monkecmonkedo
Bored Member
- Mar 28, 2005
- Manchester Center, VT
Any experts on PRV cams here? I've got three I need help identifying:
From left to right (edited for anyone who needs this info in the future):
1) Box marked 1277821. It has a distributor gear, so it's a LH cam. The end by the distributor gear is "skinny" at 24.8mm. The intake and exhaust lift are both 5.08. Part number search says it fits B27A/F 75-79 260.
2) Volvo OEM in a tube marked 1269979-9. It has a distributor gear, so again, LH cam. The end by the distributor gear is "fat" at 32.41mm. The intake and exhaust lift are both 5.99. Part number search says it fits B28F 80-86 260/760.
3) Unipart box marked GKC-25. It has a lobe where distributor gear would be, so LH cam. The end is "fat" at 32.41mm. The intake and exhaust lift: are 5.96 and 5.42 (give or take, and I’m not sure which is which). I can't find any info about Unipart GKC-25. It fits B280F 87-90 760/780, corresponding to Volvo 247958.
I don't know the duration or any other info, as I only have a micrometer. Here's some more pictures and feel free to ask any questions. Thanks for your help!!!
