Hi everyone,
Would like to ask your opinion about my compression test results on my b230ft in a 250K + mile 88' 740. The car sat for 3 years before I stated driving it again 2 years ago. Lots of blowby, no piston slap.
Not sure on the accuracy of the gauge I used but I got ~120psi wet and dry in cylinders 1,2,4 and ~80 psi dry, 120 psi wet on cylinder number three. I performed the test correctly, however only ran the car for a few minutes before starting (temp gauge maybe 1/8 of the way from cold). Last compression test I performed, maybe 30K miles ago, gave me ~135psi on all four and the car was at operating temperature.
Other than the poor results the car runs and drives just fine, idles a little rough when first started, with decent power and boosting to about 10psi. Last couple of 180 mile highway journeys at 75mph gave me ~26mpg and I average ~22mpg with combined driving.
You think I'll be alright continuing to drive to work and that?
I'm hoping it's stuck piston rings that I can free up. What do you think the chances are that the number 3 cylinder has broken ring lands or rings or just wore faster than the rest? Or, what's the chances that cylinder #3 has stuck rings?
I don't have the time, money, or garage to open up the engine, hence trying to get informed opinions. Thanks for any good or bad news you may have for me.
