Old 05-15-2018, 09:24 AM   #1976
LC4CARL
Aero challenged
LC4CARL's Avatar
Life begins at 10PSI.
Old 05-16-2018, 11:33 PM   #1977
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 05-17-2018, 09:20 AM   #1978
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Moar powar!
-Stephen
#mclovethesenuts
Old 05-17-2018, 09:26 AM   #1979
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Sweet. Something about having a boost control inside the car.
Me personally I would not run that into the car, keep the lines on it as short as possible to hedge against spikes and creep.
Your plan is a tried and trued method, get to work!
1980 242 Turbo
2004 V70R
Old 05-17-2018, 09:30 AM   #1980
KeizerBrickGuy
Sh*t pot stirrer
I was going to talk about that. lol Beat me to it. Besides, if you mount it in one of the corners by the strut tower/firewall it will look clean and keep it nice and short.
Old 05-17-2018, 09:32 AM   #1981
LC4CARL
Aero challenged
LC4CARL's Avatar
Good to know.
Plan has been to attend the early summer shows then rip and tear. Got a plate full of DIY distractions around the house, but things are actually happening on the turbo front.
Old 05-17-2018, 09:34 AM   #1982
LC4CARL
Aero challenged
LC4CARL's Avatar
Yeah, but...it's shiny...
So easily distracted. Almost bought another 245 because it had some cool stuff. Staying focused now.
Old 05-17-2018, 09:36 AM   #1983
LC4CARL
Aero challenged
LC4CARL's Avatar
Can most muffler shops put together a lo-buck down pipe? Front and rear V-bands, O2 bung for the gauge, flex thingy. What should I expect to pay?
In all sincerity, I haven't worked out how to get this to the shop yet with the turbo in and no exhaust. Does the LH O2 go in the bottom of the manifold? If so, the car should run and I could drive it a mile or two, open after the turbo. Or, I have a factory down pipe. I could leave the factory WG on and, with the factory header, drive it to the shop with that. Then swap the WG there after an hour cool down. Tow dolly?
Old 05-17-2018, 09:49 AM   #1984
LC4CARL
Aero challenged
LC4CARL's Avatar
Ordered the Kjet plugs from STS and the AMM wire extension from White855T.
Still got the three holes on the exhaust side of the cylinder head to sort. They have been fixed once with a coil or insert, so the holes are getting largish. Maybe go from an 8 to a 10mm with insert on these? More to come.
Old 05-17-2018, 09:53 AM   #1985
oldschoolvolvo
oldschoolvolvo's Avatar
LH O2 sensor goes in the downpipe near the turbine exit.
-Mike
1998 V70 T5
|Feedback|
Old 05-17-2018, 09:55 AM   #1986
Uncleknucklez
bruspeed
I have a chopped 940 DP that fits a 240 now, I will bring it to IPD, maybe we can work out a trade or something.
Oh, just realized the issue is with the Vband flange. Either way let me know and I will bring it, It is a conical flange DP with two O2 sensor holes.
Old 05-17-2018, 09:57 AM   #1987
LC4CARL
Aero challenged
LC4CARL's Avatar
Ah, so no downpipe, no run?
Old 05-17-2018, 10:03 AM   #1988
No but on the 240T log manifold it does.
Old 05-17-2018, 10:15 AM   #1989
LC4CARL
Aero challenged
LC4CARL's Avatar
Nice catch. So LH in the pipe, Kjets in the log?
And I could likely start and run the car with the LH O2 in the Kjets position on the log?
Old 05-17-2018, 10:37 AM   #1990
Cwazywazy
Cwazywazy's Avatar
Mine ran fine with the o2 in the log manifold it used to have.
I don't know what I have
Old 05-17-2018, 11:14 AM   #1991
Broke4speed
Broke4speed's Avatar
Your car will run fine without the O2 in the exhaust stream, if it's just for a short trip to the exhaust shop. The O2 is only for closed loop idle and cruise fueling. WOT it ignores the O2 data.
You'll idle and cruise rich, but it will be fine.
Old 05-17-2018, 11:27 AM   #1992
LC4CARL
Aero challenged
LC4CARL's Avatar
Huh, I wondered about that.
Old 05-18-2018, 12:40 AM   #1993
LC4CARL
Aero challenged
LC4CARL's Avatar
Going to have the machine shop fix the exhaust manifold threads. Surprised to see any cross hatch. Talked with the exhaust shop about the down pipe.
Old 05-18-2018, 09:33 AM   #1994
KeizerBrickGuy
Sh*t pot stirrer
Glad to see it's coming along, Carl!
Old 05-18-2018, 10:29 AM   #1995
LC4CARL
Aero challenged
LC4CARL's Avatar
250 hp or bust!!
Old 05-18-2018, 10:40 AM   #1996
Looks about right that's some pretty hard cast iron.
And check / have machined flat the manifold you use so it doesn't pull them ....
Again.
Old 05-18-2018, 10:54 AM   #1997
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx!
Old 05-18-2018, 10:56 AM   #1998
Cwazywazy
Cwazywazy's Avatar
Are you just gonna run the M47?
Old 05-18-2018, 05:16 PM   #1999
LC4CARL
Aero challenged
LC4CARL's Avatar
That's the plan. I'm hoping in survives under my "roll-on in 2nd and 3rd" driving style. For a while at least.
Dropped some coin at IPD today (the lads gave me the sale prices). Picked up a gasket set, radiators hose / clamps / thermostat, t-belt / tensioner, head bolts, intercooler coupler hoses.
Head and manifold at the machine shop. They seemed confident. It did have Time-Serts, but the tech speculates that somebody Loctited the studs into them as two are stuck to the studs.
Turbo shaft has more play than I remembered.
Got some ideas on the down pipe.
IPD Sale tomorrow.
Woohoo.
Old 05-18-2018, 05:51 PM   #2000
KeizerBrickGuy
Sh*t pot stirrer
WOOOOT!!!
Gonna be a blast
