Old 05-19-2017, 05:55 PM   #1
intothelabyrinth
intothelabyrinth's Avatar
Default Aftermarket Overdrive Solenoid
Anybody ever gotten an overdrive solenoid for the auto trans and it only has one hole? This one I got has the hole in the center smaller o-ring, but not the bigger hole inside of the big o-ring. I don't think this thing will work. The damn ebay listing photo shows it with 2 holes as normal, the thing looks like it will fit, but I don't even really see what it would do.
intothelabyrinth is offline   Reply With Quote
Old 05-19-2017, 06:13 PM   #2
KeizerBrickGuy
KeizerBrickGuy's Avatar
Bummer drag, dude...it won't work then. You'll never see OD with just one hole. Return it quick and get your money back and then go to Amazon or ipd...
https://www.amazon.com/Kaehler-W0133...drive+solenoid
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 05-20-2017, 05:05 PM   #3
intothelabyrinth
Damn so 106$$ is the going rate? The one I got was $30... Crap.
Old 05-20-2017, 05:35 PM   #4
lummert
lummert's Avatar
Exchange for another. Use the power of complaint.
Old 05-20-2017, 09:03 PM   #5
intothelabyrinth
It's weird, like it just has to be a defect, otherwise it's a pointless apparatus.
Old 05-20-2017, 09:44 PM   #6
AndrewNance
Amateur hour!
AndrewNance's Avatar
If you're looking for cheap/free, just bypass the solenoid. The only thing you lose is the ability to lock out OD.
'71 142
'80 245
Feedback
Old 05-20-2017, 09:55 PM   #7
One hundred gift baskets
^ this, I just took a drill and made a little path to let the oil flow between the holes
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 05-22-2017, 10:00 AM   #8
intothelabyrinth
I know, I just like being able to turn it off when I tow something.
Old 05-22-2017, 10:48 AM   #9
KeizerBrickGuy
I'm in the same boat with needing the OD switch. Take your chances exchanging it for another one, or get your money back and go to another vendor.
Old 05-22-2017, 11:33 AM   #10
intothelabyrinth
That's the plan... I'll def leave a review on this thing if it is not resolved. I'm pissed that it is going to take this long, although it isn't the biggest deal in the world! I'll let you guys know how it turned out. Look at this stupid ****!
Old 05-22-2017, 11:39 AM   #11
cleanflametrap
cleanflametrap's Avatar
Until you put the picture in the thread I figured it was just another application list error.
Crazy indeed! If they're not trying to dump mfg. mistakes, I'm baffled.
-Art
Old 05-22-2017, 11:41 AM   #12
KeizerBrickGuy
Whats the name of the vendor/mfg? That way we can all know the name and stay away.
Old 05-22-2017, 11:59 AM   #13
cleanflametrap
Then again, it could be a small-quantity defect, and they'll make it right, with apologies.
Old 05-22-2017, 12:03 PM   #14
intothelabyrinth
That is what I'm hoping for, I feel like I might could just drill it and make it work but I don't really want to do that. The actual solenoid works fine, it is just missing a hole! The seller is bavarianmotorpart on ebay. There is also another listing that is almost the same from a different seller, and they both have the same 4 reviews... hmmm fishy.
Old 05-22-2017, 12:07 PM   #15
intothelabyrinth
I'm just so glad I didn't get the car tore apart before noticing, or god forbid, actually install this thing!
Old 05-22-2017, 12:45 PM   #16
KeizerBrickGuy
I'm just so glad I didn't actually install this thing!
It's always good to inspect your parts before you install them. It can save for a lot of heartache. Good save. Hope to hear you get it back to normal soon!
Old 05-22-2017, 12:59 PM   #17
James10952001
That *has* to be a mistake. Drill bit probably broke in the machine and nobody noticed until after that one got through. It's not like it could even work in a different car, there's no way that solenoid can do anything.
James10952001 is offline   Reply With Quote
Old 05-22-2017, 03:25 PM   #18
intothelabyrinth
They just told me I would "have to send the item back first", before they would send out another one. I'm going to do everything I can to pull the plug on the paypal funds.
Old 05-22-2017, 03:27 PM   #19
You get what you pay for.
how psi stock can support?
Old 05-22-2017, 03:34 PM   #20
cleanflametrap
If the photo you took isn't enough for them, make sure they understand you've already published it and the name behind it; they'd probably enjoy better sales with a positive review.
Old 05-22-2017, 03:38 PM   #21
KeizerBrickGuy
Yup. I strongly agree with this.
Old 05-22-2017, 03:43 PM   #22
intothelabyrinth
I let them know, I have a feeling they are just going to ignore me. In which case I'll go ahead and order another part and try to get ebay to step in for the refund.
Old 05-22-2017, 03:43 PM   #23
It's an MTC part. What do you expect?
Old 05-22-2017, 03:44 PM   #24
intothelabyrinth
I have to believe this is a rare thing though, seems like there would be some word about it on the internet somewhere since they have sold like 259 of them.
Old 05-22-2017, 03:46 PM   #25
It's probably just a fluke, but it goes to show that their quality control sucks.
