Old 05-18-2015, 11:57 AM   #1
propav8r
F*ck Edgar
propav8r's Avatar
Default Stripping paint from engine bay
Hi all...so a few years back when I B230F+T swapped my '79, I painted my engine bay black for a bit of a cleaner look. There was some rust and peeling original paint, and I just wanted it to all look nice again.
I used a Rustoleum rattle can (high temp black gloss) and it held up surprisingly well.
Anyway, the time has come to get the whole car painted, and I want to color match the engine bay. In order to cut down on prep time at the body shop, I'd like to go ahead and strip the engine bay. I'm not sure that real automotive paint would adhere well on top of the rattle can stuff that's in there now.
My question is...what's the best way to go about this? I don't have air at the house (so blasting is out.) Is there a good paint stripping chemical I can use, or should I just plan on loading the whole car up on a trailer and taking it to someone who can blast it clean?
Pic for reference...
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 05-18-2015, 12:01 PM   #2
Stiggy Pop
Stiggy Pop's Avatar
Sand it. Kinda sucks without air and a DA... but I'd sand it before I got into the Tal-Strip stuff that's going to be a mess.
'79 242
943 pickup
Old 05-18-2015, 12:03 PM   #3
propav8r
F*ck Edgar
propav8r's Avatar
I've been putting off buying a decent sized air compressor for awhile now. Maybe this is the excuse I need.
I put like 5 or 6 coats on the bay. Manual sanding would be a giant pain.
Old 05-18-2015, 12:21 PM   #4
A million rollocks or try to float that lacquer out of there with easy off.
Old 05-18-2015, 12:53 PM   #5
Pro Sneaker Peddler
http://www.autozone.com/paint-and-bo...er/660022_0_0/
Proper disposal required.
Old 05-18-2015, 01:09 PM   #6
amerbritcan
Hnnnnnng
amerbritcan's Avatar
I've never used a chemical stripper but I feel like that'd be the quickest and easiest way.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 05-18-2015, 01:14 PM   #7
AndrewNance
Amateur hour!
AndrewNance's Avatar
I used some Jasco on my style 5s to get the clearcoat off. It just rinsed clean after about 15 mins. It might take a couple coats but I'd give it a shot.
'71 142
'80 245
Feedback
Old 05-18-2015, 01:37 PM   #8
cwdodson88
I have used this, and it does ok, but cleaning after stripping is a PITA, had to use POR 15 Marine clean like 3x to remove the visual residue, then metal ready just in case.
The Build Thread
SVEA - PUSHROD TURBO!
Old 05-18-2015, 01:41 PM   #9
2manyturbos
Jasco is on the low end of efficiency. The best over the counter stripper I have used is Klean Strip Aircraft Stripper. It will peel the paint right to the metal in no time. It must be completely washed away or it will ruin any new paint being applied.
This stuff. It comes in aerosol cans, gallon cans, 5 gallon cans.
http://www.handsontools.com/Klean-St...n_p_11189.html
If you want to use T-Bricks level products, old dirty Dot 3 brake fluid will peel paint right to the metal.
Old 05-18-2015, 01:44 PM   #10
Jack
Banned
Jack's Avatar
Old 05-18-2015, 01:55 PM   #11
Stiggy Pop
Stiggy Pop's Avatar
I do like Tal-Strip the best.
I would remind you heading into it, should you go that route, don't think you're getting away without doing any "mechanical" stripping. The stripper will lift up the old paint and turn it into a sloppy gelly mess. It's not going to just fall off from looking at it. You'll peel big satisfying swipes away with a putty knife, then be left picking and scratching everything else. Edges, corners, lines etc will probably require a 3m pad or something to scratch away the softened up paint. The fun part is now everything is caustic and burns your skin and is generally unpleasant to be around. You WILL end up sanding afterwards.
Yeah, it'll get the paint off, but an engine bay isn't going to just wipe off clean like clear coat off of a perfectly smooth polished aluminum lip on a wheel.
Old 05-18-2015, 02:14 PM   #12
2manyturbos
^^ Add a fine bristle brass brush to that process and you won't be picking and paint off afterwards. I have stripped way too many cars over the years and have learned how to make this process as painless as possible. Welding supply stores, auto parts stores etc have fine bristle brushes with wood handles that are slightly larger than a tooth brush. Those work wonders for getting all the paint that is in the seams where the panels overlap.
Old 05-18-2015, 08:59 PM   #13
nel621
The key to using paint stripper is NOT to take it off as soon as it starts to bubble. Add MORE remover on top of this mess and maybe lay some plastic wrap over it so it won't evaporate to quickly. Then start scrapping it off. Use good chemical resistant gloves, work outside, don't get the sh*t in your eyes. Keep the fumes away from your eyes. Scrape that stuff onto newspaper and double bag it. Shouldn't really go in trash but that's your call.
Old 05-19-2015, 06:10 AM   #14
mopar318
mopar318's Avatar
If you used lacquer paint, acetone will take it right off.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 05-19-2015, 06:57 AM   #15
Tuff240
240 Ninja
Tuff240's Avatar
99.9% of it needs to be removed or it will cause problems with the real paint.
You are in for a lot of fun!
-Patrick
Old 05-19-2015, 07:02 AM   #16
Tuff240
240 Ninja
Tuff240's Avatar
But it is all worth it...
Old 05-19-2015, 05:05 PM   #17
Mark
sex lights
Mark's Avatar
I was in the same boat- PO of the v8 car used some sorta hammertone black paint underhood.
I chemically stripped to bare metal.
Filled the holes and smoothed the wrinkles
Primed and sanded several times
And finally painted base/clear.
Turned out okay, but it was months of my spare time and I've barely done a thing on that car since then.
M.
Originally Posted by Double02 View Post
Classic TBricks - pages of discussion debating whether or not to spend $20. On a tractor.
Incorrect, the Frigidaire is Mark's 86 745. It's in appliance white and it is Best Car.
The Fridge; '86 745 DD-with full '94 LH2.4 swap. Now with M90!
2000 AMG E55 wagon.
'78 Honda GL1000- naked Goldwing.
'76 265 wagon with Megasquirted 350 chevy and T56. Scrapped
Mark is offline   Reply With Quote
Old 05-20-2015, 02:03 AM   #18
elmford1
elmford1's Avatar
900 is way overkill almost to the point of lack of adhesion for most base coats. 400 is the norm
elmford1 is offline   Reply With Quote
Old 05-20-2015, 03:21 AM   #19
77volvo245
77volvo245's Avatar
Pervious owner repainted the engine bay black, they did a pretty good job. They used quailty paint, it made it easier for us to get the engine compartment prep for paint.
Primer seal and wet sand stages 300, 600, 900 grit sand paper.
STSmachining
Old 05-20-2015, 04:18 AM   #20
Tuff240
240 Ninja
Tuff240's Avatar
Originally Posted by 77volvo245 View Post
...wet sand stages 300, 600, 900 grit sand paper.
Holy crap, 900?!?
Old 05-25-2015, 12:19 PM   #21
24DinCT
Don Juan De La Nooch
24DinCT's Avatar
http://www.blast-it-ilm.com/contact-us.html
http://evolutiondustlessblasting.com/contacts.php
Orr....just a little closer to home for you...
http://www.customcreationsblasting.com/dustless.html
Some of them even come to you...
Less sand/mess, no chance of silicosis, and less sheetmetal warping to due sand abrasion/friction
Most places that do this can come to your house/workshop/whatever...and it can be done pretty quickly for a relatively nominal fee.
If just doing under the hood...they can probably get it done in 15-20 minutes.
83 244 DL+Ti---Being parted
82 242 TI project---bare bones, shaved, and tucked...never gettin done
Originally Posted by blackbrick82 View Post
It's all about the beer.
Originally Posted by blkaplan View Post
how come everytime i in the kitchen, you in the kitchen, in the god damn refridgerator
Buy my partz...here
Feedback...here
24DinCT is offline   Reply With Quote
Old 05-25-2015, 01:23 PM   #22
2manyturbos
Originally Posted by Tuff240 View Post
Holy crap, 900?!?
There is no reason to ever sand with 900 when prepping for paint. 500 wet/dry is as fine as it needs to be. The primer/sealer will cover up 500 grit sand scratches easily.
Old 05-25-2015, 01:37 PM   #23
Tuff240
240 Ninja
Tuff240's Avatar
I was told/taught anything over 600 and you could run into paint adhesion problems.
Hell, I've cut paint with 1000 before...lol.
Old 05-25-2015, 01:50 PM   #24
2manyturbos
That is exactly the issue. You want some "tooth" for the paint to adhere to. When you are painting over factory baked paint, the mechanical bond is the component of the adhesion between the existing paint and the new paint. I cut paint with 800-1000 grit for the first step of cutting/buffing.
Old 05-25-2015, 10:25 PM   #25
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I gotta agree with Pat here. I rarely sand above 400 on primer for anything I spray color (and I spray 2k urethanes every day).
all of those posted look amazing.
(BTW a wire wheel on a drill after hitting it with easy-off will knock the majority of that paint off pretty quick).
