Old 11-17-2013, 01:43 PM   #501
Turbosteen
I was born at a young age
Turbosteen's Avatar
I think I have a new LUK PP and disc lying around for M46 flywheel to work with M90 (diesel setup). Surprisingly, the PP and disc were stamped with Sachs brand and numbers, the box was LUK....
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 11-18-2013, 07:51 AM   #502
DET17
Reformed SAABaholic
Did you buy this setup new from LUK? Foggy James has confirmed that LUK brand is good quality hardware. Perhaps my coffee hasn't kicked in, when you say M46 do you mean the flat flywheel version, or the LH2.4 dogdish with the 60-2? I don't have much M46 experience other than helping my son put a clutch in his 81 244; as I understand it the early setup is 215mm and the later 228mm (dogdish).
Old 11-18-2013, 07:08 PM   #503
mark244turbo
mark244turbo's Avatar
The 940TDI clutch bolts right onto the M46 dogdish flywheel (60-2).
You can order the clutch from Sachs or buy a LUK clutch.
You will get the same parts, but the "LUK" parts are cheaper.
And yes the first (3.91) and second gear (2.2) are way to short for fast acceleration.
It's hard not to run into the rev-limiter in first gear when accelerating fast.
mark244turbo is offline   Reply With Quote
Old 11-18-2013, 07:20 PM   #504
mark244turbo
I want to install an M90 in my other volvo 740. Is there perhaps someone in the south of holland who has a LUK clutch and pressure plate for sale?
Old 11-19-2013, 05:04 PM   #505
DET17
Reformed SAABaholic
The LUK clutch kit is on order, so I hope you are correct about "same parts".
I think the first gear will be reserved for climbing the hill to my home....otherwise of little use. I expect I will be waiting for 2nd to apply the boost....and resisting the temptation to bang 3rd.
Old 11-23-2013, 08:43 AM   #506
DET17
Reformed SAABaholic
Well my LUK clutch kit arrived....shipped to my door in Georgia, for 186 GBP ($308 at current ER).
After opening their 3 pc kit # 623224000, it contains all SACHS components, exactly as described (a couple years ago) in this thread.
228mm SACHS TDI Disc, Pressure plate, and release bearing:
Disc 1862 468 031
PP 3082 204 033
Bearing 3151 189 232
And perhaps the best news....my gearbox is actually a M90H1, not a M90L2! This means I have the 3.54 first, 2.05 second....same 3/4 as the vaunted L2, and a 0.81 5th. This gearing will match well with the 3.31 LSD Diff. I have (with LH2.4 tone ring factory) that I plan to fit to the 940. Those first couple gears, not as wicked short as the L2 mountain goat gearing.
MPH at 6K shift points, using the 3.31 final gearing and my 25.1" OD tires means very reasonable shift points (38, 66, 98 mph) for the "performance gear changes" and a 70 MPH OD friendly 2515 RPM, which I think the 2.3L redblock will pull easily on level interstate driving.
The only concern for the H1 is the broken 3rd synchro, apparently caused by "gear banging" as we idiots in the States say. That issue, also easily resolved by welding the synchro, has been documented by many online.
Old 11-23-2013, 10:35 AM   #507
DET17
Reformed SAABaholic
And for the sake of M90 posterity, I found this excellent photo album on a 7 series conversion to M90.....excellent details with part numbers shown. All credits to Mr. Baggy798, somewhere in the UK.......
http://s122.photobucket.com/user/bag...?sort=3&page=1
Old 04-01-2014, 01:25 PM   #508
barkster1971
Default 850 glt
The 228mm clutch in the volvo 850 glt is also used in MK1 V70's etc. Has anyone just put the clutch and pressure plate straight in ( without using the Sachs racing pressure plate )?
How has it held up?
barkster1971 is offline   Reply With Quote
Old 04-07-2014, 11:25 PM   #509
AdmiralSenn
2 1/2 questions, guys.
1) Have we confirmed that the correct measurement for the M90 front shaft is 744mm from end to end? And/or can anyone tell me how much longer that is than the stock m46 shaft? (I'm not lazy, I just don't have a ton of down time to crawl under the car nor an accurate way to measure it). I can't afford a mistake here, if I botch the installation then I'll be minus my last driveable vehicle for a while.
2) Regarding the welding, what is the general consensus on how to approach this? Since I lack a welder and skill to use one, I feel like I'd be better served taking the entire shaft to a professional but I have never dismantled a transmission and lack most of the tools to do so. I see some people mention filling it with gear oil as a coolant/spatter protection measure, which I'm willing to explore, but without having the transmission in front of me it's hard for me to visualize what that entails. Do I just buy a crap ton of cheap gear oil and dump it in? Or is there a less messy/wasteful way to do this?
2b) What should I tell the welder? Should I assume he'll know what wire/temperature to use or can someone clear that up for me?
Thanks.
AdmiralSenn is offline   Reply With Quote
Old 05-26-2014, 08:25 AM   #510
DET17
Reformed SAABaholic
Thanks.
I have the front half of the M90 driveshaft....donor was a 9 series. I can likely provide what dimensions you need for this piece. However if you are fitting your M90 to a 2 series, this won't help you.
Old 05-26-2014, 09:58 AM   #511
AdmiralSenn
Thank you. Yeah, it's for a 740.
Old 06-11-2014, 06:44 AM   #512
DET17
Reformed SAABaholic
The front driveshaft (prop shaft) half measures out at around 743mm.....from the aft end of the splined shaft to the FRONT edge of the REAR Guibo mounting flange. This front measure to the Guibo input end is tricky to measure as you have you choice of several surfaces. I've snapped some pics which I will attach to this post for M90 posterity. I don't speak fluent Guibo, so I'm not sure where your donor parts would be coming from to match the size of the M90 output flange. Other experts feel free to chime in on how you fab'd your this detail.
The detailed pic of the front Guibo mount & my OAL measurement from/to:
[IMG][/IMG]
[IMG][/IMG]
Old 06-15-2014, 12:09 PM   #513
AdmiralSenn
In response to another conversation, I can confirm that the M90 guibo / hardy disk is a direct bolt-on to the M46/M47 prop shaft. Although I can't take the disk out of my M46 to measure, it appears to be the exact same part on both setups down to the width of the disk and length of the holes.
I know it was stated elsewhere in the thread, but someone asked, and I saw at least one thread with someone claiming that they were different.
Old 06-27-2014, 06:24 AM   #514
supercheese365
supercheese365's Avatar
DET17, I'm in Macon GA. Where did you locate or buy the M90 parts/setup?
'94 Volvo 850 NA+T -15g, Custom Exhuast, tuned on TunerPro RT, 10psi, slammed (Sold)
'90 Volvo 740 T - 15g, MBC, lowered, Tethys
Originally Posted by 2fast242gt View Post
+1 for the ass spoolage.
supercheese365 is offline   Reply With Quote
Old 07-19-2014, 09:28 PM   #515
DET17
Reformed SAABaholic
I bought my M90 kit right here in the classifieds....seller's name was TIZ as I recall. Fortunately he had a complete kit minus clutch and dogdish flywheel which I already had. Seller was in the UK, and it took around 1.5 months to get it to me (not snail shipping, the seller was too busy to get it expedited). All's well as it showed up fine, just took some time to get States.
Old 07-21-2014, 03:47 PM   #516
Asleeper
The only M90 specific parts are the transmission and front half of the driveshaft. The rest of the parts (pedal assembly, flywheel, clutch hydraulics....) can be sourced here in the states.
As for my my M90 and driveshaft, I got it from Foggyjames here on TB although it was about 4 years ago. I'm not sure if he is still in the business anymore though.
91 740 Regina m47: slow but handles nice thanks to a full polyurethene bushing upgrade, bilstein HD's with diesel springs, IPD sways&chassis brace
95 945T: Gone but not forgotten
Asleeper is offline   Reply With Quote
Old 08-05-2014, 04:05 PM   #517
Kombi
Kombi's Avatar
I've picked up a sketchy dog dish flywheel that needs resurfacing before it goes into the M90, does anyone have the correct dimension for the top of the dish to the bottom?
Kombi is offline   Reply With Quote
Old 09-21-2014, 09:02 PM   #518
Asleeper
I am getting ready to reinstall my M90 in 95 945T and I need to get a new release bearing. Is the one for the M90 the same as the M46/M47 or is it different?
I'll be using it with a dogdish LH2.4 flywheel and a clutchnet yellow 740/900 PP and a Kevlar 850 sprung hub clutch disk if that makes a difference.
Old 09-23-2014, 06:18 PM   #519
LloydDobler
LloydDobler's Avatar
So is it even worth posting a want ad for a whiteblock M90 or is it getting pretty impossible to get one in the states? Or is it pointless because you really need multiples in case something goes wrong?
I'm doing a RWD whiteblock and the simplicity is really appealing.
'66 122 - Collectible project
'06 V70 2.5T - Mostly Stock Daily Driver
Old 09-23-2014, 09:01 PM   #520
DET17
Reformed SAABaholic
Don't know if same/different, but I listed the SACHS release bearing part# early in this thread....came with my LUK (Sachs) 940 TDI clutch for the dogfish & M90.
Old 09-24-2014, 04:05 AM   #521
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
I have 2 M90red for Sale if anybody wants...
Old 10-07-2014, 05:58 PM   #522
Asleeper
The release bearings for the m46&m90 are different. I ended up finding the one was I using when I had the M90 installed in my previous 940 and it was the same one you had listed, part #3151 189 232. I did have an m46 one laying around as well and the tabs appear to be different, as how it sits on the clutch fork. It might still work although I went ahead and reused the m90 specific release bearing.
Old 10-10-2014, 12:41 PM   #523
DET17
Reformed SAABaholic
Contact TIZ in the UK; I bought my redblock M90 from him. He claimed he had his eyes on some of the Whiteblock versions....no idea if he ever delivered any to the States.
Old 12-08-2014, 08:03 PM   #524
Airfrix
Deleted
'96 Volvo 940 B230GK M90 and some mods...
'98 V70 2.5 TDI + chip
Airfrix is offline   Reply With Quote
Old 10-03-2015, 09:14 AM   #525
R12DECOMPETI
Hello.
I am Ruben , I write from Spain and I have a Volvo 940 GLE engine B230FK European and rafters box M90 .
I have the wrong clutch and have to change the clutch guide bearing .
I do not find this out of print and Volvo .
you can help me ?.
I like very much this web.
Tank you
R12DECOMPETI is offline   Reply With Quote
