Old 07-17-2018, 01:17 PM   #26
jvluntzel
Originally Posted by oldnfast View Post
Just checked the car,I have the same ecu as yours above
you opened it up and it had the same motorola chip?
jvluntzel is offline   Reply With Quote
Old 07-17-2018, 01:28 PM   #27
jvluntzel
Another thought I had to assist with timing under boost was to use the ignition module from a renault turbo vehicle. They have a vacuum tap on the module that I believe is to assist with ignition retard under boost and advance under vacuum
Old 07-17-2018, 02:56 PM   #28
oldnfast
I didn't but did just now and the numbers on the chip are different.should I take pics then?
If yes then send me a pm with your contact info as I don't know how to post pics.also should I remove the board from case to see the backside?
oldnfast is offline   Reply With Quote
Old 07-17-2018, 03:27 PM   #29
jvluntzel
Yes please do!
I will send a pm right now. Take pictures of the front and rear of the board, and close ups of the chip part #s.
Old 07-18-2018, 09:41 PM   #30
jvluntzel
Turns out you have the same ecu as I do with the same motorola chip. Ill be checking out some ecus at the junkyard friday and will report back
Old 07-18-2018, 10:59 PM   #31
sbabbs
sbabbs's Avatar
Inside the Rex ignition box I got. You wanna adjust your ignition map also?
Old 07-19-2018, 12:15 AM   #32
jvluntzel
Very much so!
Old 07-19-2018, 01:40 AM   #33
sbabbs
sbabbs's Avatar
Is it the ST chip that I need to take out and read? What is that ST chip?
Old 07-19-2018, 09:14 AM   #34
My best guess for the ignition box is:
The ZC98902VP is another custom (mask rom) Motorola processor (VP=automotive rated 28-pin plastic pkg), probably a 6804 or 6805 family due to the smaller pincount (28 versus 40).
Based on the Fenix paper, the STMicro TSG4801AP (?) is a custom digital chip needed to decode the flywheel pattern.
One of the two 8-pin DIP chips might be a small serial PROM or EEPROM, to contain the key ignition map parameters. I'd try tracing the PCB wires between the processor and the 8-pin chips to see if they match up with a serial I2C or SPI interface (say clock, data, chip select).
Old 07-19-2018, 11:38 AM   #35
jvluntzel
Thanks so much for your assistance guys! I know this is a proof of concept but no matter what results in the end, it will never be a debate or questioned again.
Old 07-20-2018, 08:39 AM   #36
A couple more useful tidbits:
There's excerpts from a Volvo Greenbook that describe Rex/Regina in detail at:
https://people.ohio.edu/ridgely/Volvo_docs/
This includes full pinout and signal description charts on pages 28-34 (like the LH2.4 and EZK charts at ipdown, but for regina/rex). Rex provides a RPM/Tach signal to Regina; Regina provides a Load signal to Rex. Unlike LH2.4/EZK116, I didn't see a Rex to Regina Knock enrichment signal.
For Renault/Fenix, there's a good description of the fuel and ignition tables at:
http://www.fenixecu.com/injection-fe...phie?showall=1
The SAE paper on Fenix I describes the option of putting all the tables in an external PROM. If the 8-pin DIP chip shown in the board pictures is that PROM, then there's hope that the tables could be modified. The owner of fenixecu.com is the user "Manu" on the MegaSquirt forums (msextra.com/forums). He seems to be pretty active there, and writes in both English and French. Maybe you can contact him, show him the rex/regina board pictures, and ask if the 8-pin DIP chips are PROMs?
Old 07-20-2018, 11:11 AM   #37
jvluntzel
Thats funny you mention Manu, I have a thread on the megasquirt.fr page and he has been the primary assistance.
Link to my thread:
https://forum.megasquirt.fr/viewtopi...5&p=7779#p7779
