Old 01-12-2018, 09:47 AM   #1
dytha99
Default Snap crackle pop BOOM
'92 940 na Regina, 345k
No exhaust system from the cat back.
No signal from o2 sensor.
Car runs rich.
Whenever I decelerate from any speed over 30mph I hear snap crackle pop boom until I hit 30mph and lower or until I give it some gas.
What is causing these noises?
Posted via Mobile Device
dytha99 is offline   Reply With Quote
Old 01-12-2018, 09:58 AM   #2
vwblue1967
vwblue1967's Avatar
Pretty sure its not having an exhaust.
85 245 - ipd sport springs and sway bars yoshifab torque rods, kaplhenke bne strut mounts and TAB's. Poly bushings Bilstein tourings. B cam +4. 2.25 exhaust.
93 244 stockish.
vwblue1967 is offline   Reply With Quote
Old 01-12-2018, 10:22 AM   #3
esmth
dirty swede
esmth's Avatar
Even with a working o2 sensor you'll hear a ton of that with an open downpipe
you're also cooking the cat running it like that!
1991 244 LH2.4 m46 293k miles with B cam advanced 4*, 935 fuel & 146 ezk, pink injectors, 2.5" exhaust w/ magnaflow straight-through & some kaplhenke suspension goodies
esmth is online now   Reply With Quote
Old 01-12-2018, 11:22 AM   #4
EivlEvo
Here is a video of my stock 87 244 with a busted exhaust just after the cat (which was probably completely destroyed).
This is just a vid of my drive home from work one day so nothing crazy, but you can definitely see the fireballs if you watch for the flashes (easier to see towards the end maybe).
This vid is queued up. You'll see one at 3:44 and 3:54 and 4:05 etc etc etc
https://youtu.be/W6kz79Hdaeg?t=3m34s
There's a good over-run of the popping when I get off the highway at 13 mins.
Best one at 13:20
Old 01-12-2018, 12:11 PM   #5
Dirty Rick
Dirty Rick's Avatar
It is normal for a motor to cackle, fart, pop, bang, bark, even emit flame, on decell, especially without a baffle.
Overfueling or misfiring WILL overheat the cat to the point of destruction.
Old 01-13-2018, 12:12 AM   #6
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
This is only normal on cars with carbs and high strung efi cars. Very few of the users here have cars high strung enough that they pop and spit fire normally (open headers/downpipes not included). That takes compression and cam overlap. Not factory stuff. If yours does it it is because it is running like crap.
The function of the o2 sensor is to tell the ecu whether the mixture is right. Without one you are dumping fuel into the exhaust which is exploding and popping. You are also likely running lean at times as well. O2 sensor delete will not make power, only rob it. The ecu needs to know how much fuel it needs to squirt to work properly. Put the o2 back and get working on ecu upgrades.
1982 GLT 244 redwood metallic, turbo, lowered...RIP
Colonel Mustard: 1979 242DL, B21A, SU carb, M45, GT sways, Limited-slip, rad hubcaps, Manual rack, no ac e-fan
Originally Posted by NativeJesus View Post
This isn't even a trailer park suspension.
Old 01-15-2018, 10:40 AM   #7
dytha99
Thanks. The o2 has not been deleted. However I'm going to replace it and have the exhaust kit that i put on welded up.
