- Jan 24, 2009
- KC, MO
enogh
indeed
enogh
Considering the track record of you three that criticism is hilarious
In the last pic it looks like he bolted it up to a motor?
The whiteblock M90s seem to come more often than not with the round, 4 bolt output flange. I wonder if the bolt pattern is the same as in earlier 200-series cars. Or are you going to change the flange and use the never style drive shaft with a guibo?
Nope ! Thats a no-go.. under some circumstances you can break the flange, which will lead to serious injuries !! Buy a transmissionstand instead... !
/edit... when mounted to a trannystand.. i cleaned my m90 with a k?rcher
worked pretty well.. the rest i did with brakecleaner on Acetone base.. looked like fresh from bench
Going to the 3 bolt flange: I'd only do that if the flange off my M47 fit the M90. Otherwise its not worth the trouble to find an M90 flange.
