Old 01-11-2018, 01:14 AM   #1
82GLT
82GLT's Avatar
Default Water Pump Leak/ what's this hole for??
So I recently fixed a coolant leak coming from the right of my water pump, was missing a bolt. and now its leaking out of this hole on the bottom side of the pump? it was Mfg. into the pump so it belongs but why is it leaking and whats it for?
Thanks!
https://imgur.com/a/0gM3d
82GLT is offline   Reply With Quote
Old 01-11-2018, 02:06 AM   #2
Mr. V
Mr. V's Avatar
Time to replace the pump.
When coolant comes out of that hole you know the pump is shot.
Old 01-11-2018, 02:08 AM   #3
dytha99
Thanks!
I believe that's the "weep hole"... designed to leak when the pump starts to fail.
Posted via Mobile Device
dytha99 is offline   Reply With Quote
Old 01-11-2018, 02:57 AM   #4
82GLT
82GLT's Avatar
oh god don't say that first the fuel pump now this
Old 01-11-2018, 10:09 AM   #5
KeizerBrickGuy
KeizerBrickGuy's Avatar
Water pumps are far more simple and less expensive to replace than either fuel pump on these cars. Might as well do a complete coolant flush before you do with a new thermostat and hoses. A Gates WP on RockAuto is $20. All said and done with new coolant, you could do it all for around $60. If you feel like making a scenic drive down to the Valley, I can help you do it all.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 01-11-2018, 10:18 AM   #6
centason
Wine enemas for all
centason's Avatar
HEPU pump and Volvo seals. Just do it and be done.
Member: TBCCS
Death to all who stand in the way of obtaining the freedom of working people!
Just remember this guys. Im related to cocaine.
they were pushing sloppy poo up a steep hill with a pointy stick.
Any forums history.
Old 01-11-2018, 11:06 AM   #7
Do NOT put a cheap auto parts store one on there. My oreilly $35 lifetime warranty pumps failed three times in a row, quickly. My Hepu is going strong. Be prepared for a rusty coolant pipe which may have to be replaced.
Old 01-11-2018, 11:31 AM   #8
PromiseRing
We don't even like Volvos
BS, a main fuel pump takes like 20 minutes and you don’t have to drain all the coolant. Lol
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
Past
-80' 242gt m46-
spill it MClovin and WTF happens to your glasses you piece of ****..
Feedback Thread
Old 01-11-2018, 12:32 PM   #9
82GLT
82GLT's Avatar
I know its fairly easy, I already have the car mostly apart to do it since I had an oil leak to fix coming from the oil cooler feeds off the filter base plate
Old 01-11-2018, 01:29 PM   #10
TWD
TWD's Avatar
+1 In spite of the extra cost, I used a made in the U.K. Volvo pump on my '88 244. In a year the hub separated from the shaft. On went a Hepu with Volvo gaskets. Three years later all is well.
TWD is offline   Reply With Quote
Old 01-11-2018, 08:40 PM   #11
smeha
Tranny Whisperer
smeha's Avatar
Napa water pump did 3-4 years and then leaked through the same hole.
My Feedback Thread
