Old 01-21-2016, 08:48 PM   #1
240Dluxe
Default 240 Wiring Need Help Troubleshooting
I have a volvo 240 wagon that I'm trying to get road ready by the time I get my license but I need some help. None of my gauges work and the only dash lights that come on are the brights and blinker lights. I took the gauge cluster out and tested it with a multimeter and it seems fine. Also I have another gauge cluster taken form a parts car and the same thing happened when I installed it. I then assumed it was the wiring in the dash but I don't know how to test it. The alternator doesn't charge because the bulb on the dash isn't completing the circuit. I'm not very knowledgeable about wiring so an help would be greatly appreciated.
240Dluxe is offline   Reply With Quote
Old 01-23-2016, 12:42 PM   #2
24DinCT
Don Juan De La Nooch
24DinCT's Avatar
1st....welcome to TB
2nd...You posted this in the wrong section. Maybe try maintenance & nonperformance
3rd...Put up a little more info when asking questions. Make & model are obvious here...but you didn't say what year. Also...list any mods (if any at all) to help narrow things down a bit further. The more info you can give us, the better we can help you out.
Did you check ALL the dash bulbs for continuity to make sure they all actually work?
If you have more than just 1 gauge that's not working...is anything else in the car (electrically) not working? For example....lighter, radio, dash lights/illumination
Volvo tended to put more than 1 electrical item on each circuit/fuse....so if more than just your gauges aren't working...this might narrow it down to just a blown fuse. Did you check all your fuses for continuity with a meter?
83 244 DL+Ti---Being parted
82 242 TI project---bare bones, shaved, and tucked...never gettin done
Originally Posted by blackbrick82 View Post
It's all about the beer.
Originally Posted by blkaplan View Post
how come everytime i in the kitchen, you in the kitchen, in the god damn refridgerator
Buy my partz...here
Feedback...here
24DinCT is offline   Reply With Quote
