Weird Engine and Trans Issue 95 940T
1slo9_4_oh
Orlando
Weird issue. 1995 940t
Car is having a mis cold, warms up and then a miss between 5-6k and all while this is happening the trans is holding the gear.
All I did was replace intercooler piping, couplers and deleted the bov/reinstall cbv
Trying to diagnose it but anything I try, I have either fixed or have replaced in the past.
But feel free to chime in on any suggestions and I'll let you know if I have replaced/fixed/or overlooked
Car has gone through a Stage 0 phase.
Did a ipd turbo cam, 2.5 exhaust and do88 intercooler all within last 2-3 months.. disregard Sig- not the car I'm talking about
It looks like the issue has happened to a ton of people with no definite answer on a resolution. I'm leaning towards it being a bad tps switch
Tps won't cause that. Tps only tells the system if it is at idle or wot (non turbo). No affect of mixture or timing outside those two points.
Reason im guessing its a bad tps switch is when unplugged at idle the car returns to normal idle.. 850-9 and smooth. Plugged in its idling at about 450-500. And makes my ipd turbo cam sound like a vx stage 3 lmfao
