#1 |
![]() I have a 1989 245 DL with inoperable heated seats. Neither of the switched illuminate when they are turned on which tells me that there is a bad ground to the system, a bad power wire wire to the driver seat switch (fuse confirmed good), or some other crazy thing going on involving a botched wiring job.
Did you bet on number 3? Of course you did. Why else would I be making a thread? ![]() ![]() Dear god! First of all, that dangling connector is supposed to be connected to the black wire which has clearly been yanked hard enough to no longer have a terminal. Second of all, why is this such a mess? Not a single wire is where it's supposed to be. Third, what up with the tar? ![]() Here it is sorta cleaned upish. ![]() Terminal rebent so that it actually stays in the connector body... ![]() I removed the console and pulled this cute little guy out of there. I think I'm immune to the virus now. ![]() I had to redrill the little self tapped ground on the bracket because it was completely stripped and not holding any of the ring terminals anymore. I don't think it's going to help the heated seat situation, but a fix is a fix! ![]() ![]() Here's the seat back in after I cleaned up the wires a little bit. ![]() Anyway, this was all for investigative purposes. I ran out of daylight, and put things back together before I could finish diagnostics. Here's where I am. Ground (D) is good which kinda surprised me given that the lights in the switches don't work either. There is no resistance between the switch (J and I) and ground (D). Power is also good. I have 12.4V at the switch (J and I) when the key (B) is on. When I come home tomorrow I will check to see if I have power and ground at the grid (C). Questions: What does everyone else's connector F look like? the female end on both seats is something stupid small like 20g wire. Is this normal? It sure doesn't seem large enough to power a heating grid. Also, does anybody have tips for cleaning up these old switches? Mine work, but the terminals are pretty corroded. I wonder if this alone is my illumination problem. Both bulbs appear good. ![]()
Feedback - https://forums.turbobricks.com/showt...ht=volvowagoon 1986 Buick Grand National - Restored to stock™ 2002 Camaro V6 T5 +T - The trashy car that's fun to drive 2010 C30 T5 - The boring but trusty daily - 199k 1989 245 DL - The boring but not trusty daily - 233k IG: @v6buick |
#2 |
Single jingle
![]() Did you check the grid for continuity? Could also be the little temperature switch in the grid. Mine was fine, just not actually connected to the grid anymore.
I don't know what I have |
#3 |
#4 |
![]() http://cleanflametrap.com/seatHeater.htm Seat Heater Testing
-Art |
#5 |
![]() Thanks guys. I did end up checking continuity before I went to work because I knew it was going to bother me all day if I didn't. No dice. It looks like I'll be peeling the seat cover back as explained in Art's guide.
#6 |
![]() on my drivers seat I cut out the thermostat and soldered in a piece of wire, maybe not the best idea, but it sure gets warm and comfy now!
#7 |
#8 |
![]() mine wasn't getting very warm with a working thermostat
#9 |
![]() Join Date: May 2007
![]() I'd get a set of heaters from wagonmeister if I were you. Much easier, way less hassle. All the stock ones are dead.
See here: https://photos.app.goo.gl/eSXaVMn8JbAgyvQ46
#10 | |
![]() Quote:
I almost forgot that that I can take my time with this! I have the seats from my old wagon in the basement. One even has a known good heater, so that could be helpful for diagnostics. I wish seat foam was a bit cheaper, but I think I'll manage with what I have. |
#11 |
Single jingle
![]() I do need to make mine hotter. On a cold morning it gives me a sliiiightly warm bum then shuts off and doesn't come back on. The heater in my '88 244 wasn't spectacular but it would actually turn back on to maintain bum warmth.
#12 |
![]() Take care with your mods. In the past 20 years I've read a story or two about monkeyed seat heaters being the cause of a serious carbecue.
#13 | |
![]() Quote:
#14 |
![]() Seat heater kits have come a long way. Many now come as a seat and back rest kit with hi low switches.
#15 |
![]() I bought the wagonmeister kit along with the grids. I hope I don't regret not buying seat foam. I'm thinking for now I'll wrap the foam in another big piece of fabric before putting it together so that I can avoid weekly vacuum jobs.
![]() Anyway, after confirming continuity I cleaned and installed the torn up driver seat from my old car. It warmed up very quickly too! No it's not blazing, but it's adequate. I never found out what happened to light in the switch, but I'm not going to worry about that right now. Warm butts for the winter is the first priority. I noticed some interesting stuff after looking at the old seat. There's a little trim piece on the back which the back that seems to be missing. I might have to transfer this over. ![]() There's a little clip that's supposed to hold the wires in place. That would have helped my seat had the wires been routed properly to begin with. I'll transfer that as well. Also notice that the wire is a lot thicker than the one I posted earlier. This looks a lot more normal. ![]() However, this seat has seen better days. ![]() ![]() ![]() ![]() Next to my sketchy desk chair for reference. ![]() Last edited by volvowagoon; 12-29-2020 at 09:00 PM.. |
#16 |
![]() Most of the foam is fixable. I like to use microfiber towels as batting/reinforcement.
#17 |
#18 |
![]() I like to use 3M Spray 80 cement for foam repairs and gluing.
#19 |
![]() Is nobody going to talk about that awesome desk chair? Gives off the same vibe as the old Top Gear UK car seat sofa.
#20 | |
![]() Quote:
![]() I'm probably making one of those tables pretty soon too. I have a 3800 block that's pretty worthless to me and a flat Electro-Motive train windshield. That sucker is THICK and heavy. |
#21 |
![]() I'm coming back to this. My fiancé is not happy with the seat positioning and I can't say I blame her. The strangest thing is going on with the rails which I can't seem to understand.
![]() First of all, I didn't know that these seats had a rear tilt adjustment until I removed them. That super strange to have the lever on the back of the seat too. I never noticed them on my old car either. Second of all, see how I'm adjusted to the middle slot on the inside? I don't have another picture but the outside is adjusted to the top slot. This makes the entire seat gangster lean and it's pretty annoying. I tried forcing the track into a level position. It worked. It also made the seat feel normal. However the whole thing was so loaded up in a bind that the forward/backward adjustment (the one for taller/shorter legs) did not work at all anymore. ![]() I checked my other seats to see if maybe this was normal and I was chasing the wrong thing. Nope. They're definitely not supposed to be this way. Is my seat track bent? Did the previous owner do something weird when they replaced the floors? Luckily I have the seat track from my old car. Maybe it will give me clues. |
#22 | ||
![]() Quote:
Forcing the rear "flat" would then twist the whole thing. Make sure both sides of both ends are the same. Here's the owner's manual page for a 1989 240..... ![]() ...and the seat track parts diagram for 85-87 (I assume it's similar to an 89?) ...... ![]()
1990 740GL 536,000 km so far... |
#23 |
![]() Yeah it sounds like it's not squared up.
Btw you can put an adjustable base into the passenger side if you are so inclined. |
#24 | ||
![]() Quote:
![]() For those of you interested in my desk chair, the investigating I did last night helped me find the four passenger seat adjustment bolts. Since I was able to tilt the seat forward a bit, the whole thing is a lot more stable now. ![]() |
#25 |
![]() I apologize in advance for how difficult this is to follow. I'm not sure how to address a lot of these parts and mechanisms either. Also keep in mind that I have the actual seat from the car and a spare battered seat from my first Volvo which was also blue.
I cleaned up the seat track from from my old car, and removed the seat from Moose. ![]() ![]() As soon as the seat came out of the car, it was pretty apparent that the track was not my issue. ![]() I didn't bother with the seat track swap. I just threw the seat back in as-is but with the height adjusters level. It was a massive pain to install that way, and the difference in height was noticeable. However, it still felt very wrong. ![]() ![]() ![]() ![]() So like most issues with this car, it's going from 0 to 100. It all started with a heated seat problem and turned into possible floor pan repair and full seat restoration. I guess this is the one nice thing about having worthless spare parts. I can investigate before trying my hand at interior work for the first time on a decent (looking) seat. Remember this junky thing? ![]() It donated it's body to science. ![]() This would explain why the seat felt so terrible. ![]() We already knew that this didn't help either. lol ![]() Bare frame ![]() Now I'm trying to understand how this back adjuster fails. I've read a few old threads about this, but most of the descriptions are pretty vague. They also did not have any pictures. Without removing more parts, this link bar seems to be the most obvious culprit. Would the fix be to hold the seat in a good position and weld the bar where my screwdriver is pointing? Should I pull this one out and use it in the other seat? I'd prefer not to have this issue again if I can help it! ![]() |
Thread Tools | |
Display Modes | |
