Old 01-23-2011, 07:51 PM   #51
Hagar17
Hagar17's Avatar
cripes ditch win2k already!
Keeping late 80's Swedish metal alive!
Hagar17 is offline   Reply With Quote
Old 01-23-2011, 08:41 PM   #52
beepee
how hard can it be?
beepee's Avatar
Originally Posted by klr142 View Post
I'm not sure(I'm mostly a Mac person). It says Tunerpro.exe is not a valid Win32 application.
You've got something seriously wrong with your tunerpro install. Uninstall, re-download, and try again.
Bump: added Ostrich install.
beepee is offline   Reply With Quote
Old 01-23-2011, 08:51 PM   #53
klr142
Turbo, what?
klr142's Avatar
Did you miss the part where I said the laptop is from 1998? 233mhz processor and 4gb hard drive can only go so far, lol.
I'll try it again when I'm back home.
And man, you're all over this!!!
Old 01-24-2011, 01:03 AM   #54
2fast4u
2fast4u's Avatar
ok lemme start the scary questions:
When I double click on RPM limit it is set at 39. Is that just a value for 6500ish rpms, or is it saying my rev limit is 39 rpms?
nvm, holding the mouse over it explained it.
1993 940T
2005 RSX Type S
Originally Posted by badvlvo View Post
Sounds like you are afraid of the horse cock Kenny.
I will freely admit that yes, yes I am. and I'm not ashamed of that fact.
Originally Posted by MrBill View Post
im skeptical... i hope this isnt your last post. famous last words, rite? "anyone JB welded this?"
2fast4u is offline   Reply With Quote
Old 01-24-2011, 01:08 AM   #55
klr142
Turbo, what?
klr142's Avatar
Open up the rpm table that is included in beepee's "kit". It tells you what that number corresponds to in rpm.
EDIT: I tried a fresh install of TunerPro v5, same message. :( I won't be tuning on this laptop anyway, but yeah.
Old 01-24-2011, 07:39 AM   #56
JW240
All idiot, no savant
Originally Posted by ipdown View Post
JW, may be speed rating is wrong? Most memories have access time in ns (e.g. 27C256-70, that 70 is access time), if this chip has slower access time LH will have trouble reading from it.
The ones i have are 70 ns access time, i'll try your suggestions.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 01-24-2011, 11:27 AM   #57
beepee
how hard can it be?
beepee's Avatar
I've added explinations for most of the values in the comment field; the XDF for EZK is still pretty rough (though it is fairly complete as far as I can tell) so I will be working on that next.
Anyone with WinOLS, or who happens to have an alias of ipdown or blabla, who would like to add tables, please step up! :-)
Also my RPM equation is an estimate; the values are not exact but they _should_ be within 100 RPM of reality. I'm not even going to get into how I determined that equation but I am sure that there is a simpler/better one.
What sucks is that I can't figure out how to make TunerPro do conversions that aren't simple math. That's why the RPM table is included; every time I try and tell it that RPM = 60*e^(0.0215834714*(255-x)) it gets wonky and doesn't even come close to a correct value.... ugh.
Old 01-24-2011, 11:33 AM   #58
beepee
how hard can it be?
beepee's Avatar
I think the highest I have that works was less than 20, so...
*opens google calculator*
9xx LH2.4 runs at 12.5 Mhz
(1/12 500 000) second = 80 nanoseconds
I guess 70 should work, but it is cutting it close. I'd shoot for 40 or less.
I am told that the 5xx ECU only runs at 6Mhz so it might work just fine if you have one of those.
Old 01-24-2011, 11:45 AM   #59
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
hm, what's the deal with the timing numbers? they don't seem to make sense...
Megasquirt Tuning!
Old 01-24-2011, 11:50 AM   #60
beepee
how hard can it be?
beepee's Avatar
Could you give me more detail? I haven't played with my EZK yet; I'm convinced I'll asplode my motor.
Which table are you looking at, and how is it 'off' ?
Old 01-24-2011, 11:51 AM   #61
linuxman51
linuxman51's Avatar
all of them. shows max advance anywhere of like 17 degrees. I'm willing to accept conservative timing, but even that is excessive ;)
Old 01-24-2011, 12:02 PM   #62
beepee
how hard can it be?
beepee's Avatar
I feel ya. If the EZK is anything like the LH box, the tables are based on clock speed and tooth count... so I'll see if I can find the clock speed.
I have no idea where the X/8.7 formula came from; maybe one of the SAAB boys put it in there. It was in the XDF when I downloaded it.
And I really need to step up and get some ASM skills.
Old 01-24-2011, 12:02 PM   #63
linuxman51
linuxman51's Avatar
If I can usurp my buddy's ostrich I might have a little more to add to this today or tomorrow.
Old 01-24-2011, 12:13 PM   #64
beepee
how hard can it be?
beepee's Avatar
That would be excellent. If you get a chance before I do, crack open your EZK see if you can get the speed of the crystal on the board; it will probably help a lot with the maths... I'm at work right now and the only picture of it I can find has a test mark obscuring the numbers...
Old 01-24-2011, 12:16 PM   #65
linuxman51
linuxman51's Avatar
I posted all that info years and years ago, I think I had the crystal speed for ezk in there as well. not all of the info is correct but the hardware stuff was pulled basically from datasheets off the part numbers from the car(s)
Old 01-24-2011, 12:28 PM   #66
beepee
how hard can it be?
beepee's Avatar
Found it!
http://forums.turbobricks.com/archiv...p/t-41499.html
Old 01-24-2011, 12:30 PM   #67
JW240
iirc the stock chips are -250, so 250 ns. the 70 ns should be more than fast enough. I'll try the different way of programming this weekend, see if it works. should be cool for E85/gasoline. the 27SF512 is cheap on ebay, directly from china, ~32$ shipped for a 13 pack.
Old 01-24-2011, 12:42 PM   #68
ipdown
Член на форума
ipdown's Avatar
All my 9xx ecus have 12 MHz cristals.
LH 2.4 timer is running at 500 KHz (in 950,962,967 ecus which I have disassembled),
rpm signal from EZK is two pulses per revolution.
The following formula is from motronic, but seems to work for the EZK ignition tables:
X * -0.375 + 60
Reg. rpm conversion approximation - 60*e^(0.0215834714*(255-x)) - would be great to
find the exact formula. This is what LH does when converting timer stamps to convert them to one byte values (this is 8051 assembly):
Note there is map lookup in assembly code, the map content can be seen below in C code
LOOP:
;; R1 = 6
;; R2 = DELTA_CRC_HI - low byte of (last rpm pulse time - new rpm pulse time, in 500Khz)
;; A = DELTA_CRC_LO - high byte
DEC R1
RLC A
XCH A,R2
RLC A
XCH A,R2
JNC LOOP
MOV A,R2
RRC A
RRC A
ANL A,#0x3F
JNC DONE
INC A
JNB ACC.6,DONE
INC R1
CJNE R1,#0x08,DONE
SJMP TOO_LOW_RPM
DONE:
MOV DPTR,#1x64_MAP
MOVC A,@A+DPTR
XCH A,R1
SWAP A
RL A
ORL A,R1 <-- done
Very roughly translated to C this looks like this:
int translate_RPM(int real_rpm)
int map[64] =
0, 1, 1, 2, 3, 3, 4, 5,
5, 6, 7, 7, 8, 9, 9, 10,
10, 11, 11, 12, 13, 13, 14, 14,
15, 15, 16, 16, 17, 17, 18, 18,
19, 19, 20, 20, 21, 21, 22, 22,
22, 23, 23, 24, 24, 25, 25, 25,
26, 26, 27, 27, 27, 28, 28, 29,
29, 29, 30, 30, 31, 31, 31, 31
// timer T1 is clocked with 500 KHz,
// RPM signal from EZK is doubled
int v = ((500000) / ((real_rpm) / 30));
for (int i = 6; v < 65536; --i)
v *= 2;
v /= 1024;
return map[ (v % 64) ] + (i * 32);
This looked to me as some weird logarithmic function, and is very similar to one found here:
http://www.dattalo.com/technical/the...7s%20Algorithm
ipdown is offline   Reply With Quote
Old 01-24-2011, 12:46 PM   #69
linuxman51
linuxman51's Avatar
wooooow that was a long time ago. I'll re-verify EZK megahurts at lunch.
Old 01-24-2011, 12:58 PM   #70
linuxman51
linuxman51's Avatar
X * -0.375 + 60
editing the data in the xdf, this looks about right
for those doing it through TP, the equation is ((X * .375) * -1) + 60. for whatever reason, multiplying by a -.375 made everything zero.
Old 01-24-2011, 01:06 PM   #71
beepee
how hard can it be?
beepee's Avatar
Change it to -0.375 and it works. TP's equation parser sucks
Whoa ipdown, thanks for that! I am glad my approximation formula is useful. Looks like we will never have a straightforward formula for RPM though.
I have just re-polished the EZK XDF and posted it, check it out. If you all approve, i'll update the zip...
http://dl.dropbox.com/u/2074311/Volv...-beepee-v2.xdf
Let me know what you think and if I am moving in the right direction... Thanks.
Old 01-24-2011, 01:40 PM   #72
linuxman51
linuxman51's Avatar
Man it's your zip and xdf, you don't need our approval to update your stuff ;)
Checked the crystal on a 153(i think) ezk (2.4 ezk...) and it's 8 mhz.
grabbed my moates burner at lunch, bouta get that software spun up on the new laptop
Old 01-24-2011, 01:46 PM   #73
beepee
how hard can it be?
beepee's Avatar
Well I like feedback, if what I am doing is only useful to me, then what's the point??
I'll update stuff now.
Old 01-24-2011, 06:41 PM   #74
beepee
how hard can it be?
beepee's Avatar
Just added a huge step-by-step to the OP. Let me know if it helps anyone; I went from memory for lots of it so I am sure there will be corrections...
Time to finally install the crank sensor UPS says is sitting on my porch, yeehaw!
Old 01-24-2011, 06:45 PM   #75
2fast4u
2fast4u's Avatar
Amazing. Seriously man. Awesome stuff. Truly set up for idiots. Can't thank you enough.
