Old 06-07-2018, 11:14 PM   #176
lookforjoe
lookforjoe's Avatar
Getting closer to paint
Put in a engine bay fan using a thermoswitch trigger, which has resolved the heat soak after highway runs issue. Added a timer circuit so it runs on for apporx 2min after shutdown if bay temp is over 203ºF.
Made a better fitting intake pipe, and added an air scoop to the engine cover to feed the K&N Xtreme
Engine has been running well since last year's timing map revisions. I tried adding some timing back in over 2500 higher load areas, and got knock under load in 2nd. Reverted to previous no-knock map. I think I'll leave it be until I can actually log timing.
no bueno:
all good:
My XR July2013 - 446AWHP @ 8K rpm
Old 08-17-2018, 07:30 AM   #177
lookforjoe
lookforjoe's Avatar
2K primer
Volvo Passion Red 612 base coat
Clear coat:
(modified Volvo C30 rockers)
Much final sanding & then polish to go. After that, car gets 5" tape stripe that runs down the sides & across the back
3M 1080 G15 yellow (test swatch)
earlier clear coat - this orange peel was sanded out :D
