- Dec 23, 2006
- Rushing Lane, Scappoose, OR
We'll with lh2.4 I had better luck with the 012 3 inch amm. I bought an 025 amm on ebay brand new and it never worked right...
The 3 inch 012 amm matches about 50lb hour injectors with a stock lh2.4 ecu bin. So unless you are changing something else leave the injector constants stock.
Or go with a stock 016 amm and adjust the injector constants for the bigger injectors.
Or put a 016 in a 3 inch tube is what I did.
Have you checked the codes?
Also if this thing had a piggy back in it at one time, were wires cut to install it? I'd check all that... Piggybacks don't work with lh2.4 as it will learn around it...
