Old 03-05-2015, 09:04 PM   #1
chris gilmour
Default small tach install
i have a volvo tach that goes in the small gauge pod to the right of the cluster. i robbed it out of a parts car, and was wondering what needs to be done to make it function?
the car is a 91 245 with lh.2.4 (if thats at all relevent) came out of a 90' 245
are the wires already back there or do i have to run wires?
btw i tried searching but all i found was big tach swaps, and that apparently these little guys are kinda rare
chris gilmour is offline   Reply With Quote
Old 03-05-2015, 09:08 PM   #2
Old 03-05-2015, 09:18 PM   #3
chris gilmour
bam! thanks!
Old 03-06-2015, 11:52 AM   #4
cleanflametrap
cleanflametrap's Avatar
Nitpicker that I am just can't help* pointing out the lighting wire colors are labeled backward. Gray is power from the dimmer rheostat, and the black wires are the ground side. Shouldn't really matter when just adding this tach.
*that and the weather-related slow season
-Art
Old 03-06-2015, 02:18 PM   #5
Oh it matters, trust me.
My favorite electrical "Event" was the Volvo I bought from auction that was "stolen". A stolen 940, yeah, right. The PO screwed the ignition lock all up trying to make the car look like it was stolen. I knew nobody succeeded at stealing the car, that it was insurance fraud. I figured out why the PO did the fraud when I replaced the ignition lock and tried to start the car. No spark. Upon close inspection of the ignition circuit I notice a small black wire with all the insulation burned off of it. The numb nuts used the OBD 1 test probe to power the AC compressor. I'm not making that up. It of course, overloaded the wire burning the insulation off it all the way to the EZK and took out a bunch of other wires in that harness as well. Even the cigarette lighter ground wire was melted in the process. I installed a used replacement EZK harness and ended up with a really nice black on black, 940 Turbo sedan.
Old 03-06-2015, 08:55 PM   #6
theknave
theknave's Avatar
I thought the same, but I thought that grey was brown, and I thought all dash wiring in a 240 is typically brown. Is it not?
'86 240 DL, M46 - Primer grey, yellow, silver and flat black.
'90 240 DL, AW70 - Rotting, with its guts out, on the cadaver table... the AW70 is nice tho, with a recent full fluid flush via tt 500, and an all new Yukon set of bearings (Timken) and seals at the rearend, new SKF bearings and seals at the axles.
theknave is offline   Reply With Quote
Old 03-07-2015, 07:57 AM   #7
cleanflametrap
Oh, brown? I'm still wondering at that doily in the background if that's what that is...
Old 03-07-2015, 10:58 AM   #8
24DinCT
Don Juan De La Nooch
24DinCT's Avatar
When it comes to a standard filament bulb...polarity is a non-issue.
You can flip the two wires for the bulb and it'll still work...as long as the ground wire goes to ground and the power wire goes to the illumination circuit.
If running an LED bulb...THEN polarity makes a difference.
83 244 DL+Ti---Being parted
82 242 TI project---bare bones, shaved, and tucked...never gettin done
Originally Posted by blackbrick82 View Post
It's all about the beer.
how come everytime i in the kitchen, you in the kitchen, in the god damn refridgerator
Buy my partz...here
Feedback...here
24DinCT is offline   Reply With Quote
Old 03-07-2015, 02:17 PM   #9
theknave
theknave's Avatar
Well it's cute, if anything.
