Old 01-10-2018, 02:44 PM   #1
hikerguy
hikerguy's Avatar
Default 960 electrical gremlins
My 1995 960 wagon is giving me trouble. It started with a sporadic speedo, dropping out at speed. This problem was temporarily fixed with a good smack on top of the dash but if I wasn't paying attention it went into limp home. 6 months down the road the speedo just stopped altogether and full time limp.
I pulled the cluster and dropped it off with a friend who owns a computer shop. Unfortunately, my 193 mile daily commute didn't stop while the cluster was out. After 3 days I started getting a dead battery. So I parked it for 3 weeks. My buddy couldn't find any problems except for the outside temp sensor is dead. So I reinstalled it and charged the battery.
Now the radio is cutting out and the fuel pump runs all the time no matter what position the key is in except full off. I know its timed to prime the system but not, always on right? Should I be looking for cluster issues or ignition issues or bad ground/diode? In the past I have had no start problems related to park switch but I don't think this is connected.
I love this car and am quite proud of all the miles I've personally put on the car but I'm getting close to putting it out to pasture. So any help here is appreciated.
+1/2 million miles of white block sitting in the drive way
hikerguy is offline   Reply With Quote
Old 01-10-2018, 03:35 PM   #2
EivlEvo
I can't help as I'm not a 9 guy but the fuel pump should definitely not be always on and in fact, if it's running without moving fuel you're going to get pump cavitation and it's going to burn itself out. I might as an abundance of caution move the car to a spot where god forbid... if it caught fire, the property damage would be minimized.
Old 01-10-2018, 03:40 PM   #3
hikerguy
hikerguy's Avatar
it should be dumping the fuel past the pressure regulator back to the tank, but good call on the potential fire hazard time to park it on the steet lol
Old 01-10-2018, 03:48 PM   #4
bobxyz
bobxyz's Avatar
Is a 95 960 LH2.4 or Motronic?
...my 193 mile daily commute didn't stop while the cluster was out. After 3 days I started getting a dead battery.
That's because you need the Alternator warning light (and all the other bulbs that light up with key on but before starting) -- the current that lights up the bulbs comes from the field coil on the alternator and magnetizes it so that the alternator work. No cluster, no bulbs, no current in field coil, no alternator output.
The fuel pump will just circulate gas as normal, with no additional risk of fire unless you're upside down with a broken fuel line after a crash.
Old 01-10-2018, 03:53 PM   #5
hikerguy
hikerguy's Avatar
me1.8 that explains the dead battery
Old 01-10-2018, 03:58 PM   #6
bobxyz
bobxyz's Avatar
I don't know anything about Motronic. If it's easy, I'd pull the console again and see if it goes back to working. If so, look carefully for something shorting out behind the console when console is installed or a mis-connected cable on back of console.
Old 01-10-2018, 04:15 PM   #7
care to explain? does m1.8 drain batteries?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-10-2018, 04:27 PM   #8
It could be a bad ground and the voltage is backfeeding thru the fuel pump relay. Or maybe not.
This could take even a pro a few hours to figure out. I would start with a wiring diagram, or even just start with the fuse panel, and pull fuses one at a time until your fuel pump stops running and then start diagnosing that circuit. You may find an unrelated circuit is causing issues in the fuel pump circuit.
Disconnect the battery while it's parked until you figure it out. Derp.
Old 01-10-2018, 05:55 PM   #9
hikerguy
hikerguy's Avatar
the reason for the dead battery
I guess its time to start looking for the green book pdf again.
