Old 04-20-2011, 07:29 PM   #476
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
I think Homer is running something off the crossmember, but the end result should be very similar.
The swaybar is wireless.
Fake Race Car
Old 04-20-2011, 09:59 PM   #477
Homer
OEMplus++
Homer's Avatar
Yep 960 upper mounts and a fancy crossmembery lower mount.
-Jacob:
2006 A4 - Comfy DD
Old 04-21-2011, 11:52 AM   #478
Cameron
ドクターマリオ
Cameron's Avatar
Cameron is offline   Reply With Quote
Old 04-22-2011, 12:50 AM   #479
Homer
OEMplus++
Homer's Avatar
Got some measurements before dropping the M47 off to its new owner.
The M90 total length (bellhousing to output flange) is 57mm shorter than the M47
M90 output flange to shift center is 250mm
M47 output flange to shift center is 95mm
Of course these measurements only help assuming the bellhousing flange is in the same position fore/aft as the M47 originally mounted in the car.
Also realized the starter on the redblock is the same series as the whiteblock starter. I can use the parts out of the 2 year old bosch redblock starter to rebuild the whiteblock one I've got.
Old 04-22-2011, 01:11 AM   #480
740tankDriver
Post-Hypnotic Sigma
740tankDriver's Avatar
heh, the M90 has such an elegant casing.
Happy Passover!
Great Victory!
740tankDriver is offline   Reply With Quote
Old 04-22-2011, 07:12 PM   #481
Homer
OEMplus++
Homer's Avatar
Dropped the M47 and head off with their new owner. Asked him if he had a 740 M47 front driveshaft laying around.
Score. Freebie.
Top-240 M47
Bottom- 740 M47. I'll get this one cut to the right length and the universal put on.
Old 04-23-2011, 04:01 PM   #482
shaved240
shaved240's Avatar
Score. Freebie.
Top-240 M47
didn't know the 740 m47 driveshaft was longer. Can you measure the difference between in length between the 740 m47 shaft, and the 240 one? the 740 one might work for a getrag conversion.
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 04-23-2011, 04:17 PM   #483
JW240
All idiot, no savant
JW240's Avatar
a 740 driveshaft is exactly 80 mm longer than a 240 driveshaft, when equipped with the same transmission.
Old 04-23-2011, 04:21 PM   #484
shaved240
shaved240's Avatar
thanks.
Old 04-24-2011, 06:34 AM   #485
VQ
Not such a PRVert Anymore
VQ's Avatar
Man, I didn't realise that there was 9 pages of no real action on the car! About time the engine comes out! The rest will happen quickly no doubt.
Old 04-28-2011, 12:31 AM   #486
Homer
OEMplus++
Homer's Avatar
Chinagate (44mm, 10psi spring) showed up, along with rebuild parts.
Nothing sketchy with the gate, we'll see how long (diaphragm) it lasts.
Old 04-28-2011, 10:38 AM   #487
Alex Buchka
8 cylinders
Alex Buchka's Avatar
It's people like you who are bringing down the US ecomony.
Old 04-30-2011, 01:53 AM   #488
Homer
OEMplus++
Homer's Avatar
It'll sit a tad higher than that.
Didn't really get much done, just got a bunch of measurements to go at it with the header in solidworks.
Old 04-30-2011, 02:29 AM   #489
the poi
Has been
the poi's Avatar
Oh MY GOD WILL YOU FINISH IT ALREADY JESUS
Old 04-30-2011, 02:33 AM   #490
Homer
OEMplus++
Homer's Avatar
Its like the pot calling the kettle black....
Old 04-30-2011, 11:02 AM   #491
towerymt
the real Towery
towerymt's Avatar
The real magic doesn't happen til the winter.
Old 04-30-2011, 07:39 PM   #492
Tom Wiley
Are you going to cast the manifold for total OEM+ status?
Tom Wiley is offline   Reply With Quote
Old 04-30-2011, 11:41 PM   #493
ZVOLVO240
ZVOLVO240's Avatar
are you going to put a slim brake booster in there or keep the original one.
- Will Z
1989 244 DL - - - Beige N/A
1988 245 DL - - - Original owners/Dad's Car
1991 244 Turbo - DEAD
ZVOLVO240 is offline   Reply With Quote
Old 05-01-2011, 04:15 AM   #494
Homer
OEMplus++
Homer's Avatar
Original. Intake fits fine.
Old 05-09-2011, 12:22 AM   #495
Homer
OEMplus++
Homer's Avatar
Sorta a useless post, but I'm going the route of bottom mount turbo. After much engine bay staring, it should be easier.
Old 05-09-2011, 12:26 AM   #496
Poik
Backwards Turbo
Poik's Avatar
Are you mounting it forwards or backwards?
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 05-09-2011, 12:28 AM   #497
Homer
OEMplus++
Homer's Avatar
backwards
Old 05-09-2011, 02:19 AM   #498
shaved240
shaved240's Avatar
I wouldn't trust that the spring inside the china crap is 10 psi. All the springs I've gotten were 20 + psi springs.
Old 05-09-2011, 02:46 AM   #499
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Mine came with multiple springs and they all worked out to what they were claimed to be.
Bottom mount FTW.
-Kenny
Old 05-09-2011, 03:27 AM   #500
Jerd
Jerd's Avatar
My chinagate ran solid 12psi worked amazing
