wightghost
- Jan 13, 2008
- Brisbane, Australia
The odometer and trip meter (VDO speedometer) in my 90 740GL quit recently and I found the small 26 tooth gear was broken. I replaced both plastic gears and it worked for about 300 metres and quit again. Pulled it apart and found what looked like a couple of dodgy solder joints on the small circuit board for the motor that drives the gears. I resoldered them and everything else looked fine so put it back together and still no dice.
The speedo is working fine so I don't think it could be the diff sensor or wiring or could it? Are there any other possible causes? Is there a way of testing the trip meter motor out of the car?
Thanks for any input.
