   #6
LloydDobler
LloydDobler's Avatar
Have you measured the rotors to be sure they can't just be re-surfaced? These rotors are much harder than modern rotors and last forever if you start with a good surface and take care of them.
'66 122 - Collectible project
Old 01-10-2018, 10:50 AM   #7
matt b
I bought a set for the car I currently drive and they're every bit as good as the original ones. I highly doubt anyone will be able to tell the difference between those and the originals when it comes to wear, weight, etc....
I had the original ones turned and sold them with another Amazon, they were fine too.
Old 01-11-2018, 10:18 PM   #8
R3LLI1
R3LLI1's Avatar
Unfortunately no one resurfaces rotors in my entire state
Old 01-11-2018, 10:21 PM   #9
cwdodson88
No way. Almost all Advanced auto parts, NAPA, or any machine shop can do it. It’s not rocket surgery.
The Build Thread
SVEA - PUSHROD TURBO!
Old 01-12-2018, 11:40 AM   #10
matt b
Wow, that's a shame. Here, even local tire shops still offer it. $20 and you're done for a set of rotors.
