Old 02-08-2021, 02:56 PM   #2326
EFbI4
EFbI4's Avatar
Finally I'm tryed to live tune LH ECU and... There is something wrong basically.
I disable lambda regulation, upload my firmware, adjust AFR on idle, low loads and high load. But how to adjust medium loads? I can't find a good recipe for it. Maybe you there can give me some advices?
In TunerPro I can't find a logging for RPM/LOAD table (mail fuel map) and I have no idea how to log tracing (and as we know trace is slow and sometime wrong).
- Custom Jetronic chips (faster than you try before)
- TPS adapter plates (for ECU conversion)
- Megasquirt 2 cheap custom build
- AW71 shift kit
- 46/38 valves for 530/531 head
PM me!
EFbI4 is offline   Reply With Quote
Old 02-09-2021, 03:52 AM   #2327
mrjaybeeze
Team Jetronic.info
Hi
LH can absolutely not be "live tuned" per se !
You can actually fry the ECU by changing parameters with engine running.
It is not possible to log the tracing in Tunerpro until someone makes a plugin for that.
Tuning of medium loads is same as all other LH tuning, it is primarily done in the main fuelmap.
YS
Jaybee
ipdown.net/jetronic.info/tiki-index.php
Site open in "lame mode"
If you have some issues
just send me a message
mrjaybeeze is offline   Reply With Quote
Old 02-09-2021, 01:12 PM   #2328
gsellstr
gsellstr's Avatar
Perhaps I'm misunderstanding, but I've been able to live tune using the Ostrich, and upload the tune to the ostrich while the engine is running.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-09-2021, 01:15 PM   #2329
esmth
I have been able to do it most of the time too, but 0.01% of the time the car will royally **** itself and flood or crash the computer or go into weird unknown states. I don't do it anymore
1991 244 LH2.4 M46 352k miles
Old 02-09-2021, 01:37 PM   #2330
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
I've had it crash the ECU but not anything weirder than that.
I sell chips for LH 2.4!
Old 02-11-2021, 09:14 AM   #2331
sUbZeRo_DE
Just a quick Update!
Sometimes things are not as they seem... I found the Issue. The FPR was faulty and it pumped fuel right in the Intake... Fixed that, and now it is running like it should! Thank you all!
And yes TÜV is only once all 2 years =)
sUbZeRo_DE is offline   Reply With Quote
Old 03-02-2021, 04:33 PM   #2332
Swedbrick
Swedbrick's Avatar
Finally got my junk on the dyno, using kyle's (klr142) every day mapping as part of the setup, in a later bin file with the e-fan compatibility. I also updated to include the later lambda constants, as I made a comparison sheet for those. The tune got put in a 984 casing and ran on the dyno for a cool 135whp@190Nm. 1500-2000 rpm needs some sorting, possibly some idle enrichment deal that could be improved, in general I'm happy.
To repeat a small summary of the setup for reference:
10.3:1 b230k with stock 530 head
kg004 aka k camshaft
buchka wasted spark
218cc ev6 injectors
bigger J-pipe with turbo exhaust system
Chipped lh2.4 (own tune)
Volvo 745 - IPD springs, 25mm/19mm swaybars, K-cam, LH2.4, M90 swap, 3.54 \w racingdiff lsd, track/daily
Old 04-03-2021, 12:41 PM   #2333
EFbI4
EFbI4's Avatar
Anyone has 597 and 578 xdf? Ipdown is down and don't take a chance to download. ASAP!
Old 04-03-2021, 01:33 PM   #2334
bobxyz
bobxyz's Avatar
^^^ seems OK now: https://ipdown.net/jetronic.info/tik...Id=13&offset=0
Old 04-06-2021, 08:55 AM   #2335
esmth
his website has been up and down a ton recently. definitely make a backup of the bins/xdfs. The jetronic part his site is borked right now but the rest of it works. The cert is about to expire as well.
