Old 10-09-2017, 11:30 PM   #1
cookieboy
cookieboy's Avatar
Default Should I dismiss a 240 with a cracked airbag pad?
So there's a 240 with a salvaged title for sale at a small dealership but I noticed that the steering wheel pad where the airbag is was cracked in a few spots and I could see the airbag through the cracks. Is that something that I need to be overly concerned about and can it be addressed inexpensively or should I walk away ?
1990 244 DL, (Given to stepson 3-2-13)
cookieboy is offline   Reply With Quote
Old 10-09-2017, 11:34 PM   #2
Pick n Pull is selling airbag wheels again.
Draw your own conclusions.
Old 10-10-2017, 03:49 AM   #3
Shifted
C&M '17 Survivor
Shifted's Avatar
Or just install an aftermarket wheel.
Why was it salvaged?
Originally Posted by ME II View Post
Without mistakes there is no learning.
"Ego is the anesthesia that deadens the pain of stupidity" - Rick Rigsby
Shifted is offline   Reply With Quote
Old 10-10-2017, 06:12 AM   #4
Grr baby, grr
I wouldn't count on an ancient airbag to save my life anyway.
Old 10-10-2017, 01:33 PM   #5
lummert
lummert's Avatar
The air bag on my 88 765 is disconnected.
Old 10-10-2017, 01:47 PM   #6
Tuff240
240 Ninja
Tuff240's Avatar
Check the car closely for frame damage. Knowing what I know about these cars, if the air bag was deployed previously and it has a salvage title, I'd keep looking for a better car as there is a good chance that one is bent.
-Patrick
Old 10-10-2017, 02:19 PM   #7
swedefiend
There was a place in Birmingham, AL that charged $75 to place a car on a "frame jig" (not really so since our cars are unibody) and determine if the car is square.
For another $50, they would pull the car square (if not severely wrecked).
If the price is right, you might try finding a place with a similar deal.
Just my .02
Old 10-10-2017, 02:31 PM   #8
John242Ti
manofewords
John242Ti's Avatar
I'd look for a car that has a clear title.
Also, don't limit yourself to 1990-93 240's. The 1989 models are mostly the same, but without the bomb in the steering wheel. I've actually downdated my family's '92 to an '89, since it had the 1st generation bomb installed.
-J
1982 242Ti - black, M46. 1985 245Ti - blue, M46. 1989 745Ti - red, Aw71.
Formerly Blue245Ti, 245GT-Turbo, and, originally 242GT-Ti.
Old 10-10-2017, 02:53 PM   #9
Can play the blues
Check out the rest of the car and see if it is a good project. The air bag stuff isn't a big deal to either fix or remove.
I also removed the early air bag in my 93 wagon. After you remove the steering wheel, remove the clock spring and then bracket for the turn signal and wiper switches. Get the bracket from a 1981-88 model without air bag. the wiper and turn signal switches don't have to be changed. Then use what earlier steering wheel you like. I put a GT horn pad on one of my spare turbo wheels. Gave one of my friends the parts like the steering wheel, airbag, controller, and backup power supply.
Old 10-10-2017, 03:14 PM   #10
cookieboy
cookieboy's Avatar
Good question, the seller doesn't know. He's a small independent dealer and he got the car from a donation station.
Old 10-10-2017, 03:17 PM   #11
cookieboy
cookieboy's Avatar
-J
Thanks John, I'm actually looking for one between 1987-93 So I definitely wouldn't dismiss the '89's and older. I thought I had found one but it sold before I could get down to see the car.
Old 10-10-2017, 03:25 PM   #12
Shifted
C&M '17 Survivor
Shifted's Avatar
Stick with '88+ ftw, '87s still had the disintegrating wiring.
Old 10-10-2017, 04:48 PM   #13
cookieboy
cookieboy's Avatar
Good advice, thank you. I couldn't remember what the cut off year was for that.
Old 10-10-2017, 06:01 PM   #14
Somewhere in 87, [I think late in the year] so many of them are good in fact I wouldn't write off any of the LH 2.2 cars since most have replacement harnesses by now anyway...
Edit:
Or even a nice B23 / LH 2.0 car.
Old 10-10-2017, 08:49 PM   #15
Shifted
C&M '17 Survivor
Shifted's Avatar
The other thing though is that even if the underhood wiring has been replaced, the same stuff was used throughout and tends to fail sooner or later, especially at flex points like door bundles.
Can't remember when in '87 my 745t was made but I had stuff starting to crumble everywhere.
Going down that road again I'd definitely dig into it here and there to see what kind of shape it was all in.
Old 10-10-2017, 09:51 PM   #16
cookieboy
cookieboy's Avatar
You know, something else I forgot to mention was that the shift light was on which wouldn't go out when I hit the button so I wasnt sure was if it was the OD relay or what because there was some wires taped onto the auto shifter from just underneath the knob and going down towards the tranny that someone had obviously rigged up for some reason so that left me hesitant as well. I spoke with the seller at the lot since then and he said that his mechanic got the light to go off and it wasn't the relay, but that the button has to be jiggled a certain way. But unless he took it for a drive, a I still don't know if it up shifts into fourth gear which of course leaves me rather hesitant on this car, what do y'all think ?
Old 10-10-2017, 10:23 PM   #17
Sounds like a problem child.
Drive it and offer him maybe half.
Old 10-10-2017, 11:23 PM   #18
Tuff240
240 Ninja
Tuff240's Avatar
All I have is older 240's, mostly 83's. They are all fine except the engine harness or other usual problem areas that all 240's have.
Old 10-11-2017, 03:20 AM   #19
John242Ti
manofewords
John242Ti's Avatar
^Yeah, it seems the biodegradeable insulation problem ends at the firewall, and typically avoids the body harness, except the constant idle harness pigtail on turbo cars (protip: if you need to replace that pigtail, find a 1981 49 state DL or GL with the aux. air valve - pigtail is there, but stuffed inside the strut tower, looking like new)...
-J
Old 10-11-2017, 04:54 AM   #20
LloydDobler
LloydDobler's Avatar
Just my .02
Given how little is adjustable on the alignment of these cars, usually alignment is all you need to know if the car is square or not. If it aligns, it's very unlikely that the body is bent. If a setting is too far out to be corrected that's a red flag.
'66 122 - Collectible project
Old 10-11-2017, 10:57 AM   #21
cookieboy
cookieboy's Avatar
So what do you guys think of the Jeri rigged shifter with the wiring going from it down to the transmission ?
Old 10-11-2017, 11:43 AM   #22
Good bones and a straight body are the problem pieces anymore, with the cars outliving their 20 year 'lifespan'.
Old 10-11-2017, 11:45 AM   #23
Harry Tuttle
I think this car sounds like a problem. Is the price extremely low? Are you looking for a project? It seems like there should be other 240's for sale in CA.
Originally Posted by sbabbs
who cares, push start it if you have a man tranny.
Old 10-11-2017, 01:36 PM   #24
Tuff240
240 Ninja
Tuff240's Avatar
You can do a basic alignment and the car still be bent as !@#$. The front unibody bends quite easily on these cars during a crash.
It's a turd. How many times do we have to tell you it's a turd before you get the message and move on?
This. This. And this.
It's most likely this car since it's near him, priced low and has a salvage title.
https://sacramento.craigslist.org/ct...340740403.html
Old 10-11-2017, 03:29 PM   #25
cookieboy
cookieboy's Avatar
Well, I don't know what happened, but my post disappeared so I'll type it again. That is indeed the car. I Wasn't trying to beat a dead horse with the tranny question, I just wanted to clarify since there seemed to be some variance of thought on that but I have decided to leave it alone and search elsewhere. Better safe than sorry.Thanks again for your time and input everyone.
