Hey man. Have you sorted the car? Would love some more feedback on how it has been.
Car is running again. I agree that a 3.5 would be good, i to sometime run 1,3,5 shift pattern in light traffic at the lights if im at the front of the que.
I personally wont change though, i may go 8.8 but not before the end of the year. The reason is the same as the decision for my change to this over a t56. I wanted the very short 1st, and close ratio for dragracing. (Though im to scared of my diff blowing for that yet)
Its fine to drive but it is quite noisy, (only on deceleration sounds like they just have large backlash) they aparently quiet down with redline fluid, i have castrol fluid in it. All the Z guys reccomend nothing but redline. It prolongs the life drastically and saves the synchros.
I have met a few guys with good power Z's and they do still blow synchros if you dont have top quality fluid in them and over 300ish hp.
AdamLz has snapped an input shaft in a 4th gear clutch drop burnout. So they are proving incredibly strong when well looked after.
Personally i like it, my bracket adaptor worked very well.
If anyone ever wants the drawing they can DM me and ill email it to you. i would like to stress again THERE IS NO NEED FOR CUSTOM TRANS MOUNT IN A 7/9. you can move the manual trans mount to the auto location and use the adaptor plate i made.
The only issue i have had was with the new clutch and flywheel. My master and slave diddnt like it and burst seals, the both got rebuilt then needed retaining circlips put in and longer actuator rod to stop it pushing to far. But other than that its been good.
