![]() I noticed it when it started snowing but there's a hot spot on my roof where the overhead light is. the thing is, i never turn it on, it's not set to go on with the door. there's no reason it should be making a hot spot.
anyone have any ideas?
Religious people scare me. |
![]() It's not making a hot spot. It's because there is a different rate of heat transfer there. Air is an insulator and you have a plastic thing right there. So the air effectively stays warmer for a longer period of time there than the headliner.
dirty swede
![]() dvom @ the fuse and see if its using any current
1991 244 +T LH2.4 m46 285k miles with B cam advanced 4*, 962 fuel & 148 ezk, T5 white injectors, 2.5" exhaust w/ magnaflow straight-through & some kaplhenke suspension goodies |
#4 |
![]() Replace the bulb with LED's.
![]() 1982 Volvo 245 with a Ford 302 V8 Ford V8 Conversion Manual - http://forums.turbobricks.com/showthread.php?t=250257 Bertone Restoration - http://forums.turbobricks.com/showthread.php?t=256460 |
#5 |
#6 |
![]() so everyone's 240 does this?
#7 |
![]() It's a feature in every 200.
444 -55, 145 Express -71, 242 DL -80 (was 4.6l), 245 -88 "B6284T", 245 -90 "B6284T", V90 -98 4.6l |
#8 |
![]() Mine did it this mourning with a light cover of snow on the roof, all you need is a slight temp difference as the light is close to the sheet metal.
#9 |
![]() So the light never ever ever turns on?
'99 V70 NAA - So Slow '04 V70 T5A - Feels Fast |
#10 |
![]() I'm not trying to be rude... are you new to winter?
You're basically getting something like this occurring. Thin metal has a faster heat transfer than metal with air trapped in it. So you'll get shapes like this on your hood dome light... anywhere there's trapped air. ![]() That said, by all means check it to be sure you won't die in a fire but like... physics anat. |
