Old 09-30-2010, 12:27 PM   #76
sbabbs
sbabbs's Avatar
Location, location, location...
If the junker 240 won't make it there, take part of it.
Old 09-30-2010, 03:47 PM   #77
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
win
B5.5 passat wagon, low af sexier than most wagons here.
Old 10-07-2010, 09:25 PM   #78
ElBertoPolvo
i would prefer not to
ElBertoPolvo's Avatar
take your pics however you want to...its all about what you like......
ElBertoPolvo is offline   Reply With Quote
Old 10-25-2010, 09:19 PM   #79
brakedust
brakedust's Avatar
s
brakedust is offline   Reply With Quote
Old 12-02-2010, 05:49 AM   #80
benknowsbest
benknowsbest's Avatar
best thing you can do is experiment.
if youve got a dslr, get a couple of off camera flashes. lighting is key, and having some flashes lets you control the lighting.
what i do is put the camera on a tripod and take multiple exposures with the flashes in different locations, then merge all the layers together in photoshop.
result:
others: http://www.flickr.com/photos/3390328...th/5134620749/
obviously, not everyone has access to a dslr and flashes, so youll be needing to use available light. the best light happens at sunrise and sunset. its soft, has good tone and comes in at an angle. unless you want a silhouette, you'll want the side of the car youre photographing to face the sun. make sure youre at an angle where you don't get your reflection or shadow on the car. the best looking photos (IMO) have the sky reflected in the windows.
another thing you can do is wait till its a bit darker, put the camera on a tripod, and take a long exposure (30 seconds or so). walk around the car with a light of some kind and shine it at the parts you want to highlight. experiment with different coloured and shaped lights, lighting different areas and moving the light around at different angles.
the most important part is to experiment, practice, and keep at it. theres is no formula on how to take a good car picture, or on how to take a good picture of anything for that matter, there are merely things to keep in mind as you experiment.
good luck!
benknowsbest is offline   Reply With Quote
Old 12-25-2010, 12:44 PM   #81
gfco_321
gfco_321's Avatar
Default My 240 on the road
I think i made every single mistake pointed out in this thread but i still think it looks cool
I took in the middle of nowhere between Chile and Argentina.
Photobucket
gfco_321 is offline   Reply With Quote
Old 01-01-2011, 05:01 PM   #82
Volvo Heretic
Volvo Heretic's Avatar
I've got some old instant camera photos that I have tried to scan, but they came out real grainy. What is the trick to doing a better job? How much resolution should i use and what size should the picture be to post on this forum through Photo Bucket or is it just trial and lots of error? I have no negatives. How about just taking another picture of the photo with a digital camera?
Here is a digital photo of a picture, much better than scanning.
72 1800e, (74 B30f, M410, 1031 w/3.31:1, Weld Draglite 10x15/ 12x15, 265/50-15/ 295/50-15 BFGoodrich TA radials)
http://www.youtube.com/watch?v=AKn-LTNa4rc Top Speed Attempt Video
http://www.youtube.com/watch?v=T3qDGChRDDY Weather Report "Nubian Sundance"
Volvo Heretic is offline   Reply With Quote
Old 02-07-2011, 09:58 PM   #83
Hagar17
Hagar17's Avatar
Just burn some f*ckers house down!
Keeping late 80's Swedish metal alive!
Hagar17 is offline   Reply With Quote
Old 02-08-2011, 02:12 PM   #84
vivalavolvo
vivalavolvo's Avatar
This was actually done in total darkness. I did a 15 second exposure and ran around with a manual flash "painting" the car. I did this with a point and shoot too.
1978 242DL - 1995 855 T5 ARD Green - 1992 Volvo 745
vivalavolvo is offline   Reply With Quote
Old 03-04-2011, 05:13 AM   #85
760T man
Phillip Mamouf-Wifarts
760T man's Avatar
Location: Bettendorf, IA, when I'm not EASTBOUND 'N DOOOOOWN LOADED UP 'N TRUCKIN'
Josh, that's pretty ****ing badass.
a '90 765ti, an '84 244ti, and a '14 T680
760T man is offline   Reply With Quote
Old 03-04-2011, 05:51 AM   #86
aibast
aibast's Avatar
here is a tip, try to leave off background objects out of the picture.
in this one the blue barrel ruins it. Also polarisation filter helps a lot when taken pics of a car and in other situations.
This picture is taken with polarisation filter
also small aparature can help you, leaving the background more out of focus.
Volvo Nilsson 740 "van" 1987 - B230K automatic to M46+OD swaped ex hearse
Volvo S80 2002 - D5 automatic daily eco cruiser 44mpg average
aibast is offline   Reply With Quote
Old 03-04-2011, 09:28 AM   #87
vivalavolvo
Thanks
I wanna go back one night and do it again. It's in a park under the 476 over pass, the cops let us alone with a confused look when we tell them what were up to when they swing by lol.
Old 04-13-2011, 06:20 AM   #88
volviefinks
my 94' 960 i just purchased. not the best photo op. but i will find a place soon.
volviefinks is offline   Reply With Quote
Old 04-13-2011, 06:25 AM   #89
propav8r
F*ck Edgar
propav8r's Avatar
Mooresville? Welcome to another NC bricker! Nice ride.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 05-06-2011, 06:25 PM   #90
Finnish240
Finnish240's Avatar
Im trying to take cool pics. Sometimes I've got some luck
Here focus is in the ground, looks nice, but didn't got what I wanted.
Finnish240 is offline   Reply With Quote
Old 05-20-2011, 12:33 PM   #91
ButterflyBrakeChecker
ButterflyBrakeChecker's Avatar
Default Opinions are like _______.
Photobucket
You think your picture looks cool because it is! While you have not made the car the subject, like most people are giving advice for, the narrative (sorry, I'm an art major) is great. You are showing the viewer a piece of your journey in South America and the landscape is just as important as the vehicle.
Also, you pulled off the road; good move, especially on that blind hill.
I like that the horizon line is just below or at the bottom of the windows. Not sure if you did this on purpose but having the sky in the windows brings the (under-lit) car into the viewer's attention. I do think it would be worth brightening the car a little in Photoshop; just a little.
BTW, who the heck were you gonna call when it broke??
ButterflyBrakeChecker is offline   Reply With Quote
Old 05-23-2011, 03:39 AM   #92
Da Fox
I just want to point out that it's a larger aperture that helps, but larger aperture = smaller number. Knowing this makes a difference.
Fox
88 745 Turbo w/ full IPD springs/sways/bilstein HD's, a replacement 95 turbo motor (now with over 300k on it) running through an m46 to an open diff. Can you say peg legged?
95 BMW 540i6 - wallet vampire
86 RX7
....... The wagon's the quickest to 60 , then gets raped by the 540i. :(
Da Fox is offline   Reply With Quote
Old 07-21-2011, 02:33 AM   #93
Matt
ICY HOT STUNTA
Matt's Avatar
Taken with an 8sec exposure:
...and with a 15sec exposure:
There was ~20ft between the cars, but the light wouldn't reach the black Golf.
SHOtime - '90 744 Turbo
The LowCar - '93 945 Turbo
Ghetto Superstar/SkidCar - '88 740
Brown - '85 740 Turbo
Matt is offline   Reply With Quote
Old 07-21-2011, 02:33 AM   #94
Matt
ICY HOT STUNTA
Matt's Avatar
Old 07-21-2011, 11:03 AM   #95
gdogg16
You're a Subtotal
gdogg16's Avatar
The gatorade bottle is a nice addition.
Greg
'66 Locort
'72 Fulvia 1600HF Lusso
'74 142
'83 911SC
'99 2500 Ram
'13 TDI Sportwagen
'15 TDI Sportwagen
gdogg16 is offline   Reply With Quote
Old 07-21-2011, 11:23 AM   #96
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Maybe it's a VW thing.
Looks like you could be running a lower ISO. If you're already keeping the shutter open for 15 seconds, then what's a few more seconds?
Fake Race Car
Old 07-21-2011, 12:17 PM   #97
gdogg16
You're a Subtotal
gdogg16's Avatar
If you want to shoot rolling shots, match your shutter speed to your vehicle speed and voila.
1/60 at f4.5
DSC_3281.jpg by KeysarPhoto, on Flickr
1/60 at f5
DSC_3260.jpg by KeysarPhoto, on Flickr
Old 07-21-2011, 01:11 PM   #98
Matt
ICY HOT STUNTA
Matt's Avatar
The iso is as low as it can go at 100, might as well do a 30sec shutter, haha.
Old 11-20-2011, 02:30 PM   #99
sbabbs
sbabbs's Avatar
Bigger aperture produces less depth of field(Stuff that will be in focus). Smaller little aperture camera eye creates a greater depth of field, but it flattens the image.
This is all basic film photography stuff if you ever took any real film camera classes. Now days with the digital cameras, it still applies if you can adjust your aperture with your digital camera.
There is also the circle of confusion that every lens has...
Old 11-20-2011, 04:21 PM   #100
Two245Turbos
Two245Turbos's Avatar
Here's an example of wide open aperture(lower#) from the 50 1.4 @1.4. Note how shallow the focal plane is.
EXIF intact.
Was my '78 242GT, '83 DL...and 3 Turbo 245's
Two245Turbos is offline   Reply With Quote
