Old 01-16-2017, 08:20 PM   #1
alschnertz
Enough already!
alschnertz's Avatar
Default What type of antenna connector is this?
2001 S40
Long story short...I have to replace my antenna - not just the mast, the whole thing.
So I found one at the pnp but the antenna lead end was cut off. The replacement antenna works (goes up and down) but the end is missing.
The photo below is what the end connector should look like. This connector fits the factory wiring on the S40. It's not a typical motorola connector.
I don't think I'll have a problem replacing the connector, it's just that I don't know what type to search for.
Anyone know what this type of connector is called?
Old 01-16-2017, 09:14 PM   #2
cleanflametrap
cleanflametrap's Avatar
Someone does. Not I.
Never seen one like that in a car, but I daresay I haven't seen the insides of many cars made beyond 1992. It reminds me of a push-on (quick connect) F connector, like what your TV uses for coaxial cable, but I can't get a handle on size reference in the picture.
-Art
Old 01-16-2017, 09:35 PM   #3
alschnertz
Enough already!
alschnertz's Avatar
It's very similar to a quick connect style fastener.
Dimensions? 1-3/8" long; Outer sheath 1/2"; Inner silver part 1/4"
The antenna wire itself appears to be typical coax cable.
Old 01-16-2017, 09:54 PM   #4
cleanflametrap
Learning stuff as I look through image search results...
The F-Type and SMA connectors have their labels mixed up.
https://en.wikipedia.org/wiki/Belling-Lee_connector
Last edited by cleanflametrap; 01-16-2017 at 10:15 PM.. Reason: The image has the connector labels mixed up.
Old 01-16-2017, 10:01 PM   #5
alschnertz
Enough already!
alschnertz's Avatar
I was searching earlier too, but just couldn't find it.
Lots of adapters to go into a radio, but not what I'm looking for.
Definitely not a threaded connection. Kind of close to the IEC above, but that's not it either.
Old 01-16-2017, 10:08 PM   #6
cleanflametrap
That picture I thieved is wrong anyway. Didn't realize it until I saw it in the thread.
On ebay I see what looks like yours referred to as an ISO connector. Mostly they sell adapters from that to Motorola. Searching "car radio antenna connector."
Old 01-16-2017, 10:40 PM   #7
alschnertz
Enough already!
alschnertz's Avatar
Came across this site
http://www.mcmelectronics.com/browse/RF/0000000645/p/2
Will have to look closer tomorrow after work.
Thanks for the help AB.
Old 01-18-2017, 09:13 PM   #8
24DinCT
Don Juan De La Nooch
24DinCT's Avatar
Where is this connector you have pictured located in the vehicle?
I'm assuming it's for the radio
83 244 DL+Ti---Being parted
82 242 TI project---bare bones, shaved, and tucked...never gettin done
Originally Posted by blackbrick82 View Post
It's all about the beer.
Originally Posted by blkaplan View Post
how come everytime i in the kitchen, you in the kitchen, in the god damn refridgerator
Buy my partz...here
Feedback...here
24DinCT is offline   Reply With Quote
Old 01-19-2017, 07:10 AM   #9
alschnertz
Enough already!
alschnertz's Avatar
The connector in the photo is the lead (male) end at the antenna.
The antenna has a 9" +/- whip connected to it. The photo is the end of the whip which is in the trunk.
The one in the photo is the good end on the bad antenna.
I hope that makes sense.
Thanks
Old 01-22-2017, 03:30 PM   #10
alschnertz
Enough already!
alschnertz's Avatar
Didn't have luck trying to find a new end coupling so I soldered the old coupling to the replacement antenna wire. What a small gauge wire that is.
Regardless, it's back installed and working again.
Thanks for the comments and inspiration.
