Old 03-10-2011, 08:47 PM   #101
RvolvoR
250 @ .050....should be pretty rowdy
Old 03-10-2011, 09:12 PM   #102
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
What was the deciding factor for the cam specs?
962j 815/692@27psi
THIS IS FORSALE V
Old 03-10-2011, 09:55 PM   #103
TerribleOne
ZoomZoom
TerribleOne's Avatar
Zoidberg cap.. hilarious..
To comment on JohnMc's post: I used those same engine mounts to mount my duratec engine.. They're very cheap and they're a failsafe design.. Pretty good stuff in my opinion..
75 242GL - LS turbo, 4L80E, narrowed four linked 9"
89 244DL- Mazda 2.3 MZR, S366, 5R55E on Electromotive TecGT with PCS paddle shifters
94 945- Beater
93 965- For sale
91 940SE- Roller, for sale
TerribleOne is offline   Reply With Quote
Old 03-10-2011, 10:08 PM   #104
JohnMc
JohnMc's Avatar
MAXIMUM MAYHEM! Actually, I didn't pick them, I bought them from someone who had them made and then didn't use them.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-11-2011, 12:44 PM   #105
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
looking good..
90 245GL 2JSWEDE 2JZ 245...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 03-11-2011, 12:50 PM   #106
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
need to get a better turbo manifold to go with these goodies ;)
intake side of the head (the more tedious) is done, I need to get it on the bench and balance it, but I'll probably go ahead and knock out the exhaust first since I've already got it apart.
Megasquirt Tuning!
Old 03-11-2011, 12:56 PM   #107
JohnMc
JohnMc's Avatar
The exhaust side of the engine will have to wait until next winter. I'm sure the log mani and chinaBay GT30R will continue to be the main bottlenecks on the engine. Just to a greater extent.
MS3X was probably some amount of overkill, but it jsut makes everything so damned simple. Just a ridiculous number of outputs already ready to go, just enable in Tuner Studio and hook up to the piggy. 8 ignition outputs, 8 injector outputs, bunches of logic level outputs and inputs. I think I even saw a dedicated E85 sensor input wire (if not, it's easy enough to add one), so I won't need my table switching E85 dash switch any more if I get one of those fuel sensors.
PS: Cams originally came from this place: http://schneidercams.com/camshafts.aspx
Old 03-11-2011, 01:07 PM   #108
nathaninwa
nathaninwa's Avatar
Ill be doing a 16v header soon for a few peeps. Ill keep my jig handy!
Old 03-11-2011, 01:17 PM   #109
JohnMc
JohnMc's Avatar
I'm trying to keep the A/C and power steering, which means keeping the alternator on the right side. That and the factory R134a filter/dryer/accumulator can at the back right side of the engine bay makes it a bit snug for a sprawled out tubular header.
Maybe a rams horn style with the turbo tucked down? Dunno, the next turbo will need to be a little bigger than the GT30R knockoff I have now too.
Old 03-11-2011, 02:33 PM   #110
nathaninwa
nathaninwa's Avatar
Anything is possible.....the impossible just takes a little longer.
I believe my test fit 245 has AC. When I get home ill scramble through some pics....or just head out to the yard next week. The DP gets a little tight......but I think its doable.
Old 03-11-2011, 02:44 PM   #111
JohnMc
JohnMc's Avatar
Mine is the '93 R134a system.
Which is part of the reason I kept the turbo tucked down so low on the log mani:
There's just not a lot more room down there for a larger compressor housing.
I wonder if I could relocate that drier/receiver/accumulator (whatever it is) from there to the front right corner of the engine bay, and just runa rubber line from the evaporator fitting along the fender well to it, then a flex line from there to the compressor. The way that rubber line drapes over the top of the engine like that is going to be an issue with a rams horn style manifold.
Old 03-11-2011, 02:53 PM   #112
nathaninwa
nathaninwa's Avatar
I do thye topmount header....shove it forward clearing the water pump inlet and snake the dp between primary 4 and the dryer. Might need a new hose made. I think its doable.
Old 03-11-2011, 03:46 PM   #113
Turbosteen
I was born at a young age
Turbosteen's Avatar
First time I see this thread, nice to see the planned upgrades (especially the underdrive pulley)
Looks like a really nice ride!
Btw, you've put the battery in the trunk right? I'm going to do that as well, but wondering how to hold the cable in place under the car (or keep in in the interior?).
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 03-11-2011, 03:50 PM   #114
MrBill
fige=500Dollar Mistake
MrBill's Avatar
John you should just have a new hose made and tuck it under or around or something
Someone say crazy rays?
Old 03-11-2011, 04:20 PM   #115
JohnMc
JohnMc's Avatar
Late last year the very slow leak in the A/C system got faster, so I need to take it apart to fix it anyhow. Seems like a good time to re-route that hose.
Turbosteen - I ran my battery cable inside the car. Just tucked it down under the carpet along the edge of the floorboards all the way up to the firewall, then through a rubber grommet. Totally out of the way and unnoticeable insude.
Old 04-05-2011, 05:17 PM   #116
JohnMc
JohnMc's Avatar
New part I got last week from jao. Haven't bothered to take a pic of it yet until now.
Not twin scroll, but far better than a log, and it keeps the turbo in pretty much the same spot. I'll have to see if it requires moving the A/C filter/drier/whatever somewhere else, but I'm pretty well decided on doing that anyhow - getting rid of the hose draping over the top of the motor and moving that canister to the RF corner of the engine bay.
Old 04-05-2011, 07:09 PM   #117
MrBill
MrBill's Avatar
Uh oh - johnMC's gettin' serious - I missed that update from last month.
Looks good though - get excite!
Old 04-05-2011, 07:24 PM   #118
FunkyStankyChicken
Rad Panda
FunkyStankyChicken's Avatar
This is getting good, ill be keeping an eye on it now.
‘02 V70xc
‘96 F350
‘93 525it
‘88 325is
‘84 533i
‘79 242
FunkyStankyChicken is offline   Reply With Quote
Old 04-06-2011, 08:56 AM   #119
linuxman51
linuxman51's Avatar
got the new hand piece last night. work should resume here soon.
Old 04-06-2011, 09:26 AM   #120
JohnMc
JohnMc's Avatar
*rubs hands together evilly*
Nice!
Old 07-04-2011, 03:11 PM   #121
JohnMc
JohnMc's Avatar
Got some major engine bling from Nathan last week:
Just waiting on some minor parts to get the head together (got the wrong Ferrea lash caps - for some reason they list the depth of the recess in the cap, but not the thickness added to the valve stem height, not even the overall height so you could subtract out the depth of the recess. I just sort of assumed that the only measurement offered (other than 7mm stem diameter) was the height added. But no. And the place I bought them from says special order, no returns. FML. VAC motorsports says their 7mm X 4mm lashcaps actually add 4mm, but then they want $9 a piece for them. Argh.).
So, in other words, close enough to start taking the car apart. Me ripping into a perfectly fine 300whp motor:
Any interest in a stock 16V head and 8V intake on an adapter, all 3 well ported to match the shapes? Oh, and the 8V manifold has an N/A (larger) 850 throttle body on it, bigger, shorter (for clearance in a 240 vs. the master cylinder), and a proper TPS for Megasquirt. I guess I'll toss up a FS post soon.
Old 07-05-2011, 01:57 AM   #122
Tom Wiley
I'm watching this.
Tom Wiley is offline   Reply With Quote
Old 07-05-2011, 05:27 PM   #123
doucheNozzle
doucheNozzle's Avatar
Let me know when you the thread up...
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 07-06-2011, 01:11 AM   #124
Tom Wiley
I like everything you have there.
Old 07-06-2011, 01:28 AM   #125
doucheNozzle
put
