Old 02-23-2021, 06:19 PM   #1
Stu
Stu's Avatar
Default GAZ Struts for a 240
https://yoshifab.com/store/240-front...t-inserts.html
Iíve done some research and havenít found much on these, and emailed YoshiFab but his inbox is full
So, has anyone had any experience with these GAZ strut inserts?
From what I can tell they appear to be a great product, but Iíd just like to see if anyone has any first hand experience with them.
Thanks!
Stu is offline   Reply With Quote
Old 02-23-2021, 06:23 PM   #2
They are great. You get to specify matching valving for the spring rate you want. Homer, The Full Banana, Mason and myself are running the Gold coilover strut and are all (well Homer, Mason and I at least...Tom has not driven them in anger yet IIRC) blown away at how smooth and well-controlled they are.
One note though: they are a twin tube design so they may overheat with heavy track use. I have been extremely happy with them all the same.
https://forums.turbobricks.com/showt...0&page=54#1339
Old 02-23-2021, 06:33 PM   #3
Texas240
Prius Owner
Texas240's Avatar
I have the single adjust gaz insert for my wagon F/R. Great quality product
93 245 LS Engine Swap Project
Old 02-23-2021, 06:44 PM   #4
Stu
Stu's Avatar
Thanks guys! I’ve been eyeing them for awhile now, though sadly not before I had already purchased some Bilstein shocks. Now I’m thinking I should probably just sell those and take a small loss, and buy some GAZ shocks as well as the struts.
Old 02-23-2021, 07:13 PM   #5
I would. The Bilsteins ride like garbage with anything other than factory rate spring rates and lengths.
Old 02-24-2021, 11:42 AM   #6
The Full Banana
not yet good enough
The Full Banana's Avatar
Do it. Anything else on a street car that you want to handle reasonably well is a waste of time or money.
-Tom 1980 242 T5
Old 02-24-2021, 05:04 PM   #7
Stu
Stu's Avatar
My mind has been swayed, it shall be done
