Old 04-12-2019, 08:28 AM   #1
Maligantblue
Default Cost effective turbo td04-20t...?
Hi all
I know this has been debated to death but.... The kingawa td04-20t seems like a cost effective bolt on turbo upgrade for my build. I'm aiming for high 250hp or enough tha I don't kill my m90 gearbox. I would rather not buy a new mani. Is there a better alternative to the bolt on td04 upgrades?
Green top injectors
Ecu emu standalone
Standard intercooler for now
Forged rods
Stock head
Kjet fuel system (pumps haha)
Cheers!
Maligantblue is offline   Reply With Quote
Old 04-12-2019, 08:38 AM   #2
tryingbe
Boosting along.
tryingbe's Avatar
Kjet fuel system
Wait, what?
85 GLH 367whp
00 Insight mpg > yours.
Old 04-12-2019, 09:48 AM   #3
iHateVolvoPeople
Originally Posted by tryingbe View Post
Wait, what?
He probably means KJET pumps.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 04-12-2019, 10:17 AM   #4
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
td04. yuck.
Megasquirt Tuning!
Old 04-12-2019, 11:45 AM   #5
80/20 speed parts club
Yeah that's a hellish turbine-compressor sizing mismatch.
A 15g made 225whp with little effort. Try that instead.
Old 04-12-2019, 11:49 AM   #6
JW240
All idiot, no savant
JW240's Avatar
They aren't really expensive but for 250 hp you could get away with a 16t.. That is cost effective. Besides.. 20t/td04hl = Compressor/turbine mismatch IMHO.
If a 900$ turbo is an option, I'd look around and check prices of GT series Garrett or BW EFR. If you can stretch the budget, you're more than halfway there
Old 04-12-2019, 12:00 PM   #7
white855T
Garrett 50 trim and you wouldn't have to change manifold(less $$ than the 20t), just plane it flat.
Buyer/Seller Feedback
Old 04-12-2019, 12:46 PM   #8
culberro
culberro's Avatar
Correct me if I'm wrong, but I'm pretty sure the turbine housing on the Kinugawa turbos is 6cm or 7cm^2, which is substantially larger than the 4cm^2 that the 15g is... but still small when compared to a Garret t3 with 0.48 AR.
Old 04-12-2019, 12:56 PM   #9
I would skip the 20t. Maybe something like a 19T with a billet wheel... Unless you get a better flowing turbine for the 20T to reduce the back pressure.
definitely run a straight ported or angled housing, none of that conical ****.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-12-2019, 01:00 PM   #10
15g uses a 6 or 7 cm housing
Old 04-12-2019, 01:01 PM   #11
drift256
Default 250hp
Would you mind divulging the details on your 250hp setup? I'm going for similar numbers with my 15G. Not sure what it will take, but I'll be using a 15g with ported housing, ported manifold, IPD turbo cam, 3" turbo back exhaust. All on a 1990 745T.
drift256 is offline   Reply With Quote
Old 04-12-2019, 01:40 PM   #12
culberro
culberro's Avatar
Huh, I always thought they were 4 or 5...
Is the flat flanged 6cm and angled flange 7cm^2?
Old 04-12-2019, 02:16 PM   #13
sbabbs
sbabbs's Avatar
15g, A cam, 2.5 inch side exit straight pipe. 550cc injectors, 3 inch AMM. Stock 84 B23FT lh 2.4
232 Rear wheel Horseypower. 277 rear wheel torques. 12.61 in the quarter mile.
OHh yeah almost forgot, weighted in at 2400 dry. Lexan, aluminum hood, scaped out every bit of sound deadening. Cut out side impact beams in the doors with torches. Ditched everthing not needed to run, but still kept everything for street legalities plus extra heavy handling crud, bigger bars and bars added like upper and lowers and bigger brakes even.
Old 04-12-2019, 03:17 PM   #14
Maligantblue
So for interest, the 16t 19t and 20 are all roughly the same price and bolt on. And about <£600 Wondering i its worth getting the 20t rather than smaller.
Edit to initial post
Old 04-12-2019, 05:28 PM   #15
soclosenotnear
I see you talk about this car all the time and was always curious how much you really removed as far as weight. That's some insight. Was that an m46 car? Any thread on it? I realize it's easy and simple stuff.
But for op, that about proves a 15g or better will get you there. Would definitely be the most economical.
Old 04-12-2019, 05:35 PM   #16
sbabbs
sbabbs's Avatar
It was a stock m46 car, but i put a getrag 265 in it and 3.31 ratio rear and no rev limit tune. I could do 120 in third at about 7k. That dyno pull was in third also. Plenty of other vids on my youtube channel. The damage one is the one after the dog dish flywheel exploded at 7k in the burnout box at PIR. I turned a rod bearing in the b23ft so I put in a squirter b230ft and did 12.7 all days till the flywheel exploded. Car is gone now working on getting my 90 745 cut down weight wise for this summer.
Old 04-12-2019, 05:45 PM   #17
Iirc you can find a 7cm flat flange from Kinugawa. All of the flat and conicals from Volvo are 6cm. Most of the angleds are 6, some (like off of a P80 R) are 7cm.
Old 04-12-2019, 05:49 PM   #18
LC4CARL
Aero challenged
LC4CARL's Avatar
Sub-scribed.
Life begins at 10PSI.
Old 04-13-2019, 03:07 AM   #19
Acke
I have a straight 7 hotside that is supposed to be from a volvo 13G. Part # 115 89 11810 7. Left in the pic, right is a conical 6.
Old 04-13-2019, 07:53 AM   #20
apachechef
Burnt Sierra Madre
I just got a Kinugawa 7cm flat flange housing with a clockable 20T compressor, for 799 shipped.
email them and they will configure it as you wish.
Dammit, Lummert.
Old 04-15-2019, 05:30 PM   #21
The Volvo straight housing I have is a 7cm. Pretty sure it was originally a 15g before i upgraded to a 19T
Old 04-15-2019, 06:52 PM   #22
soclosenotnear
Does 6 and 7 cm refer to the part of the hotside that meets the exhaust? So, if one were grinded out to 3", it wouldn't matter what it started life as?
Old 04-15-2019, 08:40 PM   #23
sbabbs
sbabbs's Avatar
No the numbers refer to the size of the exhaust housing around the turbo exhaust wheel. Nothing to do with the in and out holes. I got a couple flat flange ones I guess I'd better see what size they are. I'm assuming 7 but I'd better check. I got a 19t to put to use here at some point.
Old 04-17-2019, 04:34 PM   #24
its like the metric version of a .48 hotside vs a .63 hotside.
Old 04-18-2019, 01:03 PM   #25
DET17
Reformed SAABaholic
Yes, as is the one I'm running. MITSU part numbers confirm the area is 7cm2.
