Old 02-07-2021, 08:48 AM   #1
DET17
Reformed SAABaholic
Default Another vote for coilovers and "tuned suspension"
Time for some testimony.
For the previous 10 years, I've run several lowering spring systems on my 940 sedan. The first rendition was IPD blue "sport springs" matched with Bils HD; this arrangement gave the car a sporty stance for sure, but underwhelmed on handling and suspension manners. The second rendition was B&G Progressive lowering springs matched with KONI Sports. This setup slightly outperformed the original in lateral handling but was worse mannered when encountering road disturbances.
The best, is definitely the last:
After resisting for nearly 10 years, I finally upgraded to coilovers from Kaplhenke Racing, with "old man" rates of 250F / 175R lb/in. My KONI Sports were retained and the rebound both front and rear have been set to the minimum. I did a fair bit of research on TB and elsewhere, and the 7/9 series KONI Sport fronts need spring rates in the range of 250 to 325 lb/in to be properly "tuned".
With an hour long test drive yesterday, WOW am I impressed!. Every road disturbance is met with a once & done response from the suspension..... just as the factory Engineers designed the system. I never realized just how poorly those lowering springs worked with the dampers that I chose, but I sure do now.
An eye opener for me a couple years back, was when I restored my 92 745T wagon to factory wagon springs and mated with the BILS HD which were already on the car, the difference from the previous lowering springs (removed) was amazing. That old wagon was the best mannered 7/9 series I had ever driven. To me, this was validation that the BILS HD were specifically designed to be mated with factory springs. They nailed it.
This testament is probably a yawner for the suspension sages on TB...... but I'm intending it for newbies who are considering suspension work and who are attempting to improve handling while NOT destroying road manners for traveling over disturbances.
Save your nickels, save your dimes, until you can afford a proper coilover arrangement. Then do your research to ensure the spring rates are a match to the dampers that you will run. The assembly of springs & dampers is a engineered SYSTEM........ not something to be haphazardly thrown together for the "stance".
There, I feel better now
Old 02-07-2021, 08:53 AM   #2
DET17
Reformed SAABaholic
and for those wondering about the stance:
My front Eibach XT barrel springs are 12 inch length; the rears are 13inch length. My goal was not lowering the sedan, but improving performance handling & suspension manners. Both coilovers are set for the lowest height possible (pictured above), so if you desire more lowering you will need the 10 inch front Eibachs and the 11 inch rears.
Old 02-07-2021, 10:04 AM   #3
Glad to see you have had your eyes opened to the ways.
Here's a shameless plug of where you can get those fine components.
https://www.bneshop.com/collections/700-900-volvo-parts
Just in case anyone needs help.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 02-07-2021, 11:51 AM   #4
$599 Volvos
Just placed an order myself
Chturd - pullyourbootstrapsupandsuckituplooser
Chturd- keepyerfilthyhandsoffMYMONEY
Old 02-07-2021, 01:48 PM   #5
dbarton
Dejected by Volvo
dbarton's Avatar
Thanks for the review, but sorry, there's some perspective missing.
Can you tell us what the rates were for the B&G springs?
And what settings were the Koni Sports set at with those springs?
Thanks, Dave B
'84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with modded 0.73 OD, 3.91 diff, unmodified G80.
Old 02-07-2021, 03:40 PM   #6
DET17
Reformed SAABaholic
Thanks, Dave B
Dave, I never could find rate information for the B&G's. I bought them used from another TBer. About the only thing I could find online stated they would lower the vehicle ~ 45mm I believe.
KONI Sport damper rebound was/is set to the minimum settings front and rear. I tried the B&Gs with them set on #2, but it did not help the manners at all (from memory, I think they only have 3 settings for rebound). A few months back, a Euro initiated thread posted right here disclosed the factory specs for those dampers on compression/rebound.
Old 02-07-2021, 05:22 PM   #7
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Nope! I emailed Koni support and got the rates.
http://forums.turbobricks.com/showthread.php?t=356594
Honestly not so sure how useful these are without a shock dyno plot.
I think the wire diameter on the B&G springs (a copy of dealer option springs from back in the day, as far as I can tell) comes in at 14.7mm in the front and 12mm in the rear, but obviously is a progressive rate, losing up to 2(?) active coils as the suspension compresses. Progressive springs are often difficult to set up a damper around for this reason as your damping ratio changes during suspension action.
If the wire diameter I have is right the spring rates go from 143-230 in the front and 124-238 in the rear at the spring, or 140-225 front and 185-335 in the rear.
I sell chips for LH 2.4!
Old 02-07-2021, 05:25 PM   #8
redblockpowered
And to add to that, stock rates (at least in my '93) were 140 lb/in front and 142 lb/in rear at the wheel.
Old 02-07-2021, 07:01 PM   #9
mikep
The MP
mikep's Avatar
I might be able to do some spring testing later this year. If so, i’ll contact OP to see if he still has them.
Originally Posted by Lord Tentacle View Post
Yes please!
Want a kangaroo hide?
Originally Posted by Shifted View Post
Now why would I want to hide my kangaroo.
Old 02-08-2021, 07:40 AM   #10
DET17
Reformed SAABaholic
Yours was the 2nd time I saw the data; original I believe was a guy in Holland, many years back. If you search KONI SPORTS and perhaps 7/9 series, you will find the thread.
Old 02-08-2021, 08:13 AM   #11
dbarton
Dejected by Volvo
dbarton's Avatar
Ok, so then maybe we can surmise the weird progressive spring rates were just not compatible with a proper tune for Koni Sports.
Question: For highway cruising, does it feel like the new springs are noticeably stiffer that the old B&G's?
Dave
Old 02-08-2021, 09:25 AM   #12
shoestring
shoestring's Avatar
Wow that car is clean.
I love threads like this. Thanks for posting.
Old 02-08-2021, 10:03 AM   #13
Just because some lowering springs have "dead coils" doesn't mean in end use they are actually progressive, They usually just do that to pass TUV inspection which frown on having loose springs when lowering the car.
Testing the spring in the stroke that is used in the vehicle is the best way to know for sure if its a linear or progressive rate spring.
Mikep would be the best to give us answers about this.
Old 02-08-2021, 10:26 AM   #14
mikep
The MP
mikep's Avatar
I like the graphing that we were able to do in the past for that reason. I am not able to do that now, so any checks i do are limited to my scale. If i get a load cell i can do a little better testing at home, but i’m hoping to have access to the computer testing again some day.
I haven’t seen these b+g springs, but if the stackable wire coils are almost touching when unloaded, they’re just placeholders, like you say.
Old 02-08-2021, 01:49 PM   #15
DET17
Reformed SAABaholic
KONI sports at full extension, with B&G's installed. Don't think I ever took a pic of them in the front with the sedan suspension "loaded".
Free length comparison, B&Gs vs. Eibach XT:
Old 02-08-2021, 02:06 PM   #16
mikep
The MP
mikep's Avatar
Those aren’t progressive. They look softer, since the overall diameter is large, same free coil count, similar wire size.
Side note, when i measure wire size i measure painted thickness i find a chip in the paint (or make one at the end) to compare. If it’s say, .010” thinner without that chip, i subtract .020” from the full paint measurement. I like to do the math even if i measure them on my scale and/or the spring rig, and i compare several online calculators. I haven’t done the long math in a while, but i might. It’s fun to find errors.
Old 02-08-2021, 03:06 PM   #17
redblockpowered
So you're only working with the bottom ~3 coils of spring when at ride height?
Old 02-08-2021, 03:33 PM   #18
Chilm
Double Dutch
Chilm's Avatar
Hi DET17,
you stated "This testament is probably a yawner for the suspension sages on TB...... but I'm intending it for newbies who are considering suspension work and who are attempting to improve handling while NOT destroying road manners for traveling over disturbances."
and that's a nice gesture, so concerning I'm a suspension newbie can you provide us with a part list from the 2 pictures of your starting post?
You did the struts yourself as I can see but what parts are in the tower etc. and did everything came from Ben?
Also do you stil have the luxe steer attached as seen in a later picture.
Cuz I stil only have this :(
Thanks in advance,
Chilm.
Flying Dutchman - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 02-08-2021, 04:51 PM   #19
Chilm.
This kit is what you need.
https://www.bneshop.com/collections/...or-diy-install
Old 02-08-2021, 05:19 PM   #20
Chilm
Double Dutch
Chilm's Avatar
Originally Posted by blkaplan View Post
Thanks Ben, I'll be back
Old 02-08-2021, 08:58 PM   #21
mikep
The MP
mikep's Avatar
My man Bne pulling that cash register lever like a one-armed bandit.
Old 02-09-2021, 08:49 PM   #22
DET17
Reformed SAABaholic
Question: For highway cruising, does it feel like the new springs are noticeably stiffer than the old B&G's?
Firm. Best ever, out of the 3 total sets of suspenders.
As Michael Yount said, "it transforms the car".
Old 02-10-2021, 01:04 AM   #23
mschultz373
mschultz373's Avatar
I've always wondered - big noob energy inbound -.... lots of coilovers have adjustable spring perches to adjust ride height, no?
Obviously on the redblocks, without a mcpherson setup in the back, the ride height is solely determined by the rear spring height.
so one could theoretically adjust the front ride height via a coilover, but not the rear. right?
mschultz373 is offline   Reply With Quote
Old 02-10-2021, 11:30 AM   #24
mikep
The MP
mikep's Avatar
You can add adjusters in rear (look closely at the first post). But often we just do the math or follow a tried and true rate and length.
Old 02-10-2021, 02:02 PM   #25
Acke
The upper spring perch is height-adjustable in the rear, as can bee seen in DET17s first post. In some applications the shock absorber "housing" length is also adjustable in the rear.
