Old 01-12-2018, 10:09 PM   #1
vwbusman66
vwbusman66's Avatar
Default N/a 240 exhaust options
So I've made the decision to stay N/A with the 244 for the foreseeable future. I would like to replace the entire exhaust system and plan on deleting the cat.
What is the best size to use with the stock "downpipe"? I'm running a K cam with an adjustable gear but have an m46, so peaky power isn't a concern.
Has anybody used one long or two shorter glass pack (cherry bomb) in the position of the resonator (1st muffler) and just run a straight pipe all the way back and out the passenger side?
I like the idea and am open to something a little obnoxious, I just don't want a straight pipe and would like to have some hearing remaining in 5 years.
(Yes, I do plan on being lazy and going under the axle)
James
1972 145S- B20/M40
"Some men are born mediocre, some men achieve mediocrity, and some men have mediocrity thrust upon them.”- Joseph Heller
Originally Posted by The Full Banana View Post
Wow, that is quite the blank slate. John Locke would be proud.
Old 01-12-2018, 10:16 PM   #2
Cwazywazy
Cwazywazy's Avatar
Delete the resonator for a bit more grumble. I'm not sure there's any benefit to a fatter exhaust on an n/a.
I don't know what I have
Old 01-12-2018, 10:23 PM   #3
vwbusman66
vwbusman66's Avatar
In that case, what is the outlet size of the downpipe? I'll just use whatever size that is and throw a few cherry bombs in it. My current system is completely trashed.
Old 01-12-2018, 10:41 PM   #4
white855T
You can get the ipd sport exhaust. It's 2 1/4 piping. It's basically the stock exhaust system minus the smaller muffler and slightly bigger pipes.(stock being 2 inch pipe)
Buyer/Seller Feedback
Old 01-12-2018, 11:28 PM   #5
Mojo Stealer
I have the above exhaust cat back with a cherry bomb welded in place of the stock muffler, no resonator for sale, just need to make/get a cat delete pipe. It sounded great with the turbo, it will be louder n/a.
Old 01-13-2018, 12:13 AM   #6
vwbusman66
vwbusman66's Avatar
Can I just use a piece of 2" pipe to replace the cat then?
Old 01-13-2018, 12:22 AM   #7
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
They call that a "test pipe"....as in.."Its only there for testing, of course I'm going to install the cat when fedex finally ships it".......
Old 01-13-2018, 01:01 AM   #8
EivlEvo
Deleting the cat is pointless for performance on an NA. May as well put one on there to not have to deal with the hassle. FWIW the Evo 8 and 9 actually put more power down with the stupid cat than without.
Regardless, for NA go for sound. I'd run straight pipe with just the cat were it me. But I like the way the stupid tractor motor sounds on song.
Old 01-13-2018, 01:12 AM   #9
white855T
Yeah, that works.
Old 01-13-2018, 03:00 AM   #10
Mojo Stealer
It's 60mm ~2-3/8", maybe hit the jy and saw off a short piece or you can bodge 2-1/4" in there.
Old 01-13-2018, 09:23 AM   #11
vwbusman66
vwbusman66's Avatar
But Maryland doesn't inspect any car registered as historic
Old 01-13-2018, 04:04 PM   #12
vwbusman66
vwbusman66's Avatar
You wouldn't happen to have any sound clips would you? The only ones I can find are ghetto style with a pipe folded up at the end.
Old 01-13-2018, 09:57 PM   #13
EivlEvo
As I just posted in another thread. This is my car effectively straight piped. The pipe broke before the cat. It spits fire and backfires and the whole 9. (This is just me driving home from work 1 day so click around for various audio. I didn't spare the redline.
https://youtu.be/W6kz79Hdaeg?t=1m34s
It's too loud with just a straight pipe, but with the resonance of a cat and... you know, the rest of the dang pipe going to the back it'll be just fine.
My Saab 900 classic just lost it's rear muffler this summer and were it not the wifes car, that would've gotten the muffler delete as well.
You can ALSO find on my pointless youtube channel my 245 with side exit with muffler AND cat. It's fine, but too quiet.
Old 01-13-2018, 10:34 PM   #14
Can play the blues
When younger I liked loud. But I learned you can have enough sound out the back without beating yourself up inside. Of course everyone has their own like of how much sound that is. I suggest at least one good sized muffer like a 24" long one and a resonated tip for some smoothness.
With only one muffler with these engines. You can get a lot of exhaust resonance between 2-3k rpms. With a resonator tip or resonator muffler added you smooth that out. Without losing any of the over all sound of your choice.
Basically, in my experience with aftermarket mufflers.
Loudest and lowest build quality=Flowmaster
Dynomax and Magnaflow have both served me well with good sounds and build quality.
Old 01-13-2018, 10:39 PM   #15
Mojo Stealer
On my phone so I can't embed, but this is the above exhaust with a 740T magnaflow car inline. https://m.youtube.com/watch?v=qzLHyCuB_4M
Old 01-13-2018, 10:47 PM   #16
NA exhaust is 2".
Old 01-13-2018, 10:56 PM   #17
vwbusman66
vwbusman66's Avatar
I was thinking something along what you describe. I want something I can hear but I really would rather not deal with a noise ordinance or a friend who can't hear anything.
Old 01-13-2018, 11:02 PM   #18
Can play the blues
I started with VWs and still like them very much. I used the Type I glasspack headers then went to the flatpack muffler ones. They were still good sounds but didn't hammer me like the glasspack headers did.
I really wish I would have bought that notchback Type 3 back when they were just an oddball VW. Sigh...it was a blue German market import back in the 80s. No rust in just good old car shape.
Old 01-13-2018, 11:28 PM   #19
Mojo Stealer
NA exhaust is 2".
Ipd N/A Starla sport exhaust is 60mm same as 740T.
Old 01-13-2018, 11:31 PM   #20
Ipd N/A Starla sport exhaust is 2 & 1/4" same as 740T.
ftfy
Old 01-13-2018, 11:39 PM   #21
Mojo Stealer
ftfy
That's funny I had to chop the ends of the bell on the Thrush 2-1/4" cherry bomb off because the 2-1/4" pipe sticking out was too small for the Starla pipe. I think you couldn't be more wronger. I bought the Starla around 2008, perhaps they've changed the specs since then in which case I'll admit you might be sort of right.
Old 01-14-2018, 11:38 AM   #22
towerymt
the real Towery
towerymt's Avatar
Early downpipe with the long secondaries, 2"-to-2.5" transition, 2.5" (4" x 9", I think) Magnaflow, 2.5" 45deg bend, 2.5" out the side. Flat torque from about 1900 to 4600 with a K cam and MS&S.
2006 was a good year
Zero tickets. One 1600 mile round trip to Alabama.
Old 01-14-2018, 01:39 PM   #23
Can play the blues
That should be in the snap crackle pop boom thread.
Old 01-14-2018, 11:45 PM   #24
vwbusman66
vwbusman66's Avatar
I like this setup a lot...
but WTF is MS&S? MegaSquirt & ???
Old 01-14-2018, 11:56 PM   #25
EivlEvo
^ Megasquirt.
You can also (as I mentioned) hear a side exit on my youtube channel. But that's with a cat AND a turbo (which is an excellent muffler). But side exit is great!
