Old 07-25-2020, 12:14 AM   #2926
brendon_ak
harald's is the only t5 car i've driven that didn't annoy me, but that was before it started falling apart. i just wish it was as easy to do some kind of toyota transmission as it is to do a t5.
You drove mine and commented on how you didn't hate it!
Old 07-25-2020, 12:59 AM   #2927
Quin
ಠ_ಠ
i didn’t hate it.
Old 07-25-2020, 03:09 AM   #2928
MrBrown
MrBrown's Avatar
I love my T5. No noises. Guess it’s the only lucky thing on my car so far. Oh and the exhaust heat wrap not rusting.
GhettoFab build thrizzie
Old 07-25-2020, 11:52 AM   #2929
LC4CARL
Aero challenged
LC4CARL's Avatar
Been buying and selling like a fiend trying keep a "net zero." LOL.
Actuator and injectors ordered. Late-model manifold heat shields are on the way. STS drain fitting here. ATP WG hardware / V-band / etc. en route. Need to revisit my exhaust flex thing choice.
Maybe start cleaning things up and replace the pan gasket while we wait on the exhaust manifold machine work.
@PDXvolvo on IG
Old 07-25-2020, 05:01 PM   #2930
MrBrown
MrBrown's Avatar
Nice!
Old 07-27-2020, 05:02 PM   #2931
LC4CARL
Aero challenged
LC4CARL's Avatar
Could one of those little plastic fuel injectors really weigh 30lbs?
Old 07-27-2020, 06:06 PM   #2932
patrickstar
patrickstar's Avatar
I did some super basic measurements with an AR5 while getting it ready for my 242 LS swap, and I have no idea why someone hasn't come up with an adapter kit for redblocks yet.
1983 Volvo 242 - 4.8/AR5
1984 Volvo 245
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 07-28-2020, 02:43 PM   #2933
kampman
dunning-krugersquirt
I have an AR5 that was originally slated for another project that didn't work out and I've often wondered how it would fit in my 245.
1984 245T
2006 V50 T5M
Feedback Thread
Old 07-28-2020, 03:32 PM   #2934
patrickstar
Packaging wise, it fit into my 242 with no hammering at all. Shifter location is suboptimal but that could be solved with the Solstice version. I measured input shaft length and it looks like it would work with an adapter plate and bellhousing, and the gear ratios aren't hugely different.
Old 07-29-2020, 12:11 PM   #2935
kampman
I have the Solstice version (it's actually still bolted to a Solstice engine, sadly not the turbo one though). Guess I know what I need to do if the AW71 ever craps out.
Old 07-29-2020, 12:27 PM   #2936
redblockpowered
redblockpowered's Avatar
M90 is pretty quiet, even with the single mass flywheel. Ratios aren't very good if you want to have a racecar.
I sell chips for LH 2.4!
Old 07-31-2020, 05:39 AM   #2937
Quin
ಠ_ಠ
well, feel free.
Old 07-31-2020, 10:33 AM   #2938
patrickstar
well, feel free.
If I didn't live in an apartment and had any of the skills necessary, perhaps I would. But, I make maps for a living and have no idea how a CNC machine works. Such is life
Old 08-01-2020, 11:00 PM   #2939
LC4CARL
Aero challenged
LC4CARL's Avatar
A couple years ago.
Old 08-02-2020, 11:44 PM   #2940
LC4CARL
Aero challenged
LC4CARL's Avatar
No time to wrench. Some parts are arriving. Pan came right off. Gasket was hard. Not the cleanest, or the dirtiest, motor I've seen.
PCV drain tube is hard but, probably, functional.
Just need the manifold and turbo oil lines.
Old 08-03-2020, 04:30 PM   #2941
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Looks good so far!
-Stephen
#mclovethesenuts
-My car: White 1991 244, 330k miles. B230F LH2.4, AW70, R134a retro
-Wife's car: White 1990 244DL, T cam, 200k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
Old 08-05-2020, 02:44 AM   #2942
77volvo245
77volvo245's Avatar
Replace the pcv hose and oil transfer tube pump seals when you already have the pan off. I would only use volvo oil transfer pump seals.
STSmachining
Old 08-05-2020, 09:46 AM   #2943
LC4CARL
Aero challenged
LC4CARL's Avatar
Thanks boss.
Old 08-09-2020, 03:51 AM   #2944
Kjets On a Plane
Kjets On a Plane's Avatar
^This & a late model transfer tube (matched to oil pump or have a few handy that fit best) & ~1989?+ OE 'tall' gear oil pump/egg beater is a nice addition to an '87 & earlier engine.
So, you removed the engine to do all this though?
So much heavy lifting/brute force for a few leaks! Impressive.
How PSI a stock can support?
Always Be Crushing!
Old 08-09-2020, 05:05 PM   #2945
LC4CARL
Aero challenged
LC4CARL's Avatar
Great idea.
You know me. First time I pulled it, years ago, was to degrease it; rather than fix an inop heater in the dead of winter...
But it will make it easier to swap the pan gasket this time.
Old 08-09-2020, 05:43 PM   #2946
Kjets On a Plane
^You need to go to the gym why again?
Tall gear pumps from 89-90 N/A cars tend to be lower RPM/less cooked oil/less beat up and tighter tolerance.
Squirter motors more oil volume/same pressure & run hotter on the e-fan cars, so they tend to be more beat up.
Get the tube with the pump is all if possible...tube seems to be matched to pump housing, block tolerance seems "similar" ( at that in redblock land) on all of them.
Old 08-15-2020, 10:14 PM   #2947
LC4CARL
Aero challenged
LC4CARL's Avatar
Yoshi to the rescue.
Old 08-15-2020, 10:15 PM   #2948
LC4CARL
Aero challenged
LC4CARL's Avatar
Flame Trap drain hose was kind of crushed.
Old 08-15-2020, 10:28 PM   #2949
LC4CARL
Aero challenged
LC4CARL's Avatar
Not much time to wrench. Maybe put the motor back in the car this week. Waiting on oil supply / drain lines. Need studs for the turbo (does a gasket go between the manifold and turbo?). Going to need a joiner or two for the intake. Injectors arrived. Exhaust flex thing arrived. Need to sort out the waste gate actuator. Manifold heat shields arrived (do I use the lower heat shield, between the manifold and the alternator, on the late model manifold?). Did Volvo stamp numbers on the big end of the con rods or has my engine been rebuilt? Losing the water cooling on the turbo, but I don't think that's a huge deal.
Sorting the down pipe will be interesting. Probably going to start the car with the small waste gate so I can connect the down pipe. Then drive it over to Robert's. Swap the ATP waste gate on at his place, then weld up the exhaust. Probably.
Don't know, what I don't know, at this point. Having fun.
Old 08-20-2020, 09:52 PM   #2950
LC4CARL
Aero challenged
LC4CARL's Avatar
