#76 | |||
how hard can it be?
![]() Quote:
#77 |
Член на форума
![]() Beepee, very cool tutorial, thanks! I should mention that I am driving only with ostrich (without chip) for the last two months in the winter time, and we get some really cold weather sometimes. It just works and works. moates.net sells replacement battery at their site with a note - you should never need this!
And a tip - Porsche 928 used LH 2.3 and there is tuning system for it - SharkTuner. From it's manual they recommend setting rev limit to some low rpm, and tuning afr up to that point. Then gradually increase rev limit up to the range. |
#78 | |
how hard can it be?
![]() Quote:
Thanks again for all of your hard work, and just in case it isn't clear: ipdown, blabla, sbabbs, frpe82, mrjaybeeze and many others who I am forgetting from the ECUProject forums are who made this possible! (if I left you out, let me know, I will update the OP as well! Thanks guys!!!! ![]() |
#79 |
BRANDSCHUTZVORSCHRIFTEN!
![]() Join Date: Dec 2002
![]() shark tuner isn't vastly different from TP. I played with one a couple years ago on a supercharged 928. I wouldn't worry as much about setting a low RPM limit per-se, I would just suggest that one should make small changes unless you're scaling an entire map (for say... e85 or bigger injectors or whatever)
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Now with in-house Dyno tuning! Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! |
#80 |
300+ Clurb
![]() Do you know the pulses per revolution on Lh 2.2
#81 |
how hard can it be?
![]() Just figured out how to make TunerPro calculate RPM! Yay! Updates soon...
#82 |
how hard can it be?
![]() Ok I have crashed TunerPro like 37 times now trying to enter conversion formulas... I'm beginning to see what ipdown meant
#83 |
![]() hahaha. i'm still waiting on my buddy to call back so I can grab the ostrich, otherwise it'll probably have to wait til weds when we're dyno tuning another car.
probably just as well, I don't have a wideband for the 940 yet. thinking about getting one of those 14point7 oem type units. |
#84 | |
how hard can it be?
![]() Quote:
But my LC1 hasn't crapped the bed.... yet... Maybe I will have better luck than MrBill, I'll try and keep mine off the turbine housing ![]() |
#85 |
how hard can it be?
![]() Updated my package. Uhhh-huh huh huh!
#86 | |
![]() if you changed all the data on a NA box to the same data on the turbo box, would that make it a turbo computer(not officially but run identically).
1993 940T 2005 RSX Type S ![]() ![]() ![]() Quote:
#87 |
how hard can it be?
#88 |
![]() So with the Ostrich loaded and running via laptop you can then shutdown remove the laptop and restart and drive the car? The Ostrich thus retaining the maps etc thus becoming the newly programmed ECU?
Keeping late 80's Swedish metal alive! ![]() |
#89 | |
Turbo, what?
![]() Quote:
I need some clarification, if I take that 935NA bin and modify it to my liking, can I use it in my 951 ECU? I'm thinking I can, but maybe not... I can't remember for sure now if I was able to take the 935 XDF file and open up my 951 bin through TunerPro. I need to get that other computer up and rolling, but it's not mine so I can only sometimes use it.
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 Endurance Racecar - The General's FB page - Oregon Volvo Tuners - Died ![]() |
#90 |
They see me trollin'
'88 245 - 2JZGTE VVTi | MS3X ECU, MS2 TCU | GT3582R-HTA | Staged simultaneous dual fuel | 590whp 580ftlbs 1968 Furd Rustang fastberk | 2JZGTE VVTi | MS3X ECU | PT6776S | 4L80e Microsquirt TCU Sloppy Transbrake | 3.73 8.8" rear end 1981 Piper Cherokee Archer II | All stock |
#91 | |
how hard can it be?
![]() Quote:
And the Ostrich isn't an ECU ![]() |
#92 |
how hard can it be?
![]() Posted an new XDF, forcing myself to go to bed before I start having nightmares about Robert Bosch chasing me with a TI-92 or something, I hate maths.
#93 |
![]() Great work beepee! Nice to see all the info/knowledge bundled like this!
#94 | |
Член на форума
![]() Quote:
#95 |
Член на форума
![]() Another note about main fuel map values - there is conversion too: X-128
Then valid range for a cell becomes [-128 : 127], where 0 is zero correction, all values greater than zero adds fuel, negative subtracts fuel from the calculated value, shown here. In other words if left as is, (unsigned) 128 would mean that after doing the calculation for the given load and rpm, the calculated value is used as is without correcting it (zero correction). Changing a cell by 1 changes fueling by about 0.2% Sorry for the crappy explanation, but I hope you get the point. P.S. For the "C/C++" people the values in the main fuel map cells are of type "char". |
#96 | |
![]() Quote:
#97 | |
how hard can it be?
![]() Quote:
#98 |
how hard can it be?
#99 |
Turbo, what?
![]() Question... Lamda correction, if we turn it off, adjust everything to where we want it(I will still want it to be near stoich for most driving, just not the fun and aggressive stuff), then turn it back on, it's going to want to adjust stuff further, won't it? Is there a map somewhere that gives us control over what it thinks it wants to be seeing?
#100 | |
how hard can it be?
![]() Quote:
Ipdown had a more thorough description on ECUProject, but basically the lambda circuit gets converted to a 2-bit input on the ECU, and the voltages that change the bits are determined by the hardware, not software ![]() That said; I used narrowband emulation with my LC1 to fool the ECU into thinking that 15.5 is 14.7 and that works just peachy! Just make sure that you don't lean out in boost (mine doesn't). Last edited by beepee; 01-25-2011 at 11:47 AM.. |
