Old 11-27-2016, 03:33 PM   #76
Broke4speed
Broke4speed's Avatar
Spent some time making the engine-side wiring harness today. Very relaxing.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 11-30-2016, 11:06 AM   #77
Broke4speed
Added a second output to my MS1 v2.2 last night, so now I can control the two-speed fan properly. I also encountered the 'heater pipe resting quite firmly against the 90+ manifold' issue, since I'm using the B21A pipe, and it does not have the dip in it that the turbo ones do. I tried to pull the one from the lone turbo 940 at the yard, but it was rotten to the core. I broke down and ordered one from IPD, even though I'll have to block off the port that goes to the water-cooled oil cooler, and make two mounting tabs. My water pump has the bolt on the top, and the late pipe I ordered bolts on the bottom. No biggie...I love my welder .
Old 12-02-2016, 11:34 AM   #78
Broke4speed
I'm really effing tired of not having the engine/trans in the car, so even though I don't have the metal heater pipe yet, I may button everything up and install it on sunday. I want it to RUN.
Old 12-03-2016, 08:17 PM   #79
Broke4speed
Did a bit more work today...and stumbled upon something interesting. I was under the impression that all 240s had the holes for the upper firewall braces...mine doesn't. I was going to make some braces, but I guess now I won't, lol.
Finished the last of the engine wiring, cleaned the rest of the bay, degreased the tranny crossmember, driveshaft support, and that brace thing that goes under the engine at the bellhousing. I also installed the ignition module and swapped to the VW coil I'm using with the MS1.
Old 12-04-2016, 03:19 PM   #80
Broke4speed
Cleaned and installed the engine-side engine mount brackets. I wasn't planning on getting new mounts, buuuuuuuuuuuuut, I think it's a necessary item. I may splurge on a tranny mount too, but it's still in good shape.
I also hooked up the fuel feed line, using the original carbed line...which is nylon, just like the efi cars. The chassis harness/fusebox also had the fuel pump wiring already in it, so I only need to run 12v to the harness at the wire going to the in-tank pump, and it runs fine. I tested it...and dumped a bunch of gas on the garage floor, lol. Still pretty happy though .
Old 12-04-2016, 04:56 PM   #81
petiww
petiww's Avatar
You had nylon feed line to the carb??
I'm still thinking about replacing the nylon feedline on the B230F with the original carb steel feed line. Which is exactly the same steel line as the return line on the B230F
1980 Brown 244 GL
Old 12-04-2016, 07:09 PM   #82
Broke4speed
Well, it was nylon at the tank outlet. I guess it's metal in the bay, I've never really looked at it.
Old 12-05-2016, 10:18 PM   #83
Broke4speed
HA! I got pissed that it didn't look like I had the pre-existing holes for the braces, so I dug deeper into the foam insulation on the cowl. Found them .
I feel pretty stupid, but at least they're there.
Old 12-06-2016, 11:30 PM   #84
amerbritcan
Hnnnnnng
amerbritcan's Avatar
I would have been thoroughly alarmed if you didn't have them
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 12-07-2016, 10:02 AM   #85
Broke4speed
...yeah...I've since learned that I was looking in the wrong spot...
It's funny how 20+ years of experience with VWs evaporates into stupidity with an unfamiliar make of car, lol.
Old 12-07-2016, 10:04 PM   #86
Broke4speed
So, I'm concerned about my passenger side engine mount. While searching the forum, I found someone talking about the ones on Yoshifab. I thought they looked kinda odd, but didn't put any effort into finding out what they were, because at that point I was going to re-use the one I had.
Then today, I was at Princess Auto (Canadian Harbour Freight) and found these...
http://www.princessauto.com/en/detai...ds/A-p8656506e
$10 CAD for TWO. They are 1/4" too short for the pass side, but a spacer will solve that. The hardness is listed as 70, which feels a lot stiffer than the old stock mount I have now. They're also 3" in diameter, so it's almost a perfect fit. I'll definitely have to make a heat shield, but that's no biggie.
Gonna give it a shot, might as well.
[edit]These are the Yoshifab ones[/edit]
Old 12-07-2016, 10:36 PM   #87
Broke4speed
Oh, I also modified a late B230FT heater pipe to fit my B21A with the 90+ manifold. The paint is drying, and once it's mounted...the engine can go back in .
Old 12-08-2016, 06:21 PM   #88
Broke4speed
So I had the afternoon off, and since it was 1*C (33.8*F), I decided to go to the junkyard. They had recently gotten a 2001 S60, and it turned out to be a T5, score!
Goodbye 13C...
Hello MINTY fresh, angled housing 16T
They cut out the catalytic converters at the yard, so I got the full dowpipe too. Comes with free bosch wideband sensor, although the wires were cut (oops).
Old 12-10-2016, 09:57 PM   #89
Broke4speed
Got the 16T mounted, and a wastegate fabbed up. The stock 16T one was pooched (wouldn't react to pressure/vac, diaphragm must be torn), and there's no way I was going to use the 13C one...so I dug into the parts bin and made one up out of a spare DSM 14b can I had. Nice and big, and a decent amount of travel.
This is as close as the pics will get, I know how this place feels about fab work that's less than stellar ;).
I had to shorten the rod, so I threaded it for some preload adjustability. It was conveniently already bent, so it doesn't foul the oil return either. I am going to use the stock downpipe, cut and rotated, since it's in really good shape. I'll blend that into the 940 dp I have, and connect it to my stock DL exhaust.
Old 12-14-2016, 07:54 PM   #90
Broke4speed
Since my back is mostly jello and bone splinters now, I have to work smarter, not harder. Muscling the transmission on to the engine while it's on the ground is not possible now, so I made this cart to hold the box up while the engine is dangling on the hoist. This way, no lifting and minimal muscling .
Old 12-15-2016, 09:02 PM   #91
Broke4speed
The cart worked perfectly .
Roll the engine and trans together, with the engine on the hoist (after the FP install), install the two starter bolts in the top bolt holes to line it up, and then walk it together. No fuss, no muss, no muscling, and no back pain.
It's interesting to note that my B21A block has the proper indent and enlarged areas for the LH2.4 CPS, but no holes. Is it just mine, or do all the later (80+) have it?
Old 12-16-2016, 12:38 AM   #92
amerbritcan
Hnnnnnng
I love that little cart.
Old 12-16-2016, 10:27 AM   #93
poulrais
poulrais's Avatar
Hey I've seen that 90+ mani somewhere!!
Good work done!
1990, Volvo 740 16v +T
Old 12-16-2016, 11:01 AM   #94
Broke4speed
Thanks! Yes, yes you have! Haha.
I hope to have the engine back in the bay this weekend, since it looks like it'll be a stormy one out this way. Might as well stay in the garage and work .
Old 12-16-2016, 01:02 PM   #95
poulrais
poulrais's Avatar
Indeed... -35c here this morning with the wind chill factor!
Old 12-16-2016, 02:56 PM   #96
Broke4speed
Same here, out my way. My subie was pretty upset this morning when I made it fire up.
The garage heater is getting cranked tomorrow!
Old 12-16-2016, 11:49 PM   #97
Broke4speed
Correction, my garage heater GOT cranked tonight ;).
We had supper with friends at a local BBQ place, then when we got home I went out to the garage to judge what kind of work I'd need to do in order to get the engine in.
An hour later, it was in the bay . Nothing is bolted in, and I have a jack holding the tranny up, but I'll address all that tomorrow.
Old 12-18-2016, 09:25 AM   #98
Broke4speed
So I spent yesterday discovering all the WONDERFUL things that are different between cars with the BW55 and cars with the AW7xs.
-Need crossmember spacers. There was NO way the driveshaft would fit without them. I have pieces of 1/4 aluminum in there now, but will hopefully get some OEM parts soon.
-Shifter linkage. The BW55 is waaaaaaaaaaaaaaaaaaaaaaaaaaay longer than an AW7x one. Luckily for me, I am able to confirm this detail...because all I have is the BW one, lol. Again, I'm hopefully getting an OEM one soon, but my BW55 part is in mint condition, and I have a welder, so it's not super essential.
This is all minor stuff, thankfully. I was smart enough to swap to the longer throttle valve cable and throttle cable when the engine was out, but those other two details just skipped my mind.
Old 12-19-2016, 11:03 PM   #99
Broke4speed
After 4 hours of useless f**kery, I finally have a shifter linkage that works.
The big issue is that the BW55 has the adjustable end, which smacks the tailhousing of the AW71L and prevented the use of 2 or 1 on the shifter. I've made it work, but I'm not super happy with the way it turned out. BAH!
Old 12-21-2016, 09:14 PM   #100
Broke4speed
Good bye, BW55...you won't be missed . I find it amusing to see that my original cluster already had the OD Off bulb in place, so adding the factory OD harness was a piece of cake. All I have to do now is connect the final wire (12v to the solenoid), and I'm done.
