Old 06-19-2016, 12:49 PM   #1
petebee
Default Left turn signal activates headlights...bad relay?
Weird symptom, when you use the left turn signal on my 93 240 it turns on the headlights and does not activate the blinker. Lights come on without the switch turned on, and won't go out until you disconnect the battery (stay illuminated when car is turned off).
Bad relay? I know there are two - one under the dash on driver side and another behind the battery (that one switches low/hi beam function I think).
petebee is offline   Reply With Quote
Old 06-19-2016, 12:58 PM   #2
coalminer
The only common denominator that I know of between the headlights and the turn signals is the turn signal switch, which also houses the bright/dim switch for the headlights. This is where I would look first.....at the turn signal switch on the steering column.
Maybe others will jump in.
coalminer is offline   Reply With Quote
Old 06-19-2016, 03:50 PM   #3
tiredoldtommy
tiredoldtommy's Avatar
Bad ground somewhere.
When you're a tired old gimp²,
you get easy to please.
'03 C70 HPT drop top 95k (stylin cruiser)
'83 242 turbo, 305k (ridge runner)
'84 245 NA, 248k (hauler/tractor)
'66 New Yorker, 440 4bbl (needs a new home)
'84 244tic (project or parts? definitely parts)
tiredoldtommy is offline   Reply With Quote
Old 06-19-2016, 07:21 PM   #4
badvlvo
Bad for Babies
badvlvo's Avatar
That ^^. Most electrical problems with lighting on older Volvos are related directly to bad grounds. Find them, and clean them.
Died at age 35
Old 06-19-2016, 08:19 PM   #5
johfraser
Something is loose or broken in the lever mechanism.
johfraser is offline   Reply With Quote
Old 06-19-2016, 09:09 PM   #6
petebee
I am thinking that it is probably the switch. I have a backup unit but includes wiring for cruise control as well. It looks fairly easy to swap...I'll check the connectors to see if we can simply install w/o the cruise stuff (my car has no cruise control).
Old 06-19-2016, 11:07 PM   #7
Harry Tuttle
This is likely, and easiest to check before you start throwing parts at it. There are some grounds in the LF corner that are worth looking at. Especially the ones that have multiple wires on them.
Originally Posted by dl242gt
It's always better to get into a turbo volvo and drive.
Old 06-20-2016, 09:47 AM   #8
Yeah likely bad ground or short circuit. I had a 740 that when you honked the horn, the rear wiper would go.
Check for bad wiring up front. It degrades by the lights.
