Old 10-03-2015, 09:17 AM   #526
R12DECOMPETI
This is the parthttp://www.skandix.de/en/spare-parts...easer/1026428/
R12DECOMPETI is offline   Reply With Quote
Old 10-18-2015, 12:56 AM   #527
Henners242
Sorry if this is a noobish question but can I run this setup:
Option #1:
Standard 850 T5-R (240/250HP) clutch setup. Good for up to almost 420NM.
Clutch disc, organic, 20 splines, 240mm, Sachs p/n: 1862 428 133.
with a redbock and dual mass? As for the time being I won't be upgrading the flywheel and Im making around 220-230bhp
Pressure plate, 240mm, Sachs p/n: 3082 254 232.
Need for Swede
97 940 b230fk - Daily
97 940 b230ft - Skid missile
93 240 Torslanda b200 - Quietly rotting 'till I've got some money to throw at it
Henners242 is offline   Reply With Quote
Old 10-18-2015, 10:30 PM   #528
JW240
All idiot, no savant
I think the normal dual mass clutch should work for that amount of HP. iirc the clutch that came out of my parts car (1995 940 with M90) was the same as an 850 2.4T something.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 10-20-2015, 12:03 PM   #529
LloydDobler
LloydDobler's Avatar
The pressure plates are significantly different for dual mass vs single mass, but I don't know for sure about the clutch plate itself. The clutches for the single mass have springs in the hub while dual mass often don't, so there's that as well.
I agree that the stock clutch will be fine.
'66 122 - Collectible project
'06 V70 2.5T - Mostly Stock Daily Driver
Old 10-28-2015, 08:55 PM   #530
Kaban
Hi, has anybody checked this setup:
- solid flywheel from m46/m47 lh 2.4
- pressure plate 940 diesel m90 with 20splines
- 850 glt 228mm clutch disc?
I can't find used tdi m90 clutch disc to go for sinter. Can I use 850 glt 228mm disc with no issues?
Kaban is offline   Reply With Quote
Old 10-29-2015, 05:39 PM   #531
Asleeper
The disk should work fine although as for how long it will hold up depends on what mods you have done.
91 740 Regina m47: slow but handles nice thanks to a full polyurethene bushing upgrade, bilstein HD's with diesel springs, IPD sways&chassis brace
95 945T: Gone but not forgotten
Asleeper is offline   Reply With Quote
Old 11-15-2015, 04:12 PM   #532
Kaban
If you had an AW70, AW71 or AW71L automatic gearbox to start with, then you can keep the transmission crossmember since that is the same p/n as the M90 crossmember. You will also need the mounting bracket for the M90 (number 16 in the last picture of gearbox parts) since that is not the same as the AW7x bracket. The crossmember from the AW7x gearbox is then moved forward in the car and mounted in the front threaded holes in the body a few inches in front of the AW7x holes (yes, there are pre-made holes for using the M90).
Which one bracket is this? There are no picture's
Old 12-22-2015, 06:41 PM   #533
usuniety
can somebody repost a picture of the flat/solid flywheel used in many 850's and early S/V70's that will fit my whiteblock with m90 gearbox and 240mm clutch?
usuniety is offline   Reply With Quote
Old 12-23-2015, 07:47 PM   #534
LloydDobler
This is a '97 850R flywheel purchased brand new, part number 9454774. Also the R clutch kit, p/n 272218. I have a used one in my garage right now and the wear pattern does appear to be 240mm, or 9.44 inches.
Old 12-26-2015, 05:04 AM   #535
barkster1971
Just found a bloke in Germany who can supply the Sachs 765 pressure plate. Should be about £200 shipped to UK. Should be able to post to USA too.
barkster1971 is offline   Reply With Quote
Old 02-04-2016, 04:46 PM   #536
John V, outside agitator
No Turbobricker is going to buy a pressure plate for £200 plus post to 'merikuh...
that's almost as much as most pay for whole car.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 02-04-2016, 07:50 PM   #537
Idealgaslaw
I have that 850R setup, it is really smooth. I like it.
84’ 240 diesel
Idealgaslaw is offline   Reply With Quote
Old 03-09-2016, 04:42 AM   #538
Danish
Sorry if it's in this topic and I've missed it, but could anyone share the dimensions of a M90, I'm particularly interested in these ones:
Danish is offline   Reply With Quote
Old 03-09-2016, 04:42 AM   #539
Danish
Old 03-10-2016, 04:39 AM   #540
sbabbs
sbabbs's Avatar
Old 03-10-2016, 05:47 PM   #541
Danish
Brilliant, thank you!
I'm going to make a mock-up in cardboard to see if it fits the transmission tunnel.
Old 03-10-2016, 07:32 PM   #542
Dean O
Does anybody know if the 850R flywheel will work with the Motronic 1.8 sensor in my '91 960?
I did read that the M90 swap would work with any 5/6 cylinder whiteblock, but I just want some clarity.
I have a donor '95 960 with an M90 and the 850R Clutch Kit on its way so its just the flywheel that I need to source now!!
1991 Volvo 960 B6304
Dean O is offline   Reply With Quote
Old 03-15-2016, 07:09 PM   #543
Chris Wilson
Are there any photos of what this welding of the third gear synchro in an M90 s all about on here still? In the first part of this thread the photos are no longer there. I can't get my head around what this mod is exactly, I suspect the term synchro ring is perhaps ambiguous? Thanks
Chris Wilson is offline   Reply With Quote
Old 03-21-2016, 06:50 PM   #544
LloydDobler
Since you got your question answered in the other forum, I'm linking the thread here. Great job getting good conversation going.
http://forums.turbobricks.com/showthread.php?t=319573
Old 03-24-2016, 11:51 AM   #545
gilber33
gilber33's Avatar
I searched a bit through this thread and couldn't find a specific answer and now time is of the essence. I have my m90 mounted into my 93 945t, I have an M47 front half driveshaft since it mounts to the m90. I want to confirm the m47 driveshaft will properly fit into the back half of the auto driveshaft; splines, carrier location, etc.
My intent is to have the m47 shaft lengthened to fit the m90
gilber33 is offline   Reply With Quote
Old 05-20-2016, 12:57 PM   #546
DET17
Reformed SAABaholic
I have the front half specific M90 prop shaft.... PM me if you want OAL dims, etc. The donor was of course a 9 series in the UK.... should be exactly what you need.
Old 05-24-2016, 11:34 PM   #547
FezMonki
This might work? Cheaper than getting my shaft lengthened for my 240 M90 swap (around here anyway), might work for a 9 series?
http://www.retroturbo.com/?product=v...lvo-200-series
Looking for S90 fat armrest.
FezMonki is offline   Reply With Quote
Old 06-01-2016, 10:14 PM   #548
gilber33
gilber33's Avatar
Just to update. Around me there was one place who could do it, and it was going to run 300 plus because they would need to ship it elsewhere to have it balanced. Instead of hassling with that I bought a complete m90 driveshaft from ebay Germany for 300 shipped.
Old 07-28-2016, 04:50 PM   #549
Danish
Can someone help with a couple of M90 questions please?
I have a B5254T3 engine, and an M90 gearbox.
First question... do I need a spigot bearing in the end of the crank when I mate the two together? There's nothing there at the moment, but other non-Volvo engines I've worked on needed one.
Also, the engine came with a box of stuff which included a rusty flywheel. It fits onto the engine OK, so I've had it zinc plated and fitted it to the engine. I'm not sure what type it is, so I'm not sure which clutch I should buy.
Any advice welcome, thanks!
Old 08-24-2016, 11:17 AM   #550
Okswes
Hey, can anyone restore pictures at first article?
Okswes is offline   Reply With Quote
