Old 08-03-2020, 06:32 PM   #51
bnw
I've heard the EGT sensors are known to fail on these engines, so be on the look out for that...
Might be an issue, but as far as I have understood, a failing EGT = retarded/advanced ignition (sorry, not sure if this is the correct wording...), my turbo with EBC on does not pump more than some 0.3 bar. With an MBC, 0.9 is easily achieveable.
92' 965 B204FT+M90;
89' 765 D24TIc+ZF4HP22;
87' 764 B280F + AW70.
Many more to come!
bnw is offline   Reply With Quote
Old 08-04-2020, 01:58 AM   #52
sbabbs
sbabbs's Avatar
928 is also a NA b234f ECU.
Old 08-12-2020, 10:17 AM   #53
tomasss
tomasss's Avatar
If the EGTC is faulty or reports high temp, it does several things. TCU lowers the boost, EZK retards, LH enriches the mixture in turn to lower the temp. More here http://forums.turbobricks.com/showthread.php?t=349043
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
