it is a good choice ? pistons rods injectors
The choice of the turbo is not blocked but is one of this;
GTX3071R
GTX3076R
PT5858CEA
PT6262CEA
850cc is ok
My tuner finish a Renault Megane 2 RS with gtx3071r 850cc E85 and lot of other part 554hp / 570nm at 1.7 bars
I need your knowledge please
Someone to test or information on the strength of these parts with 25/30psi - 7000/7500rpm ?
https://www.maxpeedingrods.co.uk/high-performance-volvo-b230-h-beam-connecting-rods-conrods.html
https://www.acm.se/en/category/volvo-b230-b234-8
Are these 850cc injectors ok for a B230FK ?
https://www.cpfuelinjection.co.uk/volvo-s60r-v70r-2-5-turbo-injectors/
Thanks a lot for your help
Hi WTF, Look:
For Volvo B230 H-Beam Connecting Rods & Conrods
Fit for
For Volvo B230 engines
Material
Forged 4340 aircraft chrome moly quality steel
Quantity
4 Pieces as showing in picture
Bolts
Including ARP 2000 bolts
Bolts size
Genuine ARP 2000 3/8" bolts<--------
Lubricants
Including ARP Ultra Torque Assembly Lubricants
Tolerance
Balanced to +/- 1 gram in set
Note
Extra cost for upgrading to ARP L19 bolts
Warranty
Limited lifetime warranty
Dimensions
Center to center length
152 mm
Big end diameter
52 mm
Small end diameter
XX mm
Big end width
24.8 mm<-------------------------------------------!!!!
Small end width
XX mm
These points hold the promise of futre en future>>
There are better rods that are full 29.75mm wide at big end --what we call "crank steered"
That gives you more choice in piston design that "rod steered" like orginal rods and these
ACM at least has that correct..But ACM still has 3/8 rod bolts which are smaller than original, and still 23mm pin..
The nicer rods are longer--between ACM 158 and 165mm center-to-center,,,at 160mm and 22mm pin for more choice in pin design (thicker wall or lighter or material) than 23mm and they come with bigger than original rod bolts ARP 7/16".
I supply the nicer rods...
And I am CP and J&E dealer so I can offer you more choice in diameter, piston crown or bowl shape if you have any special wants, or needs..
Where in France are you? Long ago I was based in Conner? in 72 Sarthe and later in Beaune, C?te-d'Or for motorsports.
850cc is ok
Sjeng ok but how you explain this
And make a easily calcul
440cc is ok to over 300hp
880cc normally are ok to over 600hp
The method form my tuner for calculate the injector size for run E85 is easy
How much HP you want + 30%
I believe my tuner but you can be sure if 850cc are finally too small is not buy to go buy bigger ;-)
Yeah the rod bolt size doesn't mean anything. Cause, I mean. Look at all of the people that snap rodbolts. The only time it really happens is when a bearing goes bye bye.
Yeah they just put bigger rod bolts in every real UP-graded connecting rod just to try and fool gullible people..
Man it's good that Turbobricks has been blessed with such astute experts in engine building who can see thru all those tricks ALL the rod makers try..
The Scat rods in the 5.0L drift engine use 3/8 rod bolts. Those pistons are HEAVY, and it spins to 6500 all day long.
The old 8v rally engine was a completely stock bottom end with 13mm rods, and it rev'd out to 8k rpm all the time.
7/16" rod bolts are stronger, but are they necessary?
You just don?t get it do you?
How many redblock rodbolts have you personally seen snapped due to anything other then a blown out engine. And at what power level?
Gasoline and that's pushing it. (assuming 4 cylinder)
850cc on e85 is not enough for 550hp.
Two possibilities:
1: (Adjustable) FPR with 5 bar pressure, (strange, because bigger injectors cost the same)
2: Dyno numbers are inflated. 550hp on a 3071R is pushing it as well.
Why NOT? Choice..something wrong with doing something stronger? Or is it just your buddies didn't bother to look and see the opportunity to do something bigger than stock--they just copied that which was already done..
So why do you and a couple of other of the same little clique complain about a bigger rod bolt than stock? What does it HURT?
7/16" is stronger, and it hurts nothing, you're just trolling.
Crank steered is, when going to oversize aftermarket pistons, BETTER. It gives MORE choices..
Something wrong with more choices?
  • Like
Reactions: Flo
Up from 5/16"
Those pistons are HEAVY, and it spins to 6500 all day long. Yeah, right
The old 8v rally engine was a completely stock bottom end with 13mm rods, and it rev'd out to 8k rpm all the time. Those rod bolts were 10mm.....0393"....3/8 is .375"..So the stock bolts are virtually 0,5mm larger...why did Volvo use such big bolts if you and the troll-boys insist its not important?
Is anything necessary?
