Old 08-04-2018, 09:20 PM   #1
icdpride
Default My Cheap Heap the Ebay way 1986 244dl + t
So for the past year or so I have been working on my 1986 Volov 240dl in sweet sweet beige, it came to me barely running, with the stock n/a b230f engine, a 4spd m46 trans with overdrive, and 86000 original miles. Like any other project with no plan I started to put together all the cheap parts I had and set to work and after that these are the specs that I have for the car
1986 Volvo 244dl
4spd M46w/od
B230f +t 86 block, installed rods from 93 new rings and bearings
Cometic head gasket
530 head with some minor porting work
IPD Turbo cam
2.2lh Block mounted distributor
Megasquirt 2.0 v3.57 with Mapdaddy 4bar
10' ms harness from diyautotune.com
OBX (ebay) turbo manifold flipped and re welded with braces and extermal wastegate
38mm External wastgate
Gt35 (a/r .70) ebay turbo
3" downpipe
3" full mandrel bent 2 pc exhaust with thrush turbo muffler and v-bands
Innvoative ls-2 Wideband o2
Large FMIC
Walbro intank 450lbh
GENSSI Blue Type S Adjustable Fuel pressure Regulator
YoshiFab redblock billet TPS sensor adapter
1000cc injectors with resistor pack
2 12" efans
Dual core ka aluminum radiator
Here is how it started
Here is what its at now
Engine Bay
icdpride is offline   Reply With Quote
Old 08-04-2018, 09:29 PM   #2
icdpride
But with me being bad at tuning and contaminating the oil with a ton of fuel my engine went from making cool cho cho turbo noise to horrible screeching noise (see video bellow)
So today it got pulled back into the garage for some major work
Tear down begins
Front clip off
Coming out
Its out
Now to get it on a stand torn down and figure out what happened
Old 08-05-2018, 09:33 PM   #3
icdpride
Got the motor torn down and there is diffidently shows some damage so it is tie to rebuild after to measuring to find out if there is any damage to the crank or anything.
Top end with the valve cover off
Head off
The oil that came out, looks not great and a fair amount of metal
Crankshaft, looks ok I think, need to measure it to make sure, tips are welcome
Piston 1 rod and bearing
Piston 2 rod and bearing
Piston 3 rod and bearing
Piston 4 rod and bearing
Oil pump tube, Here is where the real damage no clue how this happened
So any input would be awesome I am assuming it was poor assembly by me followed by all the fuel in the oil so I think a rebuild will fix it
Old 08-05-2018, 11:14 PM   #4
Tfrasca
Tfrasca's Avatar
Did the counterweight hit the oil transfer tube or something? That looks crazy.
Old 08-06-2018, 09:49 AM   #5
icdpride
Honestly I don't know as there is no rubbing marks or aluminum on any of the parts, I am think a rod was rubbing on it due to play in a bearing .. maybe
Old 08-08-2018, 09:52 PM   #6
icdpride
So I measured the ring gap and I think they are all too tight but they also very greatly from cylinder to cylinder
Looks like I need to th hone the cylinders and do some math to get these right
Old 08-13-2018, 12:12 PM   #7
icdpride
Since I am waiting on tools and parts I though I would wire tuck everything and refresh the engine bay, fix all the scratches fill the unused holes delete the battery tray and repaint it
Battery tray delete
Bay refresh
Old 08-13-2018, 12:16 PM   #8
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Nice! I wish I could convince myself to do my engine bay like that, maybe someday...
1980 242 Turbo
2004 V70R
Uncleknucklez is online now   Reply With Quote
Old 08-13-2018, 12:28 PM   #9
icdpride
It really wasn't that bad on this car easier then most, the wire routing requires making sub harness extensions but otherwise not terrible
Old 09-10-2018, 10:25 AM   #10
icdpride
Finally got some motivation (and time) to work on this heap got the bay all finished and all the wires tucked and hidden and put the engine back in.
Angle 1
Angle 2
And another one
And the money shot
Got it started and it seems the engine noise has been fixed Horray!!!! but I need to do something about the tune it is really hard to start and runs pig rich Now I try to learn how to tune horray
Old 09-10-2018, 01:04 PM   #11
Hodginsa
Always
Hodginsa's Avatar
This car look very fun. Very inspirational for what I want to build.
http://idlehandsproject.com - Keep me busy.
Hodginsa is offline   Reply With Quote
Old 09-10-2018, 01:36 PM   #12
icdpride
Thanks, Yeah I am hoping to get it tuned to a point where it is drive-able its been a struggle so far, for some idiotic reason I thought Mega-squirt and tuning would be easy... not so much lol but if cool learning it
Old 09-20-2018, 10:56 PM   #13
icdpride
So I have been working on a tune with some help this is my current tune https://drive.google.com/open?id=1p7...XXwHTmtjCxQVa5 it runs and idles just not really drive-able I think I need to pull some fuel for sure but I am still learning feel free to let me know what you thin
I will get back to tuning and data logging soon the whole return fuel line split in 2 places.
But please let me know what would help to post or share I appreciate every bit of input
Old 09-24-2018, 09:58 AM   #14
icdpride
Great news! I got it started and running yesterday
Bad news is after running for around 15 mins it just shut off, then when I went to start it it sounds like the starter is bad so I could not get it restarted. I will get a video of that later but it sounds weird.
Is it possible for a starter to go bad and cause the car to shut off? Like draw enough current to starve all the other components and shut off the car even through it is not engaged?
The car still turns over fine but a hand ratchet so I am kinda stumped. I will replace the starter and go from there but just is really strange. I swear I am usually got at cars
Old 09-25-2018, 09:32 AM   #15
icdpride
Well it for sure seems like its the starter between the smoke and the grinding I think I am right need to pull it and confirm
At the end there is some smoke, I checked all the wires nothing is melted or hot so I am assuming is the starter
Anyone know why a starter that has maybe 30-40 starts on it would go bad so fast?
Old 09-25-2018, 09:56 AM   #16
oldschoolvolvo
oldschoolvolvo's Avatar
Based on the timing belt movement, I’d also suspect the starter. Looks like it is moving very slowly.
Where did you get the starter? Maybe it is just a bad unit?
-Mike
1998 V70 T5
|Feedback|
Old 09-25-2018, 10:18 AM   #17
icdpride
Bought it on Amazon, it has a warranty but its a crap warranty, luckily there is a fresh redblock drop off at the junkyard which I will rob the starter off of.
Also if anyone needs anything off a 1990 744 with a b230ft let me know
Old 09-27-2018, 10:29 AM   #18
icdpride
Test fitting the back flares I think they look pretty good might need to heat them and bend them a little tighter but I think it looks good this tucked
Old 10-08-2018, 11:32 AM   #19
icdpride
Made the final cuts rivenutted the fenders and final mounted them I really like the way these cheap flares tuned out. Just waiting on a starter so I can get back to tuning and hopefully driving soon
Old 10-09-2018, 09:54 AM   #20
Hodginsa
Always
Hodginsa's Avatar
This looks like an easier option to fixing the rust in my fenders. haha
Nice!
Old 10-09-2018, 04:00 PM   #21
icdpride
Nice!
Haha Yup that was the side benefit I got to cut out the rust
Old 10-09-2018, 04:44 PM   #22
apachechef
Burnt Sierra Madre
Tell me about that fuel rail, please.
Dammit, Lummert.
Old 10-09-2018, 07:25 PM   #23
icdpride
The fuel rail is just the stock rail painted gold and with a fuel pressure regulator at the end with a gauge that pretty much it
