Old 01-14-2021, 05:22 PM   #1
Jussi Alanko
Default What your engine will cost?
Ok, occasionally: fun thread, what your project engine will cost at, i will start.
Block 100€
Bored & honed 300€
NEw pistons 450€
Conrods 400€
Bearings 120€
Gasgets 80€
Head gasget 120€
Head studs 110€
Cylinder head porting & 46/38mm valves & double springs and camshaft, 1300€
Exhaust manifold 300€
Turbo 400€
Wastegate 330€
Intake manifold 465€
Fuel rail 100€
Injectors 150€
Fuel pressure regulator 60€
Flywheel 100€
Microsquirt and ignition 650€
Wiring harness+sensors 700€
Only 6235€ (7000$) gone and i have a new engine...
Ok, i have two cool 'LVR-Racing engines' stickers too!
ANd i dont have clutch yet and no transmission.
Clutch package is 450 + 24% at classic-swede
Transmission is 400€ at bakaxel.se (reinforced M90)
1550€ for rear end at bakaxel.se
2500€ for suspension.
600€ at brakes.
at least 5500€ is going for those.
Then painting, 600€
Welding 300€
Yes, this is an expensive, very expensive hobby...
Jussi Alanko is offline   Reply With Quote
Old 01-16-2021, 09:19 AM   #2
I.M. Weasel
B23 block-$300
530 head $65
Machine work $950
Bigger valves $368
Lightweight steel flywheel $300
B23ET pistons and H beam rods $550
Oil pump $120
Head gasket set $45
Lower gasket set $60
Bearings $120
Crank scraper $120
Upgrade fuel system $400
Arp head studs $260
Stage 3 South Bend clutch $330
Starter $65
Other stiff $300
$3933
Living life one day at a time. Stopping to smell the oil slick beneath my Volvos.
Old 01-16-2021, 10:16 AM   #3
Jussi Alanko
Originally Posted by VB242 View Post
B23 block-$300
530 head $65
Machine work $950
Bigger valves $368
Oil pump $120
Head gasket set $45
Bearings $120
Crank scraper $120
Arp head studs $260
Starter $65
Other stiff $300
$3933
where did you buy crank scraper?
Old 01-16-2021, 11:37 AM   #4
JohnMc
JohnMc's Avatar
2008 Hummer H3 Alpha 5.3L LH8 - $1575
LS9 Camshaft - $150
LS7 lifters and guides (probably not needed) - $115
PAC 1218 valve springs - $136
Holley 302-1 oil pan - $350
Gen 4 hi-flow oil pump (probably not needed) - $85
LS6 head studs kit (probably not needed) - $129
MLS 5.3L headgasket set - $53
Corvette LS7 accessory kit - $564
Short-nose Corvette water pump - $105
Cheap truck starter from eBay: $54
Genuine A/C Delco truck starter when the eBay thing literally died after about 4 starts: $135
LS6 intake manifold - $350
eBay LS6 fuel rails - $94
CXRacing Fox body Mustang LS1 turbo kit (manifolds, turbo, oil supply and drain bits, turbo, wastegates): $1585 (certain regrets are in existence for this - it works and works well, but those headers are a PITA for spark plug access, plug wire access, etc)
About 4 sets of different kinds of super duper high temp plug wires that last for a drive or two: $250
EFI Source 'Gold Box' with complete wiring harness and 80 lb Deka injectors: $1531 (I was feeling lazy and just wanted to plug it in, fire it up - FWIW that's how it worked out w0000t)
'Mopar style' (hi/lo hose sides swapped) C4 aluminum radiator: $185
Dual fan and shroud kit: $230 (in retrospect, meh)
Universal 3" intercooler piping kit: $86 (pipes, bends, couplers, t-clamps - this was, by the way, totally awesome, even if I didn't use half of it I save money, effort, and have a bunch of stuff left over for the next time I do something turbo-ey )
3" BOV fitting/Silicone coupler, HKS BOV: $110
1L oil sump for turbo drain: $75
Cheap eBay oil scavenge pump: $43
Turbowerx oil pump when the eBay crap pump made *HORRIBLE* noises and leaked and I didn't trust it to last to the end of the driveway: $265
Random hoses, tubes, fittings, etc: $200 (???)
STS Machining LS motor mounts: $350
Total: $8805
OOF! I knew I shouldn't have added that up. My rough mental math always estimated it as a bit less than that...
Drivetrain:
Nissan G35 JK40C transmission: $650
Camaro T56 bellhousing: $256 (in retrospect, probably should have gotten a steel scatter shield bellhousing for a bit more)
Camaro LS1 flywheel: $159
Collins complete adapter kit: $1287 (adapter, 780 lb/ft clutch kit, slave cylinder)
(I like the above kit because everything is either stock Nissan or stock Camaro T56 - other than the clutch disc itself (Nissan center on a Camaro disc).
CBF Performance top mount shifter kit: $525 (and, it must be noted, about 4 months of wait time, April to August)
Custom driveshaft 1-pc CD009 to Volvo rear axle: $320
240 Hydraulic clutch pedal set and new master cylinder: $200
Total: $3397
Again, a bit of OOF. At least if I mangle the transmission, another CD009 style is cheaper than if I'd gone with a T56, where the trans costs $2500-ish (and up). $1500 - 2000 seems to get you a 'known bad' rebuildable core on those.
Grand total: $12,202. Now I'm depressed. Thanks. Ah well, 550-ish whp is pretty damn fun in a 240. It never felt like that much money when I was doing it. Because it was spread out over like 3 years. A year (more or less) buying various parts before getting it really going and pulling the old motor out, then 2 years of slow work getting it done. So it was just chunks here and there. It all adds up though. Obviously. I don't think I ever bothered to total it up before, and I'm probably forgetting things. Like (oh yeah) the STS machining LS/240 motor mounts - $350 GB a long time ago)
In the works:
Since the Deatschwerks 300 fuel pump left over from the 350 hp 16V redblock is out of capacity at the current 6 psi boost levels, I need more fuel.
new gas tank: $120
big Aeromotive FPR: $187
Aeromotive 183099 dual fuel pump setup: $550
AN10 fuel filter: $100
Electronic boost control: free with some wiring and laptop setup
This should allow me to run the boost up to around 15 psi, for maybe 700 - 750 hp?
And of course, the rear axle probably won't survive that so:
Narrowed Ford 8.8 axle with Volvo suspension mounts: $800
New custom driveshaft CD009 - Ford 8.8: $320 (might go 2-pc)
Rebuild rear axle with low 3.0-ish:1 gearing to suit the CD009 gear ratios: $700??? (haven't even looked into it)
Dakota digital convertor box - to keep ABS and Speedo/Odo happy with Ford speed sensor: $150
New 5X4.5 wheels all around, rolling fenders to stuff as much tire in back there as I can: $$$$ (no clue what I'm going to do, but so far I'm leaning toward something like this https://www.imagewheels.co.uk/billet-11-alloy-wheel/ )
STS machining front Wilwood brake kit: $950
Wilwood Ford 8.8 rear brake kit (w/parking brake): $850
All that and it doesn't have A/C. Lol...
Yes, some people put turbo LS cars together in 2 weekends with about $500 invested. I am apparently not that guy.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-16-2021, 11:40 AM   #5
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I think I was around 10 or 11k into my ls swap, but I spent big money on a couple things I didn't have to, and I specifically sought out an L33 vs a $300 jy 5.3
the gold car... I don't know anymore. to duplicate where it sits right this second, probably 6 or 7k depending on how things get shopped out. the engine itself is probably around a grand to 1500, again depends on how you shop things out. stock 150k pistons and crank, $200 ebay rods, but springs/retainers/cams in a 16v head...
Megasquirt Tuning!
Old 01-16-2021, 01:21 PM   #6
eabras
350whp:
used complete b21et: $100
used v-cam: $20
usde valve springs: $30
used injectors: $100
used hy35: $250
vems: $600
dw300 intank: $220
car already had 90+manifold and 3" exhaust, plus a large 3" thick genereic ebay-ic and other bits and pieces
eabras is offline   Reply With Quote
Old 01-16-2021, 01:58 PM   #7
I.M. Weasel
From this guy
https://www.crank-scrapers.com/Volvo.html
Old 01-17-2021, 09:10 PM   #8
Stiggy Pop
Stiggy Pop's Avatar
I wouldn’t consider engine management or wiring as part of the cost of “building an engine”, that’s a separate column, but if those are the rules...
~applies filters to spreadsheet~
$19,115.44
'79 242
943 pickup
Old 01-17-2021, 09:13 PM   #9
2turbotoys
Salaminizer
2turbotoys's Avatar
I don't think I want to play this game, I don't want to face that reality.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 01-18-2021, 12:31 PM   #10
Tfrasca
Tfrasca's Avatar
Same.
Old 01-18-2021, 12:46 PM   #11
Broke4speed
Broke4speed's Avatar
Opposite end of the spectrum!
-AQ140A pulled (cut) from a boat in a buddy's scrapyard: $free
-Zenith Stromberg 175CD-S2 carburetors (x3): $50
-Carburetor rebuild kits (x2): $50
-Gasket kit/timing belt/blah blah: $100
-Modification to AQ intake manifold: $100
Total: $300 CAD .
1984 244/ LR4 4.8 / T5
Old 01-18-2021, 02:23 PM   #12
RvolvoR
Poi b6284t/b6304s combo - $1000
Header - $750
Mounts - $300
EFR 8374 - $1800
Injectors - $600
Maxxecu race - $1600
Wiring harness supplies - $1500
Yeah, I'm just gonna stop there...its more than likely north of $15k with transmission stuff and all of the other odds and ends. Still doesn't run.
Old 01-18-2021, 02:41 PM   #13
JohnMc
JohnMc's Avatar
My very vague mental running total was about 1/3rd lower than reality.
Old 01-18-2021, 03:10 PM   #14
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
I'm scared to even think about how much money I'm blowing on a 150-hp rally motor that I'm going to stuff into an absolute rust bucket.
Doing the wrong thing the right way.
Get f*cked and please have a nice day.
Originally Posted by IansPlatinum View Post
please no more prying things with screwdrivers and bashing things with hammers!
Originally Posted by Cwazywazy View Post
my balls have more wrinkles than my brain
Originally Posted by leecatd8209 View Post
Against all odds I have overcome the 4
-1967 144S
-1983 245 Diesel (Current Project) - passively for sale (interested in trades!)
fatcatbestcat is offline   Reply With Quote
Old 01-18-2021, 03:48 PM   #15
culberro
culberro's Avatar
Ahhh, the price of pushrods.
Or so I assume.
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 01-18-2021, 04:01 PM   #16
culberro
culberro's Avatar
V8 drift car is up to $13,800, but that's for all parts and consumables since ~2015(?)
Fully rebuilt 5.slow with new aluminum heads was ~$2600 for 350+hp and lots of revs.
Old 01-18-2021, 06:54 PM   #17
spock345
spock345's Avatar
I am scared about how much I am putting into a motor that I hope makes 130 hp but a stock B20E made that and it shouldn't be too hard to pull off. I can only imagine what an additional 20hp would cost.
1998 S70, grandma-mobile
spock345 is online now   Reply With Quote
Old 01-19-2021, 05:07 PM   #18
fatcatbestcat
Professional Hack
It's mostly in machine-work and non-stock top-end parts.
Doesn't help that I'm starting with a questionable cylinder wall in #1, so I already have to get it bored out.
Old 01-19-2021, 05:20 PM   #19
JohnMc
JohnMc's Avatar
Extra NA horses do cost more than extra turbo horses. Especially extra pushrod horses.
Old 01-19-2021, 06:03 PM   #20
*Looks at balance sheet*
*closes balance sheet*
I hate the car and also cannot be free of it. I dream of having a different project but cannot separate myself emotionally from this one and so remain bonded to it like Sisyphus to his great stone.
Old 01-19-2021, 06:12 PM   #21
fatcatbestcat
Professional Hack
The fee for passage:
Engine itself: $0 (included with the car, pre-ruined)
New B20F cylinder head: $250
37mm Exhaust valves: $150
Head resurface and valve installation: $300
Redline DCOE manifold: $120
FAJS 45mm DCOE carbs: $500
VV91 cam: $190 (we're not going to include the other two cams I bought)
Iske Lifters: $250 (bought sixteen by mistake)
Iske Pushrods: $150
Steel timing gear set: $200 (doesn't include the aluminum one I borked)
0.30 over pistons and rings: $250
Water pump: $50
Alternator: $250
I still need to get the head machined again for the bigger valve springs, and need to get the block bored out. I also have basically no linkage for my carbs...
Total:
I'm too scared to calculate.
Old 01-19-2021, 06:45 PM   #22
Mkay,
Block: $175
Rebuild rings, bearings, seals, gaskets: $350
head studs: $150
rods+pistons: leftover from previous engine ($free)
16v head, cams, springs, lifters, intake manifold, cam gears, billet crank gear, conversion stuff, fuel rail, ~$1500
Exhaust manifold and adapter plate: $250
Harmonic balancer: $70
MS3X: $430
Wiring harness, connectors, sleeving, heat shrink and sensors: $300
CAS conversion: $250
Ignition Coils,: $130
ID1300x: $500
ebay turbo: $200
KL Racing intercooler: $250
Intercooler piping: $100
Motor mounts: $150
Fuel Pump: $100
Fuel fittings and hose: $300
Machine work for cylinder head: $200
FPR: $free from purchase of car
$5405 plus a few jars of salsa for culberro on the engine alone
EDIT: not counted:
GM alternator conversion
740T accessory brackets
Air conditioning
240T oil cooler
silicone hoses
DO88 radiator
Old 01-19-2021, 06:49 PM   #23
fatcatbestcat
Professional Hack
Mkay,
Yeah, but does it run?
Old 01-19-2021, 06:52 PM   #24
I think it's up there for an expensive and overcomplicated 300 whp turbo engine on this board I think.
Old 01-19-2021, 06:58 PM   #25
joel142
Opens order history; looks at list of AN fittings; closes order history.
Yeah, I think we're good here.
'71 142E, B230FT, M41, Corbeau GT seats, iPd bars and springs, Nardi wheel, GT gauges, overmatched KYB Gas-A-Justs, Canisto wheels, 7" Cibies
'95 T5-R, yellow, M56H swap
'06 R500, Built like a steak house; handles like bistro
joel142 is offline   Reply With Quote
