Old 01-09-2006, 08:59 AM   #1
igiveup
Question shift linkage bushing on a 740 turbo at 1990 wagon
I posted earlier about my car not moving. I put the front up on ramps enough to crawl under it. The shift linkage is loose but not gone or detached. All the bushings seem to be gone. How do I replace the bushings? Anyone in VA know where I can find the bushings? Once I replace the bushings will that tighten it up? Or is there something else I need to look at? It is so loose that it really wiggles bad and there is no way that it is telling the car anything to do. I need all the advice I can get, I really need my car back to working. My husband is no help on this matter, so step by step insturctions is best. Thanks so much for the advice from before and thanks in advance for any and all advice this time.
Thanks
Janet
igiveup is offline   Reply With Quote
Old 01-09-2006, 01:30 PM   #2
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
New bushings can be found a the Volvo dealer, FCPgroton.com, IPDusa.com et cetera. I'll be replacing the ones on my '94 shortly, and it only just turned 61k miles.
Instructions:
http://www.brickboard.com/FAQ/700-90...ifter_Is_Loose
For reference, this is what they look like:
http://img.eautopartscatalog.com/live/J407025165OES.JPG
Three Fat Tigers is offline   Reply With Quote
Old 01-09-2006, 02:31 PM   #3
gsellstr
gsellstr's Avatar
Auto or manual??
Just replaced em on my 90 740T, a/t and they ran about $4each. The new ones are graphite impregnated instead of just plastic or nylon. Takes about 10 minutes to do all of em. Sure makes the shifter feel more solid.
RIP
74 144 B20
90 745Ti
Old 01-09-2006, 03:03 PM   #4
igiveup
Thanks for the advice. I had to order them from Omni parts in Roanoke VA. They will be here tomorrow. Cost me $6.00 to get 4 of them. Cheapest part for my car yet. I just hope this is my problem.
Thanks
Old 01-09-2006, 04:07 PM   #5
Three Fat Tigers
Where did you find those?
Old 01-09-2006, 04:21 PM   #6
gsellstr
gsellstr's Avatar
Dealer. Should have the p/n at home if you need it. They just looked it up though, and that's the normal replacement part.
Old 01-09-2006, 04:21 PM   #7
blu92in99
I hate you all, equally
blu92in99's Avatar
Dealership IIRC.
EDIT// Heh, beat me to it by a few seconds.
-Justin
-Justin
blu92in99 is offline   Reply With Quote
Old 01-09-2006, 06:26 PM   #8
igiveup
I am getting my part from Omni Import Parts or Woods Auto Parts in Roanoke VA there address is 807 Hardy Road Vinton phone number is 540-982-6664. They can usually get what I need faster than the dealership and cheaper. When I had to replace the MAF Sensor Hose that also has a sensor in it they were a lot cheaper than the dealership and they usually order it for next day delivery.
Old 12-06-2009, 12:23 AM   #9
brickyard92
Regular Contributor
brickyard92's Avatar
Default shift linkage bushings 92 740t
hey guys i was trying to replace shift link bushing on my tranny .i cant seem to figure out how to install them . it seems as if they are to thick i took the linkage a part which is very easy but i cant see how a bushing can go on there ...help me please this rattling is driving me crazy.1992 740t volvo 320000 miles mint cond except for the noise lol.
brickyard92 is offline   Reply With Quote
Old 12-06-2009, 12:27 AM   #10
brickyard92
Regular Contributor
Default did you put the bushings on between the washer and the c -clip?
Originally Posted by gsellstr View Post
Auto or manual??
Old 01-10-2018, 06:38 PM   #11
PromiseRing
We don't even like Volvos
This is the hardest thing I’ve ever done in my life. Just broke 2 bushings in a row and now i get to wait 2 weeks with a piece of **** shifter. ****ing bull****. Let them sit in hot water and lubed everything. Still won’t go in.
I’m having a somewhat difficult time installing these bushings. I accidentally broke some but I’m sure that if I am patient I will be able to get the next set in easily.
Current
-93' 244 m47-iPd sways, 13c, iPd cam, 2.5Ē
straight pipe
-93' 245 m47-iPd sways, B-cam
-94' M-Edition Miata-Stock with a hardtop
Past
-80' 242gt m46-
spill it MClovin and WTF happens to your glasses you piece of ****..
Feedback Thread
Old 01-10-2018, 07:11 PM   #12
oldnfast
Did you use Volvo or aftermarket?
oldnfast is offline   Reply With Quote
Old 01-10-2018, 08:19 PM   #13
PromiseRing
Aftermarket. I was told they would be okay. I was having difficulty spending $10 on a little piece of plastic.
I know the aftermarket ones will work since i got one in.
Old 01-10-2018, 08:42 PM   #14
planetman
planetman's Avatar
I like to warm those bushings before installing them, so put them in your pocket to warm them up to body temperature or if you are in a hurry, soak them in hot tap water to make them more pliable.
Eric
Torrance, CA 90502
planetman is online now   Reply With Quote
Old 01-10-2018, 08:48 PM   #15
PromiseRing
I put them in boiling water lol. Idk, maybe i could try a different way of installing them next time. I was using pliers to squeeze them into the linkage but Iím sure thatís not the best way. When it was partially in i tried to push in with a screwdriver and the screwdriver poked through the bushing. I let it cool a bit before using the screwdriver because obviously if itís too soft itíll poke through easier.
I got 1.5 bushings in as well as the single black bushing up top. Itís already infinitely better.
Old 01-10-2018, 09:06 PM   #16
oldnfast
I know what you mean,that's why I asked,I have to do mine and was wondering if I should pay up for oem.its my first time doing them.
