Old 08-22-2010, 01:45 PM   #451
Janspeed
the stock shifter gave very slick shift without any noticeable clicks
since i installed the avalange short throw speedshifter it is more of a clicking action. Still smooth though
Old 08-22-2010, 02:40 PM   #452
vanapeer
old fcuk
vanapeer's Avatar
Ayee I used my old short shifter from M46 which is some 1cm lengthened.
Did anyone start the engine when M90 installed but propshaft not? 1 and 2 were quiet, in third you can hear some and 4 made quite loud rattle. I take its normal domino effect of gears when they have no load.
Today had a longer testdrive. Damn. Something's grinding.
vanapeer is offline   Reply With Quote
Old 09-23-2010, 08:46 AM   #453
mark244turbo
mark244turbo's Avatar
Default M90 in 200 series in dutch
For all the people in Holland who want to put a M90 in a 240/260.
http://volvolvo.nl/forum/topic,3714.0/
mark244turbo is offline   Reply With Quote
Old 09-26-2010, 03:04 PM   #454
volvalover
Originally Posted by Benzine View Post
I'm using an M90 in my kit car. I'm using a non volvo m/c and I'm having trouble getting the clutch to work properly. Basically I have to have my foot right to the floor and then I can just about change gear, but it's hard. As i know flip all about hydraulic clutches, could this be a problem with the m/c not being big enough or a problem with the slave cylinder? It's a 3/4" m/c, I don't know what the m/c that came with the 960 was. There's no leaking fluid anywhere. I'm using an 850 clutch & flywheel. This is the kind of m/c i'm using, the .75 one
Any ideas on what I can do. FANX
is the master cyl. adjustable if so start with that before ya go adding shims
volvalover is offline   Reply With Quote
Old 12-26-2010, 01:53 PM   #455
Cojones
Cojones's Avatar
John did a small run - 3 pieces i think - of M90 short throw shifters. I just installed and tried it, and damn I like it. It has nothing to do with the M46 the car once came out of the factory with. It kind of reminds me of an MX5 i once drove. Clean, crisp, short throws. It does require some more force to shift gear compared to the original M90 shifter, but it's worth the extra effort.
S90 Executive
Cojones is offline   Reply With Quote
Old 12-26-2010, 06:58 PM   #456
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Absolutely right. The clevis on the master is adjustable, and will most likely need to be adjusted.
This threads remonds me I need to hit up John about a short shifter, or even just the bushings.
-Kenny
Old 08-07-2011, 05:27 PM   #457
pwaes
pwaes's Avatar
Did some thinking. (Ouch... that hurt )
Why not use an 850r clutch disc and pressure plate (240mm) and the stock dogdish (m4*) flywheel, machine flatten the dogdish flywheel and drill & tap 6 holes for the m8 screws? Then you have the dogdish with the 60-2 pattern for LH and a 850r clutch setup (240mm) for more clamping pressure? Do I need to make any modifications on the clutch fork ? Any thoughts about the height of the setup?
'88 740: '92 b230ft, 90+ manifold, ported/flowed 531, t04e turbo, siemens deka 630cc injectors, TLAO chips, full 3 inch, npr intercooler and more goodies
pwaes is offline   Reply With Quote
Old 08-08-2011, 03:26 AM   #458
Turbosteen
I was born at a young age
Turbosteen's Avatar
I wouldn't spend my money on having someone machining the stock flywheel, waste of money imho, and the result is to risky I think.
The TTV billet flywheel I have in the 760 is unbeatable in price/quality. I bet you that adapting the volvo dogdish is already pretty expensive and time consuming anyway.
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 08-08-2011, 03:48 AM   #459
pwaes
pwaes's Avatar
OK, did a little searching:
B230 Red Block 850R 'Lite'
Lightweight billet steel
Single piece design integral teeth
Suits standard 850R diameter clutch
Dynamically balanced
Weight: XXKg
Part number: 1090
Stockist: info@ttvracing.com
Is this the one you have?
Old 08-08-2011, 06:39 AM   #460
Turbosteen
Turbosteen's Avatar
Looks like the right one, don't know what part number it was but the description fits what I have (B230 + 850R PP)
see this post http://forums.turbobricks.com/showpo...&postcount=227
Looks a million times better than the volvo flywheel
Old 08-09-2011, 09:00 PM   #461
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
I don't think what you're suggesting would work anyway - I think the timing pattern is in the 'dished' section, so removing that to make a flat mating surface would remove the timing marks, or at least the bulk of them. I suspect that the mating surface on the TTV flywheel is actually further back than on the dished one...i.e. it's thicker as far as the mating surface, but without the dished section.
cheers
James
'13 V70 D4
'89 740 Turbo Intercooler
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'70 164 - Under Restoration
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 08-10-2011, 02:37 PM   #462
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
cheers
James
The trigger pattern is not on the dish section, but behind it.
Wagner is offline   Reply With Quote
Old 08-10-2011, 10:21 PM   #463
foggyjames
foggyjames's Avatar
I take it all back I've been looking at them recently (swapping a B200 in a 360 on Renix with a 44-4 or similar pattern to a B230FT on LH2.4), but my mind must have been playing tricks!
cheers
James
Old 01-10-2012, 01:33 PM   #464
volvoz2000
Default pics
Hi All,
the pics are missing at the sart of this topic in the instructions for welding up third gear synchro on M90, does anybody have another link or can repost pictures etc.....?
thanks
volvoz2000 is offline   Reply With Quote
Old 01-28-2012, 05:07 PM   #465
katluke
Originally Posted by volvoz2000 View Post
Hi All,
thanks
+ 1
1990 740 GLT Estate
katluke is offline   Reply With Quote
Old 02-17-2012, 04:48 PM   #466
Rust Reaper
Originally Posted by katluke View Post
+ 1
+2 The original pics would be a great help, as well as preserving the purpose of the post; people not asking random M90 questions when "it's been covered on this board in great depth"
Rust Reaper is offline   Reply With Quote
Old 02-17-2012, 07:45 PM   #467
Captain Bondo
I have this picture from when I did it. It's pretty much all you need. It doesn't make much sense out of context but once you pull the tailshaft housing off the trans it will. :
The only tricky part is you need a good 2 jaw puller to get the 4th gear assembly off.
Old 04-22-2012, 04:19 PM   #468
jonah
Pastafari !
jonah's Avatar
I'm just putting some new input and output seals in my M90 and decided to change the selector shaft seal too, but, I couldn't get it out, and as I didn't want to damage anything I decided to take the back cover off to make it easy.
So, can anyone recommend what sealant I should use to seal the two halves together again? And, what is the torque figure for the rear flange nut? Apologies if this has been covered somewhere in this thread.
Fear is your only God.
jonah is offline   Reply With Quote
Old 04-23-2012, 02:40 PM   #469
Captain Bondo
Reseal with anaerobic sealer. Dunno abut the flange - I would just put some loctite on it and crank it down. I would always just rattle it down with an impact.
Old 04-23-2012, 03:59 PM   #470
Homer
OEMplus++
Homer's Avatar
Rear flange nut is 115 ft/lbs based on the green/blue manual. (Or thereabouts, I don't have the manual in front of me)
-Jacob:
2017 allroad - Comfy DD
Old 04-23-2012, 05:59 PM   #471
jonah
Pastafari !
jonah's Avatar
Thank you gentlemen.
Old 06-07-2012, 05:50 PM   #472
luyopadre
hello, would somebody tell me why am I not able to see the pics about the welding of the M90 3rd syncro. I need to do it these days and I remember that there were also pics on the first page where the details are. But now I see only text without pics.
thx,
luyopadre is offline   Reply With Quote
Old 06-11-2012, 01:32 AM   #473
Captain Bondo
apparently pbase killed my account. Nice.
Old 06-11-2012, 02:07 PM   #474
Wagner
Wagner's Avatar
Here is a page from Bilport magazine from the year 2001 showing the ring you need to weld.
Old 06-12-2012, 06:23 PM   #475
luyopadre
thx, could you give me any more details, how to weld it, and if possible pictures, I'm not so familiar with swedish .
