Old 01-12-2018, 04:27 PM   #1
sclay
Default Excessive crankcase pressure, all PCV parts check out okay...
Hey gang, before I throw the towel in and just plumb up an evilBay el cheapo catch can, could one of you fine folks see if there is something I am overlooking?
92 745, Turbo
Oil separator is clear (removed it, flows freely)
All lines are clear (also removed them, including the elbow and small line to the intake manifold, all clear)
Heater on intake tube is clear and unblocked
I did the "oil cap test" and the little dude just dances on the valve cover if he isn't latched down. It's a plastic cap from what I imagine is a later model Volvo. Maybe I did this wrong, but either way, that doesn't seem right.
Compression test yields 170-150-170-170 from 1-4. I don't have the tools for a leak down test.
Any idea what's going on? It sounds like plenty of folks have "had it" with the factory system and defaulted to a catch can setup, but I really dislike thinking that everything is working correctly and the system is still not operating as intended.
If anyone has any other ideas, or can see something I missed, or just needs to tell me to do a leak down test I'd greatly appreciate it. But this seems like a great deal of pressure, and it sure seems like my seals aren't into it.
Thanks
sclay is offline   Reply With Quote
Old 01-12-2018, 04:32 PM   #2
cwdodson88
latex glove test, less chance of the cap dancing due to engine vibration. if it fills up, bad, if it sucks in, good.
The Build Thread
SVEA - PUSHROD TURBO!
Old 01-12-2018, 04:37 PM   #3
PCH
So are you popping the seals out or what is the problem exactly?
Static compression test may show good readings while the rings are shot and cylinder walls have oil on them. Seen it before. You may have a lot of blow-by under boost and stock 3/4 inch nipple on the turbo intake just can't flow that out of the case.
Old 01-12-2018, 05:41 PM   #4
Can play the blues
Did you check the oil drainback pipe under the oil separator box? That is what is clogged on my 93 n/a wagon. There was no unclogging it for me so I did something else as shown in the pcv mod thread.
http://forums.turbobricks.com/showthread.php?t=338673
You could probably use the oil cap or add a fitting to vent the valve cover to a catch can then from there to the turbo intake hose.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
Old 01-12-2018, 06:33 PM   #5
lummert
lummert's Avatar
What about the one cylinder with lower compression?
Old 01-12-2018, 08:31 PM   #6
sclay
I did not! Thanks for pointing that out. I'll have to give it a look. I think general practice is to check on the tube for clogs right before changing oil? To prevent any gunk from making it's way through the system?
As for the one lower cylinder, I feel as if that should be within an acceptable tolerance, but someone who knows these engines a bit better maybe should clarify that. I can't be sure. The engine runs well.
I did the glove test, as best I can describe it, it doesn't "inflate" so to speak, but more like "flutter", sort of if you filled a balloon and then let the air out of the fill neck in one go. It certainly isn't pulling the glove down with any constant authority, and isn't filling it either. Pretty erratic.
As for which problem I am trying to solve, when I purchased the car, it appeared to have several oil seepage/leak issues for quite some time, and someone had been in there to mess with the oil box. As I know they can be a little bit of a problem child, I want to try and wrap my head around it's function and do my best to make sure it is operating as it should before putting the car in regular family service. Currently, I'd say at least the cam seal and distributor seal are having issues holding oil back, other areas I am still waiting to see what seeps out.
Thanks for the advice so far everyone!
